Hi @mstormi, I deleted all files on a 32GB USB stick. Then i checked the usb stick:
$ ls /dev/sd*
/dev/sda /dev/sda1
Then i changed the file system on it to ext4
$ sudo mkfs.ext4 /dev/sda1
mke2fs 1.43.4 (31-Jan-2017)
/dev/sda1 contains a vfat file system
Proceed anyway? (y,N) y
Creating filesystem with 7591244 4k blocks and 1900544 inodes
Filesystem UUID: 68a04dbe-f5ff-4a45-8897-16c632e29f6b
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
4096000
Allocating group tables: done
Writing inode tables: done
Creating journal (32768 blocks): done
Writing superblocks and filesystem accounting information: done
- i mounted it again to
/mnt/usb
- i started
sudo openhabian-config
again to configure Amanda Backup. - switched to user backup
sudo su - backup
~$ amcheck openhab-dir
Amanda Tape Server Host Check
slot 1: contains an empty volume
Will write label 'openHABian-openhab-dir-001' to new volume in slot 1.
NOTE: skipping tape-writable test
NOTE: host info dir /var/lib/amanda/openhab-dir/curinfo/openHABianPi does not exist
NOTE: it will be created on the next run.
NOTE: index dir /var/lib/amanda/openhab-dir/index/openHABianPi does not exist
Server check took 1.454 seconds
Amanda Backup Client Hosts Check
Client check: 1 host checked in 3.164 seconds. 0 problems found.
(brought to you by Amanda 3.3.9)
This looks good, i think…
[14:07:11] backup@openHABianPi:~$ amcheck openhab-dir
[14:07:28] backup@openHABianPi:~$ amreport openhab-dir
*** THE DUMPS DID NOT FINISH PROPERLY!
The next 10 tapes Amanda expects to use are: 10 new tapes.
FAILURE DUMP SUMMARY:
planner: FATAL errors processing config file
driver: FATAL errors processing config file
STATISTICS:
Total Full Incr. Level:#
Estimate Time (hrs:min) 0:00
Run Time (hrs:min) 0:00
Dump Time (hrs:min) 0:00 0:00 0:00
Output Size (meg) 0.0 0.0 0.0
Original Size (meg) 0.0 0.0 0.0
Avg Compressed Size (%) -- -- --
DLEs Dumped 0 0 0
Avg Dump Rate (k/s) -- -- --
Tape Time (hrs:min) 0:00 0:00 0:00
Tape Size (meg) 0.0 0.0 0.0
Tape Used (%) 0.0 0.0 0.0
DLEs Taped 0 0 0
Parts Taped 0 0 0
Avg Tp Write Rate (k/s) -- -- --
DUMP SUMMARY:
DUMPER STATS TAPER STATS
HOSTNAME DISK L ORIG-kB OUT-kB COMP% MMM:SS KB/s MMM:SS KB/s
(brought to you by Amanda version 3.3.9)
[14:11:02] backup@openHABianPi:~$ amdump openhab-dir
[14:11:56] backup@openHABianPi:~$ amreport openhab-dir
Hostname: openHABianPi
Org : openHABian openhab-dir
Config : openhab-dir
Date : February 25, 2019
These dumps were to tape openHABian-openhab-dir-001.
STATISTICS:
Output Size (meg) 81.9 81.9 0.0
Original Size (meg) 81.9 81.9 0.0
Avg Compressed Size (%) 100.0 100.0 --
DLEs Dumped 2 2 0
Avg Dump Rate (k/s) 5315.7 5315.7 --
Tape Size (meg) 81.9 81.9 0.0
Tape Used (%) 24.6 24.6 0.0
DLEs Taped 2 2 0
Parts Taped 2 2 0
Avg Tp Write Rate (k/s) 5947.5 5947.5 --
USAGE BY TAPE:
Label Time Size % DLEs Parts
openHABian-openhab-dir-001 0:00 83860k 24.6 2 2
NOTES:
planner: Adding new disk openHABianPi:/etc/openhab2.
planner: Adding new disk openHABianPi:/var/lib/openhab2.
planner: WARNING: no history available for openHABianPi:/var/lib/openhab2; guessing that size will be 170496 KB
planner: WARNING: no history available for openHABianPi:/etc/openhab2; guessing that size will be 170496 KB
taper: Slot 1 without label can be labeled
taper: Slot 2 without label can be labeled
taper: tape openHABian-openhab-dir-001 kb 83860 fm 2 [OK]
big estimate: openHABianPi /etc/openhab2 0
est: 170528k out 350k
DUMP SUMMARY:
openHABianPi /etc/openhab2 0 350 350 -- 0:01 239.6 0:00 3500.0
openHABianPi /var/lib/openhab2 0 83510 83510 -- 0:14 5833.1 0:14 5965.0
You have new mail in /var/mail/backup
[14:12:13] backup@openHABianPi:~$
But here, i do not see that the whole sd-card has been backup-ed… It is definitely not the same as i see in the openhabian-amanda.md
What am I doing wrong? Btw, i filled in 5000 for the Storage capacity.
