Probably you are not using a recent snapshot of the binding as the device was only added quite recently. If you update to the current snapshot I would think it would work.
The FT116 doesn’t seem to be in the database at the moment, so that probably will not work until it is added. See the database guide for more information.
Thank you!
I installed the newest snapshot and the dimmer module is working.
There is not so much rush with the FT116 module, but any idea if it will be added? If not I will just changes those for a different module.
Thanks. I’ve copied over the configuration from the Aeon device - I think it’s the same configuration as the manual you’ve uploaded, but it would pay to do a quick check to ensure that at least the same parameter numbers are consistent as this can cause problems if there are parameters missing.
If it’s ok, then please click the request review button and we’ll get it into the binding.
