- Hardware: rasp pi zero 2w (I know this is not reccomended but wifi shouldn’t be the problem right)
- Issue of the topic: I’ve been trying to install openhabian using the wifi setup with config changes below. I’ve tried ipv6 on and off.
I’ve also tried looking for the hotspot, which the log says was launched. but I couldn’t find it.
I first tried without changing the timezone. no difference.
timezone=Europe/Brussels
locales="en_BE.UTC+1 en_BE.UTC+1"
system_default_locale="en_BE.UTC+1"
wifi_ssid="WiFi-2.4-A266"
wifi_password="w9k56hksacw9h"
wifi_country="BE"
ipv6=disable
first-boot.log below
2021-05-07_18:51:02_CEST [openHABian] Starting the openHABian initial setup.
2021-05-07_18:51:02_CEST [openHABian] Storing configuration... /etc/openhabian.conf: line 63: pi3: command not found
OK
2021-05-07_18:51:03_CEST [openHABian] Enable maximum debugging output
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2021-05-07_18:51:03_CEST [openHABian] Starting webserver with installation log... '
2021-05-07_18:51:03_CEST [openHABian] Starting webserver with installation log... ++ command -v python3
+ [[ -x /usr/bin/python3 ]]
+ bash /boot/webserver.bash start
bash: /boot/webserver.bash: No such file or directory
+ sleep 5
++ ps -ef
++ pgrep python3
+ isWebRunning=
+ [[ -n '' ]]
+ echo FAILED
FAILED
+ defaultUserAndGroup=openhabian
+ userName=openhabian
+ groupName=openhabian
+ is_raspbian
+ [[ '' == \r\a\s\p\b\i\a\n ]]
++ cat /etc/os-release
+ [[ PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs" =~ Raspbian ]]
+ return 0
+ defaultUserAndGroup=pi
+ rm -f /etc/sudoers.d/010_pi-nopasswd
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2021-05-07_18:51:08_CEST [openHABian] Changing default username and password... '
2021-05-07_18:51:08_CEST [openHABian] Changing default username and password... + [[ -v openhabian ]]
+ id pi
+ echo SKIPPED
SKIPPED
+ echo 'watch cat /boot/first-boot.log'
+ echo noipv4ll
+ [[ -z WiFi-2.4-A266 ]]
+ grep -qs openHABian /etc/wpa_supplicant/wpa_supplicant.conf
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2021-05-07_18:51:08_CEST [openHABian] Setting up Wi-Fi connection... '
2021-05-07_18:51:08_CEST [openHABian] Setting up Wi-Fi connection... + wifiCountry=BE
+ wifiSSID=WiFi-2.4-A266
+ wifiPassword=w9k56hksacw9h
+ grep -qs '^BE[[:space:]]' /usr/share/zoneinfo/zone.tab
+ wifiCountry=BE
++ wpa_passphrase WiFi-2.4-A266 w9k56hksacw9h
+ wifiConfig='network={
#psk="w9k56hksacw9h"
psk=3d5367138f3be3fd7d3ced6eaf2d814728fa2f8c21bbe054b748d90d35073863
+ echo -e '# WiFi configuration generated by openHABian\ncountry=BE\nctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev\nupdate_config=1\n# Network configuration was created by wpa_passphrase to ensure correct handling of special characters\nnetwork={
\tkey_mgmt=WPA-PSK\n}'
+ sed -i 's|REGDOMAIN=.*$|REGDOMAIN=BE|g' /etc/default/crda
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2021-05-07_18:51:08_CEST [openHABian] Configuring network... '
2021-05-07_18:51:08_CEST [openHABian] Configuring network... + grep -qs wlan0 /etc/network/interfaces
+ cond_echo '\nNot writing to '\''/etc/network/interfaces'\'', wlan0 entry already available. You might need to check, adopt or remove these lines.'
+ [[ -z 1 ]]
+ is_pi
+ is_pifour
+ [[ '' == \p\i\4 ]]
+ grep -q '^Revision\s*:\s*[ 123][0-9a-fA-F][0-9a-fA-F][0-9a-fA-F]11[0-9a-fA-F]$' /proc/cpuinfo
+ return 1
+ is_cmfour
+ [[ '' == \c\m\4 ]]
+ grep -q '^Revision\s*:\s*[ 123][0-9a-fA-F][0-9a-fA-F][0-9a-fA-F]14[0-9a-fA-F]$' /proc/cpuinfo
+ return 1
+ is_pi400
+ [[ '' == \p\i\4\0\0 ]]
+ grep -q '^Revision\s*:\s*[ 123][0-9a-fA-F][0-9a-fA-F][0-9a-fA-F]13[0-9a-fA-F]$' /proc/cpuinfo
+ return 1
+ is_cmthreeplus
+ [[ '' == \c\m\3\+ ]]
+ grep -q '^Revision\s*:\s*[ 123][0-9a-fA-F][0-9a-fA-F][0-9a-fA-F]10[0-9a-fA-F]$' /proc/cpuinfo
+ return 1
+ is_cmthree
+ [[ '' == \c\m\3 ]]
+ grep -q '^Revision\s*:\s*[ 123][0-9a-fA-F][0-9a-fA-F][0-9a-fA-F]0[aA][0-9a-fA-F]$' /proc/cpuinfo
+ return 1
+ is_pithree
+ [[ '' == \p\i\3 ]]
+ grep -q '^Revision\s*:\s*[ 123][0-9a-fA-F][0-9a-fA-F][0-9a-fA-F]0[8dDeE][0-9a-fA-F]$' /proc/cpuinfo
+ return 1
+ is_pitwo
+ [[ '' == \p\i\2 ]]
+ grep -q '^Revision\s*:\s*[ 123][0-9a-fA-F][0-9a-fA-F][0-9a-fA-F]04[0-9a-fA-F]$' /proc/cpuinfo
+ return 1
+ is_pione
+ [[ '' == \p\i\1 ]]
+ grep -q '^Revision\s*:\s*00[0-9a-fA-F][0-9a-fA-F]$' /proc/cpuinfo
+ grep -q '^Revision\s*:\s*[ 123][0-9a-fA-F][0-9a-fA-F][0-9a-fA-F]0[0-36][0-9a-fA-F]$' /proc/cpuinfo
+ return 1
+ is_cmone
+ [[ '' == \c\m\1 ]]
+ grep -q '^Revision\s*:\s*[ 123][0-9a-fA-F][0-9a-fA-F][0-9a-fA-F]06[0-9a-fA-F]$' /proc/cpuinfo
+ return 1
+ is_pizerow
+ [[ '' == \p\i\0\w ]]
+ grep -q '^Revision\s*:\s*[ 123][0-9a-fA-F][0-9a-fA-F][0-9a-fA-F]0[cC][0-9a-fA-F]$' /proc/cpuinfo
+ return 1
+ is_pizero
+ [[ '' == \p\i\0 ]]
+ grep -q '^Revision\s*:\s*[ 123][0-9a-fA-F][0-9a-fA-F][0-9a-fA-F]09[0-9a-fA-F]$' /proc/cpuinfo
+ return 1
+ return 1
+ wpa_cli reconfigure
+ echo OK
OK
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2021-05-07_18:51:08_CEST [openHABian] Ensuring network connectivity... '
2021-05-07_18:51:08_CEST [openHABian] Ensuring network connectivity... + running_in_docker
