Database update has been performed, you need to update to the latest snapshot zwave binding:
or if you are using the development branch wait until the next update is published.
Thank you!
Installed last zwave snapshot on stable OH2.1 but there is no new features in binding after reinitialization.
/opt/openhab2/conf # ls ../addons root@openhab
org.openhab.binding.zwave-2.2.0-SNAPSHOT.jar org.openhab.ui.iconset.climacons-2.0.0-SNAPSHOT.jar README
2017-07-15 00:32:27.337 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Initialising Thing Node...
2017-07-15 00:32:27.338 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Initialising channel zwave:device:15bbe728e21:node4:switch_dimmer
2017-07-15 00:32:27.339 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Initialising cmd channel zwave:device:15bbe728e21:node4:switch_dimmer
2017-07-15 00:32:27.339 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Initialising poll channel zwave:device:15bbe728e21:node4:switch_dimmer
2017-07-15 00:32:27.340 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Initialising cmd channel zwave:device:15bbe728e21:node4:switch_dimmer
2017-07-15 00:32:27.340 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Initialising poll channel zwave:device:15bbe728e21:node4:switch_dimmer
2017-07-15 00:32:27.342 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Initialising state channel zwave:device:15bbe728e21:node4:switch_dimmer
2017-07-15 00:32:27.343 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Initialising state channel zwave:device:15bbe728e21:node4:switch_dimmer
2017-07-15 00:32:27.345 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Initialising channel zwave:device:15bbe728e21:node4:scene_number
2017-07-15 00:32:27.346 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Initialising cmd channel zwave:device:15bbe728e21:node4:scene_number
2017-07-15 00:32:27.346 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Initialising poll channel zwave:device:15bbe728e21:node4:scene_number
2017-07-15 00:32:27.347 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Initialising state channel zwave:device:15bbe728e21:node4:scene_number
Did you delete the thing and add it back again? If not, you will still have the old definition - ESH won’t update the thing definition automatically.
Thx. all works fine now but I can’t send parameter from Slider (Dimmer) like in oh1.8. Now it works only if I use Number item.
