- Platform information:
- Hardware: 2xXeon E5-2697 v2 / x86_64 / 128 GB / 5 TB HDD
- OS: FreeBSD 12.3-RELEASE-p1 Jail on TrueNAS 12.0 host
- Java Runtime Environment: OpenJDK 11.0.13+8-1
- openHAB version: openHAB 3.2.0Release Build installed from Ports (pkg install openhab)
- Issue of the topic: I’m unable to automatically discover things. I have some Shelly Plugs and a Yeelight that should be discovered. I can’t remove things, it just stays in REMOVING state. It initially worked well, but then I’ve copied my rule files from openhab2 and installed a bunch of add-ons. Not sure why it fails, but I’m hoping that the log below can point to the problem. Maybe this message is relevant – how could I increase the number of threads in the thread pool?
2022-01-23 10:18:28.606 [ERROR] [t.http.internal.WebClientFactoryImpl] - Could not start Jetty web socket client
java.lang.IllegalStateException: Insufficient configured threads: required=52 < max=40 for QueuedThreadPool[OH-httpClient-common]@7239b1d4{STARTED,10<=24<=40,i=0,r=-1,q=0}[ReservedThreadExecutor@19e3edf9{s=0/4,p=0}]
- Please post configurations (if applicable):
Installed bindings: DMX, LG TV Serial, LIFX, MQTT, Shelly, Yeelight.
I have several complex rule files, and haven’t completed porting everything to OpenHAB 3. Some rule files use the wrong date API. I can share the rules if you think it’s relevant.
- If logs where generated please post these here using code fences:
2022-01-23 10:18:09.704 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/Oslo'.
2022-01-23 10:18:09.720 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to '59.516488560259226,10.476563572883608'.
2022-01-23 10:18:09.721 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'en_NO'.
2022-01-23 10:18:12.731 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'fas.sitemap'
2022-01-23 10:18:14.041 [INFO ] [.core.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2022-01-23 10:18:14.135 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'smart.rules'
2022-01-23 10:18:17.589 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'smart.rules', using it anyway:
Unnecessary cast from HSBType to HSBType
2022-01-23 10:18:17.640 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'alarm.rules'
2022-01-23 10:18:17.844 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'oppstart.rules'
2022-01-23 10:18:18.311 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'sov.rules'
2022-01-23 10:18:20.349 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'sov.rules', using it anyway:
The field Tmp_sovRules.alarmTid refers to the missing type Object
The field Tmp_sovRules.preAlarmTid refers to the missing type Object
2022-01-23 10:18:20.391 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'console.rules'
2022-01-23 10:18:21.504 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'oppvarming.rules'
2022-01-23 10:18:22.207 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'storeknapp.rules'
2022-01-23 10:18:22.762 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'lys.rules'
2022-01-23 10:18:24.586 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'lys.rules', using it anyway:
Unnecessary cast from PercentType to PercentType
2022-01-23 10:18:27.465 [INFO ] [org.openhab.ui.internal.UIService ] - Started UI on port 8080
2022-01-23 10:18:27.982 [INFO ] [ab.ui.habpanel.internal.HABPanelTile] - Started HABPanel at /habpanel
2022-01-23 10:18:28.397 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.1.8' with clientid 9b892d19-8a22-49ac-9c13-9da0f48b8791
2022-01-23 10:18:28.557 [ERROR] [t.http.internal.WebClientFactoryImpl] - Could not start Jetty web socket client
at org.eclipse.jetty.util.thread.ThreadPoolBudget.check(ThreadPoolBudget.java:165) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.ThreadPoolBudget.leaseTo(ThreadPoolBudget.java:141) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.ThreadPoolBudget.leaseFrom(ThreadPoolBudget.java:191) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.io.SelectorManager.doStart(SelectorManager.java:255) ~[?:?]
