andyh
(Andy Howell)
December 20, 2020, 7:12am
1
Upgraded to RC2 from RC1. Notice this error:
Preparing to unpack …/openhab_3.0.0~RC2-1_all.deb …
Warning: openHAB’s home directory is incorrect (/var/lib/openhab2)
but can’t be changed because another process (358
493) is using it.
Frontail is the culprit:
openhab 358 0.0 1.1 138080 45048 ? Ssl Dec17 0:01 node /usr/bin/frontail --ui-highlight --ui-highlight-preset /usr/lib/node_modules/frontail/preset/openhab.json -t openhab -l 2000 -n 200 /var/log/openhab2/openhab.log /var/log/openhab2/events.log
The only config file I found with frontail in is /etc/openhab/service/dashboard.cfg
mstormi
(Markus Storm)
December 20, 2020, 12:58pm
2
your post is unrelated to OH and off topic so I moved it, mind the rules please.
You have an oldish openhabian setup. Try reinstalling frontail from the menu.
andyh
(Andy Howell)
December 21, 2020, 1:25am
3
Sorry. It wasn’t clear to me that this was not part of OH. It seemed relevant in that it was a failure brought to light during the upgrade.
matt1
(Skinah)
December 21, 2020, 2:40am
4
If frontail is running it probably just needs to be stopped. Try this and then update again:
sudo service frontail stop
Also two things to note:
All paths that have openhab2 in them will need to be edited so it is just openhab. Need to work out where they are located to edit them.
Second I believe that there is no dashboard anymore so that config file does nothing and it can be deleted.
