Failed to install Grafana
Tags: #<Tag:0x00007f617e211e70> #<Tag:0x00007f617e211d08>
I have problems with installing Grafana and InfluxDB.
I tried to install with the openhabian config tool. But got an error.
With the video https://www.youtube.com/watch?v=T0GnfHt8aLg I tried to install it manually, but also I’m not able to solve the problem.
It seems that installing Grafana is the problem. InfluxDB is running but on installing Grafana I get this error:
Vorbereitung zum Entpacken von .../grafana_6.7.3_armhf.deb ...
Entpacken von grafana (6.7.3) ...
dpkg: Fehler beim Bearbeiten des Archivs /var/cache/apt/archives/grafana_6.7.3_armhf.deb (--unpack):
 Versuch, »/usr/share/grafana/conf/defaults.ini« zu überschreiben, welches auch in Paket grafana-data 2.6.0+dfsg-3 ist
dpkg-deb: Fehler: »einfügen«-Unterprozess wurde durch Signal (Datenübergabe unterbrochen (broken pipe)) getötet
I found no topic for this problem, has someone a solution for this problem?
Thanks for your help.
same problem here. Any suggestions?
I found it.
File could not be overwritten because it belongs to a different package (grafana-data 2.6.0+dfsg-3)
you must first delete this package with
sudo apt-get purge grafana-data
Then you can install grafana with:
sudo apt-get update
sudo apt-get install grafana
Thanks, that worked for me too!
But then I had the problem, that grafana doesn’t start automatically after reboot.
Thanks to this Post https://community.grafana.com/t/grafana-service-does-not-start-after-reboot/2759/10
now everything works fine.
