Hi, @chris
My flood sensor is not reporting battery level. Default wake up is 4000 as per manufacturer but no wake up is happening. No logs for wake up command class.
Any idea…?
Thanks,
Shrikant
Hi, @chris
Any idea…?
Thanks,
Shrikant
Chris can’t help much without your Z-Wave debug logs to give him some clues. He has built a very clever log analysis tools to help him with these sorts of queries (of which he gets many!). Please post your logs showing the binding starting up and probably another 12 hours worth of operation to see if there is any activity from the flood sensor.
ok…
can i send logs only related to that flood sensor node only . i grep that much logs only
@chris
These are my logs:
zwave binding version: 1.8.2
wake up interval is 300 seconds, configure using fibaro home center.
14:00:28.923 [INFO ] [rialApiGetInitDataMessageClass:57 ] - NODE 55: Node found 14:00:28.941 [DEBUG] [b.z.i.protocol.ZWaveController:493 ] - NODE 55: Init node thread start 14:00:29.218 [DEBUG] [.b.z.i.p.i.ZWaveNodeSerializer:138 ] - NODE 55: Serializing from file etc/zwave/node55.xml 14:00:29.413 [DEBUG] [b.z.i.protocol.ZWaveController:529 ] - NODE 55: Restore from config: Ok. 14:00:29.431 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:269 ] - NODE 55: Node advancer - EMPTYNODE: queue length(0), free to send(true) 14:00:29.431 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:335 ] - NODE 55: Node advancer: loop - EMPTYNODE try 1: stageAdvanced(false) 14:00:29.432 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:340 ] - NODE 55: Node advancer: Initialisation starting 14:00:29.432 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:868 ] - NODE 55: Node advancer - advancing to PROTOINFO 14:00:29.432 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:335 ] - NODE 55: Node advancer: loop - PROTOINFO try 0: stageAdvanced(true) 14:00:29.433 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:349 ] - NODE 55: Node advancer: PROTOINFO - send IdentifyNode 14:00:29.450 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:242 ] - NODE 55: Node advancer - queued packet. Queue length is 1 14:00:29.451 [DEBUG] [b.z.i.protocol.ZWaveController:585 ] - NODE 55: Init node thread finished 14:00:29.517 [DEBUG] [i.p.s.IdentifyNodeMessageClass:52 ] - NODE 55: ProtocolInfo 14:00:29.517 [DEBUG] [i.p.s.IdentifyNodeMessageClass:68 ] - NODE 55: Listening = false 14:00:29.517 [DEBUG] [i.p.s.IdentifyNodeMessageClass:69 ] - NODE 55: Routing = true 14:00:29.518 [DEBUG] [i.p.s.IdentifyNodeMessageClass:70 ] - NODE 55: Beaming = true 14:00:29.518 [DEBUG] [i.p.s.IdentifyNodeMessageClass:71 ] - NODE 55: Version = 4 14:00:29.518 [DEBUG] [i.p.s.IdentifyNodeMessageClass:72 ] - NODE 55: FLIRS = false 14:00:29.518 [DEBUG] [i.p.s.IdentifyNodeMessageClass:73 ] - NODE 55: Security = false 14:00:29.518 [DEBUG] [i.p.s.IdentifyNodeMessageClass:74 ] - NODE 55: Max Baud = 40000 14:00:29.518 [DEBUG] [i.p.s.IdentifyNodeMessageClass:89 ] - NODE 55: Basic = Routing Slave 14:00:29.518 [DEBUG] [i.p.s.IdentifyNodeMessageClass:96 ] - NODE 55: Generic = Alarm Sensor 14:00:29.519 [DEBUG] [i.p.s.IdentifyNodeMessageClass:103 ] - NODE 55: Specific = Routing Alarm Sensor 14:00:29.519 [DEBUG] [.o.b.z.i.p.c.ZWaveCommandClass:225 ] - NODE 55: Creating new instance of command class NO_OPERATION 14:00:29.519 [DEBUG] [.o.b.z.i.p.c.ZWaveCommandClass:225 ] - NODE 55: Creating new instance of command class BASIC 14:00:29.519 [DEBUG] [.o.b.z.i.p.c.ZWaveCommandClass:225 ] - NODE 55: Creating new instance of command class SENSOR_ALARM 14:00:29.520 [DEBUG] [.o.b.z.i.p.c.ZWaveCommandClass:225 ] - NODE 55: Creating new instance of command class MANUFACTURER_SPECIFIC 14:00:29.520 [DEBUG] [.o.b.z.i.p.c.ZWaveCommandClass:225 ] - NODE 55: Creating new instance of command class BATTERY 14:00:29.520 [DEBUG] [.o.b.z.i.p.c.ZWaveCommandClass:225 ] - NODE 55: Creating new instance of command class ASSOCIATION 14:00:29.520 [DEBUG] [.o.b.z.i.p.c.ZWaveCommandClass:225 ] - NODE 55: Creating new instance of command class VERSION 14:00:29.522 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1013 ] - NODE 55: Node advancer - PROTOINFO: Transaction complete (IdentifyNode:Request) success(true) 14:00:29.522 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:203 ] - NODE 55: Node advancer - checking initialisation queue. Queue size 1. 