ISSUES:
After installing latest openHABian 1.5 (fresh install using prebuilt SD image), Bluetooth is not working. During boot I get error “Failed to start Configure Bluetooth Modems connected by UART”, and hciuart.service logs can be seen below. Serial port settings are all unchecked in openhabian-config.
Same issue can be seen when installing openHAB via APT on top of Raspian Stretch Lite, but first with only Raspbian, BT is working fine, but after installing openHABian, errors are the same as with this pre-build SD image.
Any tips?
Platform information:
Hardware: Raspberry Pi 3 Model B Rev 1.2
OS: Raspbian GNU/Linux 10 (buster)
Java Runtime Environment:
openjdk version "1.8.0_222" OpenJDK Runtime Environment (Zulu8.40.0.178-CA-linux_aarch32hf) (build 1.8.0_222-b178) OpenJDK Client VM (Zulu8.40.0.178-CA-linux_aarch32hf) (build 25.222-b178, mixed mode, Evaluation)
openHAB version: 2.4 and 2.5 M3
Logs
[16:54:30] openhabian@openhab:~$ systemctl status hciuart.service hciuart.service - Configure Bluetooth Modems connected by UART Loaded: loaded (/lib/systemd/system/hciuart.service; enabled; vendor preset: enabled) Active: failed (Result: exit-code) since Thu 2019-10-03 16:53:05 EEST; 1min 28s ago Process: 322 ExecStart=/usr/bin/btuart (code=exited, status=1/FAILURE) Oct 03 16:53:00 openhab systemd[1]: Starting Configure Bluetooth Modems connected by UART... Oct 03 16:53:05 openhab btuart[322]: Can't set line discipline: Invalid argument Oct 03 16:53:05 openhab btuart[322]: Can't initialize device: Invalid argument Oct 03 16:53:05 openhab btuart[322]: bcm43xx_init Oct 03 16:53:05 openhab btuart[322]: Flash firmware /lib/firmware/brcm/BCM43430A1.hcd Oct 03 16:53:05 openhab btuart[322]: Set BDADDR UART: b8:27:eb:5c:01:e9 Oct 03 16:53:05 openhab btuart[322]: Set Controller UART speed to 921600 bit/s Oct 03 16:53:05 openhab systemd[1]: hciuart.service: Control process exited, code=exited, status=1/FAILURE Oct 03 16:53:05 openhab systemd[1]: hciuart.service: Failed with result 'exit-code'. Oct 03 16:53:05 openhab systemd[1]: Failed to start Configure Bluetooth Modems connected by UART.