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:73) ~[?:?]
at org.eclipse.jetty.util.component.ContainerLifeCycle.start(ContainerLifeCycle.java:169) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:117) ~[bundleFile:9.4.43.v20210629]
at org.eclipse.jetty.client.AbstractConnectorHttpClientTransport.doStart(AbstractConnectorHttpClientTransport.java:64) ~[?:?]
at org.eclipse.jetty.client.HttpClient.doStart(HttpClient.java:255) ~[?:?]
at org.eclipse.jetty.websocket.client.WebSocketClient.doStart(WebSocketClient.java:413) ~[bundleFile:9.4.43.v20210629]
at org.openhab.core.io.net.http.internal.WebClientFactoryImpl$3.run(WebClientFactoryImpl.java:293) [bundleFile:?]
at org.openhab.core.io.net.http.internal.WebClientFactoryImpl$3.run(WebClientFactoryImpl.java:1) [bundleFile:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at org.openhab.core.io.net.http.internal.WebClientFactoryImpl.createWebSocketClientInternal(WebClientFactoryImpl.java:275) [bundleFile:?]
at org.openhab.core.io.net.http.internal.WebClientFactoryImpl$1.run(WebClientFactoryImpl.java:211) [bundleFile:?]
at org.openhab.core.io.net.http.internal.WebClientFactoryImpl$1.run(WebClientFactoryImpl.java:1) [bundleFile:?]
at org.openhab.core.io.net.http.internal.WebClientFactoryImpl.initialize(WebClientFactoryImpl.java:192) [bundleFile:?]
at org.openhab.core.io.net.http.internal.WebClientFactoryImpl.getCommonHttpClient(WebClientFactoryImpl.java:143) [bundleFile:?]
at org.openhab.binding.shelly.internal.ShellyHandlerFactory.<init>(ShellyHandlerFactory.java:96) [bundleFile:?]
at jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) ~[?:?]
at jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62) [?:?]
at jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) [?:?]
at java.lang.reflect.Constructor.newInstance(Constructor.java:490) [?:?]
at org.apache.felix.scr.impl.inject.internal.ComponentConstructorImpl.newInstance(ComponentConstructorImpl.java:316) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:286) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:115) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:1000) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:973) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:918) [bundleFile:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:216) [org.eclipse.osgi-3.16.300.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:213) [org.eclipse.osgi-3.16.300.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:114) [org.eclipse.osgi-3.16.300.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:48) [org.eclipse.osgi-3.16.300.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:547) [org.eclipse.osgi-3.16.300.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:533) [org.eclipse.osgi-3.16.300.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:656) [org.eclipse.osgi-3.16.300.jar:?]
at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:88) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObject(BindMethod.java:675) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2556) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:2075) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:2058) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:443) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:333) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:301) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1200) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1121) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:928) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:864) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1152) [bundleFile:?]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:114) [bundleFile:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:120) [org.eclipse.osgi-3.16.300.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:957) [org.eclipse.osgi-3.16.300.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234) [org.eclipse.osgi-3.16.300.jar:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151) [org.eclipse.osgi-3.16.300.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:936) [org.eclipse.osgi-3.16.300.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:873) [org.eclipse.osgi-3.16.300.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:141) [org.eclipse.osgi-3.16.300.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:261) [org.eclipse.osgi-3.16.300.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:496) [org.eclipse.osgi-3.16.300.jar:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:929) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:915) [bundleFile:?]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:133) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:984) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:752) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1271) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1222) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:674) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:437) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:667) [bundleFile:?]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:305) [bundleFile:?]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:554) [bundleFile:?]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:70) [bundleFile:?]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:421) [bundleFile:?]
at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) [bundleFile:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) [bundleFile:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) [bundleFile:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:488) [osgi.core-7.0.0.jar:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:420) [osgi.core-7.0.0.jar:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [osgi.core-7.0.0.jar:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:450) [osgi.core-7.0.0.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:945) [org.eclipse.osgi-3.16.300.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:232) [org.eclipse.osgi-3.16.300.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:138) [org.eclipse.osgi-3.16.300.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:130) [org.eclipse.osgi-3.16.300.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:217) [org.eclipse.osgi-3.16.300.jar:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:499) [org.eclipse.osgi-3.16.300.jar:?]
at org.eclipse.osgi.container.Module.start(Module.java:486) [org.eclipse.osgi-3.16.300.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1849) [org.eclipse.osgi-3.16.300.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136) [org.eclipse.osgi-3.16.300.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1842) [org.eclipse.osgi-3.16.300.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1785) [org.eclipse.osgi-3.16.300.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1747) [org.eclipse.osgi-3.16.300.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1669) [org.eclipse.osgi-3.16.300.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [org.eclipse.osgi-3.16.300.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345) [org.eclipse.osgi-3.16.300.jar:?]