14:00:29.522 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:209 ] - NODE 55: Node advancer - message removed from queue. Queue size 0. 14:00:29.523 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:269 ] - NODE 55: Node advancer - PROTOINFO: queue length(0), free to send(true) 14:00:29.527 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:335 ] - NODE 55: Node advancer: loop - PROTOINFO try 1: stageAdvanced(false) 14:00:29.528 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:868 ] - NODE 55: Node advancer - advancing to NEIGHBORS 14:00:29.529 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:335 ] - NODE 55: Node advancer: loop - NEIGHBORS try 0: stageAdvanced(true) 14:00:29.529 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:359 ] - NODE 55: Node advancer: NEIGHBORS - send RoutingInfo 14:00:29.530 [DEBUG] [p.s.GetRoutingInfoMessageClass:29 ] - NODE 55: Request routing info 14:00:29.535 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:242 ] - NODE 55: Node advancer - queued packet. Queue length is 1 14:00:29.591 [DEBUG] [p.s.GetRoutingInfoMessageClass:47 ] - NODE 55: Got NodeRoutingInfo request. 14:00:29.592 [DEBUG] [p.s.GetRoutingInfoMessageClass:78 ] - NODE 55: Neighbor nodes: 1 14:00:29.597 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1013 ] - NODE 55: Node advancer - NEIGHBORS: Transaction complete (GetRoutingInfo:Request) success(true) 14:00:29.597 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:203 ] - NODE 55: Node advancer - checking initialisation queue. Queue size 1. 14:00:29.599 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:209 ] - NODE 55: Node advancer - message removed from queue. Queue size 0. 14:00:29.600 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:269 ] - NODE 55: Node advancer - NEIGHBORS: queue length(0), free to send(true) 14:00:29.600 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:335 ] - NODE 55: Node advancer: loop - NEIGHBORS try 1: stageAdvanced(false) 14:00:29.600 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:868 ] - NODE 55: Node advancer - advancing to FAILED_CHECK 14:00:29.600 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:335 ] - NODE 55: Node advancer: loop - FAILED_CHECK try 0: stageAdvanced(true) 14:00:29.601 [DEBUG] [i.p.s.IsFailedNodeMessageClass:31 ] - NODE 55: Requesting IsFailedNode status from controller. 14:00:29.601 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:242 ] - NODE 55: Node advancer - queued packet. Queue length is 1 14:00:29.635 [DEBUG] [i.p.s.IsFailedNodeMessageClass:54 ] - NODE 55: Is currently marked as healthy by the controller 14:00:29.636 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1013 ] - NODE 55: Node advancer - FAILED_CHECK: Transaction complete (IsFailedNodeID:Request) success(true) 14:00:29.636 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:203 ] - NODE 55: Node advancer - checking initialisation queue. Queue size 1. 14:00:29.636 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:209 ] - NODE 55: Node advancer - message removed from queue. Queue size 0. 14:00:29.636 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:269 ] - NODE 55: Node advancer - FAILED_CHECK: queue length(0), free to send(true) 14:00:29.637 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:335 ] - NODE 55: Node advancer: loop - FAILED_CHECK try 1: stageAdvanced(false) 14:00:29.637 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:868 ] - NODE 55: Node advancer - advancing to WAIT 14:00:29.637 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:335 ] - NODE 55: Node advancer: loop - WAIT try 0: stageAdvanced(true) 14:00:29.637 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:382 ] - NODE 55: Node advancer: WAIT - Listening=false, FrequentlyListening=false 14:00:29.637 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:400 ] - NODE 55: Node advancer: WAIT - Still waiting! 