@namraccr, glad you’re looking into this binding. It’s worked well for me, but I see these every OH restart…
2018-12-22 18:11:25.695 [INFO ] [org.openhab.binding.feed.internal.handler.FeedHandler] - Can not update channel with ID: latest-date, no data has been downloaded from the server!
2018-12-22 18:11:25.696 [INFO ] [org.openhab.binding.feed.internal.handler.FeedHandler] - Can not update channel with ID: latest-title, no data has been downloaded from the server!
2018-12-22 18:11:25.701 [INFO ] [org.openhab.binding.feed.internal.handler.FeedHandler] - Can not update channel with ID: last-update, no data has been downloaded from the server!
2018-12-22 18:11:25.701 [INFO ] [org.openhab.binding.feed.internal.handler.FeedHandler] - Can not update channel with ID: number-of-entries, no data has been downloaded from the server!
2018-12-22 18:11:25.696 [INFO ] [org.openhab.binding.feed.internal.handler.FeedHandler] - Can not update channel with ID: description, no data has been downloaded from the server!
2018-12-22 18:11:25.696 [INFO ] [org.openhab.binding.feed.internal.handler.FeedHandler] - Can not update channel with ID: author, no data has been downloaded from the server!
2018-12-22 18:11:25.697 [INFO ] [org.openhab.binding.feed.internal.handler.FeedHandler] - Can not update channel with ID: title, no data has been downloaded from the server!
2018-12-22 18:11:27.819 [ERROR] [org.eclipse.smarthome.core.thing.link.ThingLinkManager] - Exception occurred while informing handler: null
at org.openhab.binding.feed.internal.handler.FeedHandler.publishChannelIfLinked(FeedHandler.java:129) ~[?:?]
at org.openhab.binding.feed.internal.handler.FeedHandler.handleCommand(FeedHandler.java:273) ~[?:?]
at org.eclipse.smarthome.core.thing.binding.BaseThingHandler.channelLinked(BaseThingHandler.java:233) ~[?:?]
at org.eclipse.smarthome.core.thing.link.ThingLinkManager.lambda$0(ThingLinkManager.java:300) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
And occasionally see these randomly…
2018-12-23 18:12:26.329 [WARN ] [org.eclipse.smarthome.core.internal.common.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
at org.openhab.binding.feed.internal.handler.FeedHandler.refreshFeedState(FeedHandler.java:113) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) ~[?:?]
As far as I can tell, your feed has no description attributes in it, unlike the feed used by the OP.
The line where you’re getting the NPE is the line dealing with the description.
I’d also agree that the large blotto of INFO statements at startup is bad and should be avoided.
Would you raise an issue asking for these things to be fixed?
Here’s a jar that contains my planned fix if you’d like to test it out.
