Hey everybody,
I am thinking of getting an “Fakro ARF solar” blind with a zwave function.
In the zwave binding is only the ARF mentioned, without “solar”.
Does anyone know if it would work with the binding?
Thanks for infos
Martin
Hey everybody,
Thanks for infos
Martin
Hi Martin, I assume you did lookup the device in the Z-Wave database that is part of the binding? If the device is not mentioned there, it will not function. But you can add the device yourself, following the instructions here.