14:00:30.992 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:999 ] - NODE 55: Node advancer - WAIT: The WAIT is over! 14:00:30.992 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:203 ] - NODE 55: Node advancer - checking initialisation queue. Queue size 0. 14:00:31.873 [DEBUG] [.z.internal.ZWaveActiveBinding:192 ] - NODE 55: Polling list: item BATTERY_55 is not completed initialisation 14:00:31.874 [DEBUG] [.z.internal.ZWaveActiveBinding:192 ] - NODE 55: Polling list: item SENSOR_FLood_55 is not completed initialisation 14:00:31.874 [DEBUG] [.z.internal.ZWaveActiveBinding:192 ] - NODE 55: Polling list: item BATTERY_55 is not completed initialisation 14:03:12.822 [DEBUG] [ApplicationCommandMessageClass:38 ] - NODE 55: Application Command Request (ALIVE:PING) 14:03:12.823 [DEBUG] [ApplicationCommandMessageClass:56 ] - NODE 55: Incoming command class WAKE_UP 14:03:12.823 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:136 ] - NODE 55: Received Wake Up Request 14:03:12.823 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:182 ] - NODE 55: Received WAKE_UP_NOTIFICATION 14:03:12.824 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:411 ] - NODE 55: Is awake with 0 messages in the wake-up queue. 14:03:12.825 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1036 ] - NODE 55: Wakeup during initialisation. 14:03:12.825 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:269 ] - NODE 55: Node advancer - PING: queue length(0), free to send(true) 14:03:12.825 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:335 ] - NODE 55: Node advancer: loop - PING try 1: stageAdvanced(false) 14:03:12.826 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:419 ] - NODE 55: Node advancer: PING - send NoOperation 14:03:12.826 [DEBUG] [c.ZWaveNoOperationCommandClass:72 ] - NODE 55: Creating new message for command No Operation 14:03:12.826 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ] - NODE 55: Creating empty message of class = SendData (0x13), type = Request (0x00) 14:03:12.828 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:242 ] - NODE 55: Node advancer - queued packet. Queue length is 1 14:03:12.829 [DEBUG] [WaveController$ZWaveSendThread:1268 ] - NODE 55: Sending REQUEST Message = 01 08 00 13 37 01 00 25 0F F8 14:03:12.838 [DEBUG] [b.z.i.p.s.SendDataMessageClass:38 ] - NODE 55: Sent Data successfully placed on stack. 14:03:12.856 [DEBUG] [b.z.i.p.s.SendDataMessageClass:74 ] - NODE 55: SendData Request. CallBack ID = 15, Status = Transmission complete and ACK received(0) 14:03:12.859 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1013 ] - NODE 55: Node advancer - PING: Transaction complete (SendData:Request) success(true) 14:03:12.859 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:203 ] - NODE 55: Node advancer - checking initialisation queue. Queue size 1. 14:03:12.859 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:209 ] - NODE 55: Node advancer - message removed from queue. Queue size 0. 14:03:12.860 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:269 ] - NODE 55: Node advancer - PING: queue length(0), free to send(true) 14:03:12.860 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:335 ] - NODE 55: Node advancer: loop - PING try 2: stageAdvanced(false) 14:03:12.860 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:868 ] - NODE 55: Node advancer - advancing to DETAILS 14:03:12.860 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:335 ] - NODE 55: Node advancer: loop - DETAILS try 0: stageAdvanced(true) 14:03:12.860 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:437 ] - NODE 55: Node advancer: Restored from file - skipping static initialisation 14:03:12.861 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:868 ] - NODE 55: Node advancer - advancing to DYNAMIC_VALUES 14:03:12.861 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:335 ] - NODE 55: Node advancer: loop - DYNAMIC_VALUES try 0: stageAdvanced(true) 14:03:12.861 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:781 ] - NODE 55: Node advancer: DYNAMIC_VALUES - checking BATTERY 14:03:12.861 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:784 ] - NODE 55: Node advancer: DYNAMIC_VALUES - found BATTERY 14:03:12.862 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:788 ] - NODE 55: Found 1 instances of BATTERY 14:03:12.862 [DEBUG] [i.p.c.ZWaveBatteryCommandClass:137 ] - NODE 55: Creating new message for application command BATTERY_GET 14:03:12.862 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ] - NODE 55: Creating empty message of class = SendData (0x13), type = Request (0x00) 14:03:12.862 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:781 ] - NODE 55: Node advancer: DYNAMIC_VALUES - checking SENSOR_BINARY 14:03:12.863 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:784 ] - NODE 55: Node advancer: DYNAMIC_VALUES - found SENSOR_BINARY 14:03:12.863 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:788 ] - NODE 55: Found 1 instances of SENSOR_BINARY 14:03:12.863 [DEBUG] [.ZWaveBinarySensorCommandClass:128 ] - NODE 55: Creating new message for application command SENSOR_BINARY_GET 14:03:12.863 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ] - NODE 55: Creating empty message of class = SendData (0x13), type = Request (0x00) 14:03:12.864 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:781 ] - NODE 55: Node advancer: DYNAMIC_VALUES - checking SENSOR_ALARM 14:03:12.864 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:784 ] - NODE 55: Node advancer: DYNAMIC_VALUES - found SENSOR_ALARM 14:03:12.864 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:788 ] - NODE 55: Found 1 instances of SENSOR_ALARM 14:03:12.865 [DEBUG] [c.ZWaveAlarmSensorCommandClass:284 ] - NODE 55: ====---- Checking alarm GENERAL - init false 14:03:12.865 [DEBUG] [c.ZWaveAlarmSensorCommandClass:209 ] - NODE 55: Creating new message for command SENSOR_ALARM_GET, type General 14:03:12.865 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ] - NODE 55: Creating empty message of class = SendData (0x13), type = Request (0x00) 14:03:12.865 [DEBUG] [c.ZWaveAlarmSensorCommandClass:284 ] - NODE 55: ====---- Checking alarm FLOOD - init false 14:03:12.865 [DEBUG] [c.ZWaveAlarmSensorCommandClass:209 ] - NODE 55: Creating new message for command SENSOR_ALARM_GET, type Flood 14:03:12.866 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ] - NODE 55: Creating empty message of class = SendData (0x13), type = Request (0x00) 14:03:12.866 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:781 ] - NODE 55: Node advancer: DYNAMIC_VALUES - checking WAKE_UP 14:03:12.866 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:781 ] - NODE 55: Node advancer: DYNAMIC_VALUES - checking MANUFACTURER_SPECIFIC 14:03:12.866 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:781 ] - NODE 55: Node advancer: DYNAMIC_VALUES - checking NO_OPERATION 14:03:12.866 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:781 ] - NODE 55: Node advancer: DYNAMIC_VALUES - checking MULTI_INSTANCE 14:03:12.867 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:802 ] - NODE 55: Node advancer: DYNAMIC_VALUES - checking SENSOR_BINARY for endpoint 1 14:03:12.867 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:806 ] - NODE 55: Node advancer: DYNAMIC_VALUES - found SENSOR_BINARY 14:03:12.867 [DEBUG] [.ZWaveBinarySensorCommandClass:128 ] - NODE 55: Creating new message for application command SENSOR_BINARY_GET 14:03:12.867 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ] - NODE 55: Creating empty message of class = SendData (0x13), type = Request (0x00) 14:03:12.867 [DEBUG] [.z.internal.protocol.ZWaveNode:671 ] - NODE 55: Encapsulating message, instance / endpoint 1 14:03:12.868 [DEBUG] [ZWaveMultiInstanceCommandClass:560 ] - NODE 55: Creating new message for command MULTI_CHANNEL_ENCAP endpoint 1 14:03:12.868 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:802 ] - NODE 55: Node advancer: DYNAMIC_VALUES - checking BASIC for endpoint 1 14:03:12.868 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:802 ] - NODE 55: Node advancer: DYNAMIC_VALUES - checking SENSOR_MULTILEVEL for endpoint 2 14:03:12.868 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:806 ] - NODE 55: Node advancer: DYNAMIC_VALUES - found SENSOR_MULTILEVEL 14:03:12.869 [DEBUG] [veMultiLevelSensorCommandClass:205 ] - NODE 55: Creating new message for command SENSOR_MULTI_LEVEL_GET 14:03:12.869 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ] - NODE 55: Creating empty message of class = SendData (0x13), type = Request (0x00) 14:03:12.869 [DEBUG] [.z.internal.protocol.ZWaveNode:671 ] - NODE 55: Encapsulating message, instance / endpoint 2 14:03:12.869 [DEBUG] [ZWaveMultiInstanceCommandClass:560 ] - NODE 55: Creating new message for command MULTI_CHANNEL_ENCAP endpoint 2 14:03:12.870 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:802 ] - NODE 55: Node advancer: DYNAMIC_VALUES - checking BASIC for endpoint 2 14:03:12.870 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:781 ] - NODE 55: Node advancer: DYNAMIC_VALUES - checking VERSION 14:03:12.870 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:781 ] - NODE 55: Node advancer: DYNAMIC_VALUES - checking ASSOCIATION 14:03:12.870 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:781 ] - NODE 55: Node advancer: DYNAMIC_VALUES - checking BASIC 14:03:12.870 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:781 ] - NODE 55: Node advancer: DYNAMIC_VALUES - checking CONFIGURATION 14:03:12.870 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:816 ] - NODE 55: Node advancer: DYNAMIC_VALUES - queued 6 frames 14:03:12.871 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:242 ] - NODE 55: Node advancer - queued packet. Queue length is 6 14:03:12.871 [DEBUG] [WaveController$ZWaveSendThread:1327 ] - NODE 55: Response processed after 42ms/4176ms. 14:03:12.872 [DEBUG] [WaveController$ZWaveSendThread:1268 ] - NODE 55: Sending REQUEST Message = 01 09 00 13 37 02 80 02 25 10 67 14:03:12.880 [DEBUG] [b.z.i.p.s.SendDataMessageClass:38 ] - NODE 55: Sent Data successfully placed on stack. 14:03:12.900 [DEBUG] [b.z.i.p.s.SendDataMessageClass:74 ] - NODE 55: SendData Request. CallBack ID = 16, Status = Transmission complete and ACK received(0)
14:03:12.911 [DEBUG] [ApplicationCommandMessageClass:38 ] - NODE 55: Application Command Request (ALIVE:DYNAMIC_VALUES) 14:03:12.911 [DEBUG] [ApplicationCommandMessageClass:56 ] - NODE 55: Incoming command class BATTERY 14:03:12.912 [DEBUG] [i.p.c.ZWaveBatteryCommandClass:81 ] - NODE 55: Received Battery Request 14:03:12.912 [DEBUG] [i.p.c.ZWaveBatteryCommandClass:96 ] - NODE 55: Battery report value = 40 14:03:12.913 [DEBUG] [.z.internal.ZWaveActiveBinding:450 ] - NODE 55: Got a value event from Z-Wave network, endpoint = 0, command class = BATTERY, value = 40 14:03:12.921 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1013 ] - NODE 55: Node advancer - DYNAMIC_VALUES: Transaction complete (SendData:Request) success(true) 14:03:12.921 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:203 ] - NODE 55: Node advancer - checking initialisation queue. Queue size 6. 14:03:12.921 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:209 ] - NODE 55: Node advancer - message removed from queue. Queue size 5. 14:03:12.922 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:269 ] - NODE 55: Node advancer - DYNAMIC_VALUES: queue length(5), free to send(true) 14:03:12.922 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:242 ] - NODE 55: Node advancer - queued packet. Queue length is 5 14:03:12.922 [DEBUG] [WaveController$ZWaveSendThread:1327 ] - NODE 55: Response processed after 50ms/4176ms. 14:03:12.923 [DEBUG] [WaveController$ZWaveSendThread:1268 ] - NODE 55: Sending REQUEST Message = 01 09 00 13 37 02 30 02 25 11 D6 14:03:12.932 [DEBUG] [b.z.i.p.s.SendDataMessageClass:38 ] - NODE 55: Sent Data successfully placed on stack. 