Fakro ARZ Komfort Z-Wave
Dear Community. I have several Fakro ARZ Komfort Z-Wave Roller Shutters (6 pcs.) in my house.
I have discovered them using my aeotec z-wave stick, but it seems this roller shutter is not in the z-wave database, the discovered device is labeled: Z-Wave Node 005 (0085:0003:0013:1.1). Can anybody help me or give me instrucitons how to add this entry to the database? Thanks in advance
https://www.opensmarthouse.org/blog/zwave_device_database_guide
Welcome to OH.
There appears to be three ARZ version already in the ZW DB, but none have your exact numbers. Per the guide posted above the simplest option is to add your numbers to the entry. This entry looks the closest (it has the 1.1 version as a minimum). One option to test (and get going right away) would be follow this procedure with the file below. You will want to override/or replace the file in your current ZW binding.
arz2_1_1.xml (6.3 KB)
