@chris I installed a new OH2 build (#445) for the first time in a couple weeks. I wanted to give some feedback on a few things I’m seeing.
Let me know if I should open issues for any of these. As always, your work on this binding is outstanding, and very much appreciated!
The full debug log is large, and is located here:
https://drive.google.com/file/d/0Bwmcwu6ccTd_aUxEOXBKMzVtaGM/view?usp=sharing
I recall seeing that there was a format change to the node xml files, so I removed the old ones prior to startup.
###HABmin
Loving that I can install HABmin from the Paper UI or using addons.cfg! Nice!
Also l like the initialization status for each node in the thing list. Very helpful indeed!
###Binding
1:
I’m seeing many (about 100 for my 27 node network) of these “Controller handler not found” warnings at startup. – possibly because the thing handler is initialized before the bridge handler? Seem to be associated with REFRESH? I suppose these will go away when the thing lifecycle gets reworked…
2016-08-11 08:32:54.237 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler.
2016-08-11 08:32:54.242 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Command received zwave:device:154acc671d8:node11:switch_binary --> REFRESH
2016-08-11 08:32:54.243 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - Controller handler not found. Cannot handle command without ZWave controller.
2016-08-11 08:32:54.243 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Controller initialised.
2016-08-11 08:32:54.243 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Command received zwave:device:154acc671d8:node11:scene_number --> REFRESH
2016-08-11 08:32:54.244 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - Controller handler not found. Cannot handle command without ZWave controller.
2016-08-11 08:32:54.244 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Controller status changed to UNINITIALIZED.
2016-08-11 08:32:54.245 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Controller is not online.
2016-08-11 08:32:54.287 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler.
2016-08-11 08:32:54.298 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Controller initialised.
2016-08-11 08:32:54.301 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Controller status changed to UNINITIALIZED.
2016-08-11 08:32:54.302 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Controller is not online.
2016-08-11 08:32:54.309 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler.
2016-08-11 08:32:54.311 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Command received zwave:device:154acc671d8:node12:sensor_door --> REFRESH
2:
I’ve seen this NPE a few times. This happens on nodes 11, 15, and 22, which all are Leviton VRS05 devices. Could be due to #3 below…
2016-08-11 08:34:02.327 [ERROR] [ve.internal.protocol.ZWaveController] - Exception during ZWave thread: Input 2. {}
java.lang.NullPointerException
at org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer.advanceNodeStage(ZWaveNodeInitStageAdvancer.java:885)[174:org.openhab.binding.zwave:2.0.0.201608110102]
at org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer.handleNodeQueue(ZWaveNodeInitStageAdvancer.java:230)[174:org.openhab.binding.zwave:2.0.0.201608110102]
at org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer.ZWaveIncomingEvent(ZWaveNodeInitStageAdvancer.java:1276)[174:org.openhab.binding.zwave:2.0.0.201608110102]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.notifyEventListeners(ZWaveController.java:541)[174:org.openhab.binding.zwave:2.0.0.201608110102]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.handleIncomingRequestMessage(ZWaveController.java:244)[174:org.openhab.binding.zwave:2.0.0.201608110102]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.handleIncomingMessage(ZWaveController.java:208)[174:org.openhab.binding.zwave:2.0.0.201608110102]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.access$7(ZWaveController.java:202)[174:org.openhab.binding.zwave:2.0.0.201608110102]
at org.openhab.binding.zwave.internal.protocol.ZWaveController$ZWaveInputThread.run(ZWaveController.java:1288)[174:org.openhab.binding.zwave:2.0.0.201608110102]
3:
The Leviton VRS05 switch has 2 association groups in the zwave database. I believe I did that a while ago when I made some edits to that device. Might be causing NPE in #2 above. Could you please delete association group “GroupID 2”?
4:
I’ve not noticed this before. There appears to be a mismatch between the database and what the device reports for the BASIC command class version for the Leviton VRPD3. Should the database be updated to reflect version 0?
2016-08-11 08:34:04.916 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 17: Application Command Request (ALIVE:VERSION)
2016-08-11 08:34:04.916 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 17: Incoming command class VERSION
2016-08-11 08:34:04.916 [DEBUG] [ommandclass.ZWaveVersionCommandClass] - NODE 17: Received VERSION command V0
2016-08-11 08:34:04.916 [DEBUG] [ommandclass.ZWaveVersionCommandClass] - NODE 17: Process Version Command Class Report
2016-08-11 08:34:04.916 [DEBUG] [ommandclass.ZWaveVersionCommandClass] - NODE 17: Requested Command Class = BASIC, Version = 0
2016-08-11 08:34:04.916 [INFO ] [ommandclass.ZWaveVersionCommandClass] - NODE 17: Command Class BASIC has version 0!
2016-08-11 08:34:04.916 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 17: Version = 1, version set. Enabling extra functionality.
5:
I can now set the Polling Period for a node. Yay! What’s the maximum value? It looks like it might be 7200 seconds. I have a node (14) that’s behaving a bit flaky. Until I replace it, I was hoping to set a longer polling period.
6:
For node 14, VERSION_COMMAND_CLASS_GET is being sent with a parameter “UNKNOWN(83)”. The command is never successful. What does that mean?
Edit: Is 83 hex or decimal? There is no 0x83 command class, but there is a 0x53 (83 decimal) command class (SCHEDULE). I suppose I should do the “FORCEVERSION” thing on the SCHEDULE command class for this device?
This list got a bit longer than I had expected.
I appreciate your time looking into these questions.