2022-01-23 10:18:28.567 [ERROR] [shelly.internal.ShellyHandlerFactory] - bundle org.openhab.binding.shelly:3.2.0 (283)[org.openhab.binding.shelly.internal.ShellyHandlerFactory(311)] : Error during instantiation of the implementation object
java.lang.reflect.InvocationTargetException: null
at jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62) ~[?:?]
at jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) ~[?:?]
at java.lang.reflect.Constructor.newInstance(Constructor.java:490) ~[?:?]
at org.apache.felix.scr.impl.inject.internal.ComponentConstructorImpl.newInstance(ComponentConstructorImpl.java:316) ~[bundleFile:?]
Caused by: org.openhab.core.io.net.http.HttpClientInitializationException: Could not start Jetty web socket client
at org.openhab.core.io.net.http.internal.WebClientFactoryImpl$3.run(WebClientFactoryImpl.java:296) ~[?:?]
at org.openhab.core.io.net.http.internal.WebClientFactoryImpl$3.run(WebClientFactoryImpl.java:1) ~[?:?]
at org.openhab.core.io.net.http.internal.WebClientFactoryImpl.createWebSocketClientInternal(WebClientFactoryImpl.java:275) ~[?:?]
at org.openhab.core.io.net.http.internal.WebClientFactoryImpl$1.run(WebClientFactoryImpl.java:211) ~[?:?]
at org.openhab.core.io.net.http.internal.WebClientFactoryImpl$1.run(WebClientFactoryImpl.java:1) ~[?:?]
at org.openhab.core.io.net.http.internal.WebClientFactoryImpl.initialize(WebClientFactoryImpl.java:192) ~[?:?]
at org.openhab.core.io.net.http.internal.WebClientFactoryImpl.getCommonHttpClient(WebClientFactoryImpl.java:143) ~[?:?]
at org.openhab.binding.shelly.internal.ShellyHandlerFactory.<init>(ShellyHandlerFactory.java:96) ~[?:?]
... 100 more
Caused by: java.lang.IllegalStateException: Insufficient configured threads: required=52 < max=40 for QueuedThreadPool[OH-httpClient-common]@7239b1d4{STARTED,10<=24<=40,i=0,r=-1,q=0}[ReservedThreadExecutor@19e3edf9{s=0/4,p=0}]
at org.eclipse.jetty.util.thread.ThreadPoolBudget.check(ThreadPoolBudget.java:165) ~[?:?]
at org.eclipse.jetty.util.thread.ThreadPoolBudget.leaseTo(ThreadPoolBudget.java:141) ~[?:?]
at org.eclipse.jetty.util.thread.ThreadPoolBudget.leaseFrom(ThreadPoolBudget.java:191) ~[?:?]
at org.eclipse.jetty.util.component.ContainerLifeCycle.start(ContainerLifeCycle.java:169) ~[?:?]
at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:117) ~[?:?]
at org.eclipse.jetty.websocket.client.WebSocketClient.doStart(WebSocketClient.java:413) ~[?:?]
at org.openhab.core.io.net.http.internal.WebClientFactoryImpl$3.run(WebClientFactoryImpl.java:293) ~[?:?]
... 100 more
2022-01-23 10:18:28.601 [WARN ] [g.discovery.internal.PersistentInbox] - bundle org.openhab.core.config.discovery:3.2.0 (164)[org.openhab.core.config.discovery.internal.PersistentInbox(114)] : Could not get service from ref {org.openhab.core.thing.binding.ThingHandlerFactory, org.openhab.binding.shelly.internal.ShellyHandlerFactory}={service.id=522, service.bundleid=283, service.scope=bundle, component.name=org.openhab.binding.shelly.internal.ShellyHandlerFactory, component.id=311}
2022-01-23 10:18:28.602 [WARN ] [g.discovery.internal.PersistentInbox] - bundle org.openhab.core.config.discovery:3.2.0 (164)[org.openhab.core.config.discovery.internal.PersistentInbox(114)] : DependencyManager : invokeBindMethod : Service not available from service registry for ServiceReference {org.openhab.core.thing.binding.ThingHandlerFactory, org.openhab.binding.shelly.internal.ShellyHandlerFactory}={service.id=522, service.bundleid=283, service.scope=bundle, component.name=org.openhab.binding.shelly.internal.ShellyHandlerFactory, component.id=311} for reference ThingHandlerFactory
