Dear,
I have this in the *.items file:
Contact GF_chickencoop_LightStatusONOFF “Het licht is: [%s]” { simatic=“plc:Q0.0” }
Switch GF_chickencoop_LightONOFF “Licht Kippenhok” [“Switchable”] {simatic=“plc:DB2.DBX0.1”,expire=“1s,command=OFF”,autoupdate=“false”}
And this in the sitemap:
Frame label=“kippenhok”{
Text item=GF_chickencoop_LightStatusONOFF icon="gate2"
Switch item=GF_chickencoop_LightONOFF icon="garage" mappings=[ON="ON/OFF"] }
Any idea why the text item isn’t updating? It constantly says closed.
Maybe there is a more simple way to check the status of GF_chickencoop_LightStatusONOFF?
Thanks!
Tom
Platform information:
Hardware: CPUArchitecture/RAM/storage
OS: what OS is used and which version
Java Runtime Environment: which java platform is used and what version
openHAB version:
Issue of the topic: please be detailed explaining your issue
Please post configurations (if applicable):
Items configuration related to the issue
Sitemap configuration related to the issue
Rules code related to the issue
Services configuration related to the issue
If logs where generated please post these here using code fences:
Dear,
I just discovered that everything is working fine. BUT i have to manually refresh the website with F5…
Is there an option to refresh everything x time or on change?
Thanks,
tom.
If it is a sitemap based UI like BasicUI, have you looked in your openhab.log for any messages related to your sitemap? You should find at least a “loaded” message at boot or editing time.
I use basic UI.
I found this in the logs:
Location set to ‘50.764446,3.4187619999999996’.
2020-01-21 19:31:13.088 [WARN ] [g.eclipse.smarthome.core.net.NetUtil] - Found multiple local interfaces - ignoring 192.168.11.1
2020-01-21 19:31:13.141 [WARN ] [g.eclipse.smarthome.core.net.NetUtil] - Found multiple local interfaces - ignoring 192.168.56.1
2020-01-21 19:31:15.351 [WARN ] [g.eclipse.smarthome.core.net.NetUtil] - Found multiple local interfaces - ignoring 192.168.11.1
2020-01-21 19:31:15.412 [WARN ] [g.eclipse.smarthome.core.net.NetUtil] - Found multiple local interfaces - ignoring 192.168.56.1
2020-01-21 19:31:19.060 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘default.items’
2020-01-21 19:31:19.428 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘default.sitemap’
2020-01-21 19:31:20.594 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2020-01-21 19:31:21.202 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.86.57:8080
2020-01-21 19:31:21.202 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.86.57:8443
2020-01-21 19:31:21.460 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
2020-01-21 19:31:21.523 [INFO ] [openhab.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2020-01-21 19:31:21.617 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2020-01-21 19:31:21.713 [INFO ] [rt.modbus.internal.ModbusManagerImpl] - Modbus manager activated
2020-01-21 19:31:21.796 [DEBUG] [ng.simatic.internal.SimaticActivator] - Simatic binding has been started (v.1.2.0).
That’s good; people frequently mess up the filename part (which would produce an error log) and are mystified when it “works” but doesn’t refresh. So that is ruled out.
If you’re on Windows, try another browser. Some work better than others.
