Hi everyone,
I’m working for a big company and I need to create a custom openHAB distribution with custom bindings and services.
In order to do this, I installed the development environment with eclipse installer.
As I need to have stable builds and to stick to a stable version I checked out the 2.1.0 tag for openHAB and the 0.9.0-b5 for smarthome. All is doing fine in Eclipse but when I want to compile all on the command line the project org.eclipse.smarthome.ui.paper fail to compile.
I get the following error :
[ERROR] Failed to execute goal com.github.eirslett:frontend-maven-plugin:1.0:npm (npm install) on project org.eclipse.smarthome.ui.paper: Failed to run task: 'npm install --https-proxy=http://***:***@proxy:3128 --proxy=http://***:***@proxy:3128' failed. (error code 1) -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal com.github.eirslett:frontend-maven-plugin:1.0:npm (npm install) on project org.eclipse.smarthome.ui.paper: Failed to run task
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:212)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:116)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:80)
at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build(SingleThreadedBuilder.java:51)
at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:128)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:307)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:193)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:106)
at org.apache.maven.cli.MavenCli.execute(MavenCli.java:863)
at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:288)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:199)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:289)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:229)
at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:415)
at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:356)
Caused by: org.apache.maven.plugin.MojoFailureException: Failed to run task
at com.github.eirslett.maven.plugins.frontend.mojo.AbstractFrontendMojo.execute(AbstractFrontendMojo.java:95)
at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:134)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:207)
... 20 more
Caused by: com.github.eirslett.maven.plugins.frontend.lib.TaskRunnerException: 'npm install --https-proxy=http://***:***@proxy:3128 --proxy=http://***:***@proxy:3128' failed. (error code 1)
at com.github.eirslett.maven.plugins.frontend.lib.NodeTaskExecutor.execute(NodeTaskExecutor.java:60)
at com.github.eirslett.maven.plugins.frontend.mojo.NpmMojo.execute(NpmMojo.java:62)
at com.github.eirslett.maven.plugins.frontend.mojo.AbstractFrontendMojo.execute(AbstractFrontendMojo.java:89)
... 22 more
[ERROR]
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException
When I run the npm install in the project with the same parameters all is doing well.
Does anyone ah a solution ?
Thanks in advance
Matthieu
