I just realized I’m running a corrected version of “org.openhab.core.automation.module.script.rulesupport” to fix the rule loading issue on Windows. I wonder if that is causing the issue? @5iver
Seems to be related… in the console, what is returned for this?
list -s |grep rulesupport
I’m thinking you make have cleared the cache and the original bundle popped up again, so you may need to uninstall it again. I’ll fire up my Windows VM and install http1.
OK… I received the same error. So, remove the updated rulesupport bundle from /addons/ and install the http1 binding or wait for it to try to install again. After it installs, follow the steps again for adding in the updated bundle.
