- Platform information:
- Hardware: Raspberry 3/1GB/16GB
- OS: Openhabian (Debian GNU/Linux 10 (buster))
- Java Runtime Environment: which java platform is used and what version
- openHAB version: 3.0.1
- Issue of the topic: Fails to add items via usb-dongle
First, I don’t think this is necessarily an openhab issue. It might be an os/dongle thing.
Now, the story.
A while ago I had a small NUC machine running Windows server. It was doing some small stuff and I thought it might be a good idea to use it also for home automation. I downloaded openhab 2.0, bought an Aeotec gen5 stick and added z-wave things. All went fine.
Now, I moved and decided to start the network from scratch. I bought also a cheap cc2531 from amazon (they claim it is already flushed and should work fine with openhab) and I tried to set them up both, to do a mesh network (reuse some of my old things and by new ones).
I ditched Windows and decided to use ubuntu 20.10. Installed it, openhab installation is going fine. I am adding the dongles via add-new-thing, use binding (z-wave/zigbee), configured the port and openhab was seeing both dongles as green. Logs are happy, no complains there. I start the process of adding new things, I use the z-wave/zigbee bindings, reset the devices and put them into inclusion mode, then start the scan - but the no thing is found. The other bindings (network, chromecast, bluetooth) seem to work. Again, nothing in the logs.
Ok, I am thinking maybe there is a bug in oh3, installing oh2.5. The same behavior.
Now, I am thinking there might be a hardware issue, or something that I missed. I found an old raspberry 3 lying around in a drawer. Installed openhabian on it, everything is the default. Adding the sticks, the same. No thing is found.
I did some reading over the web and some complained about zigbee being messed by wifi or distance. The closest zigbee thing is 3m away (one wooden wall between) and z-wave 1m away (nothing in between). I set my wifi channel on 1 and the manually set the zigbee chanel to 25. Still the same, nothing in the logs.
Basically, the only things I see things like this:
2021-03-14 13:35:31.469 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:serial_zstick:745a8d3f6d' changed from UNINITIALIZED to INITIALIZING
2021-03-14 13:35:31.494 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:serial_zstick:745a8d3f6d' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2021-03-14 13:35:40.943 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:serial_zstick:745a8d3f6d' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
and then later on
2021-03-14 13:47:57.876 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:serial_zstick:745a8d3f6d' changed from ONLINE to UNINITIALIZED
2021-03-14 13:47:58.240 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:serial_zstick:745a8d3f6d' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2021-03-14 13:47:58.287 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:coordinator_cc2531:5608b4b50c' changed from ONLINE to UNINITIALIZED
2021-03-14 13:48:03.339 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:coordinator_cc2531:5608b4b50c' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
Yet, when I check them in the interface, they look “green”/ONLINE.
If I use lsusb
Bus 001 Device 005: ID 0658:0200 Sigma Designs, Inc. Aeotec Z-Stick Gen5 (ZW090) - UZB
Bus 001 Device 004: ID 0451:16a8 Texas Instruments, Inc.
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
On dmesg
the only errors I see are around the bluetooth dongle:
[ 178.493741] WARN::dwc_otg_hcd_urb_dequeue:639: Timed out waiting for FSM NP transfer to complete on 0
[ 204.031225] Bluetooth: hci0: command 0x2005 tx timeout
[ 206.047266] Bluetooth: hci0: command 0x200b tx timeout
[ 208.063251] Bluetooth: hci0: command 0x200c tx timeout
[ 300.093799] WARN::dwc_otg_hcd_urb_dequeue:639: Timed out waiting for FSM NP transfer to complete on 5
Now, to be honest, I am pretty confused. I don’t know where else can I look for problems on why none of the things I want to add are being seen by openhab.
At this moment, I haven’t tried any other software as - like I told you - I don’t really think it’s openhab’s fault (I hope, fingers crossed). So, guys, any hint?
Thanks.