14:03:12.952 [DEBUG] [b.z.i.p.s.SendDataMessageClass:74 ] - NODE 55: SendData Request. CallBack ID = 17, Status = Transmission complete and ACK received(0) 14:03:12.960 [DEBUG] [ApplicationCommandMessageClass:38 ] - NODE 55: Application Command Request (ALIVE:DYNAMIC_VALUES) 14:03:12.961 [DEBUG] [ApplicationCommandMessageClass:56 ] - NODE 55: Incoming command class SENSOR_BINARY 14:03:12.961 [DEBUG] [.ZWaveBinarySensorCommandClass:82 ] - NODE 55: Received Sensor Binary Request (v1) 14:03:12.961 [DEBUG] [.ZWaveBinarySensorCommandClass:102 ] - NODE 55: Sensor Binary report, type=Unknown, value=0 14:03:12.962 [DEBUG] [.z.internal.ZWaveActiveBinding:450 ] - NODE 55: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_BINARY, value = 0 14:03:12.966 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1013 ] - NODE 55: Node advancer - DYNAMIC_VALUES: Transaction complete (SendData:Request) success(true) 14:03:12.967 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:203 ] - NODE 55: Node advancer - checking initialisation queue. Queue size 5. 14:03:12.967 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:209 ] - NODE 55: Node advancer - message removed from queue. Queue size 4. 14:03:12.967 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:269 ] - NODE 55: Node advancer - DYNAMIC_VALUES: queue length(4), free to send(true) 14:03:12.968 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:242 ] - NODE 55: Node advancer - queued packet. Queue length is 4 14:03:12.969 [DEBUG] [WaveController$ZWaveSendThread:1327 ] - NODE 55: Response processed after 46ms/4176ms. 14:03:12.970 [DEBUG] [WaveController$ZWaveSendThread:1268 ] - NODE 55: Sending REQUEST Message = 01 0A 00 13 37 03 9C 01 00 25 12 78 14:03:12.983 [DEBUG] [b.z.i.p.s.SendDataMessageClass:38 ] - NODE 55: Sent Data successfully placed on stack. 14:03:12.997 [DEBUG] [b.z.i.p.s.SendDataMessageClass:74 ] - NODE 55: SendData Request. CallBack ID = 18, Status = Transmission complete and ACK received(0) 14:03:13.007 [DEBUG] [ApplicationCommandMessageClass:38 ] - NODE 55: Application Command Request (ALIVE:DYNAMIC_VALUES) 14:03:13.007 [DEBUG] [ApplicationCommandMessageClass:56 ] - NODE 55: Incoming command class SENSOR_ALARM 14:03:13.008 [DEBUG] [c.ZWaveAlarmSensorCommandClass:85 ] - NODE 55: Received Sensor Alarm Request 14:03:13.008 [DEBUG] [c.ZWaveAlarmSensorCommandClass:104 ] - NODE 55: Alarm Report: Source=55, Type=General(0), Value=255 14:03:13.009 [DEBUG] [.z.internal.ZWaveActiveBinding:450 ] - NODE 55: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_ALARM, value = 255 14:03:13.013 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1013 ] - NODE 55: Node advancer - DYNAMIC_VALUES: Transaction complete (SendData:Request) success(true) 14:03:13.014 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:203 ] - NODE 55: Node advancer - checking initialisation queue. Queue size 4. 14:03:13.014 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:209 ] - NODE 55: Node advancer - message removed from queue. Queue size 3. 14:03:13.014 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:269 ] - NODE 55: Node advancer - DYNAMIC_VALUES: queue length(3), free to send(true) 14:03:13.014 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:242 ] - NODE 55: Node advancer - queued packet. Queue length is 3 14:03:13.015 [DEBUG] [WaveController$ZWaveSendThread:1327 ] - NODE 55: Response processed after 45ms/4176ms. 14:03:13.015 [DEBUG] [WaveController$ZWaveSendThread:1268 ] - NODE 55: Sending REQUEST Message = 01 0A 00 13 37 03 9C 01 05 25 13 7C 14:03:13.025 [DEBUG] [b.z.i.p.s.SendDataMessageClass:38 ] - NODE 55: Sent Data successfully placed on stack. 14:03:13.042 [DEBUG] [b.z.i.p.s.SendDataMessageClass:74 ] - NODE 55: SendData Request. CallBack ID = 19, Status = Transmission complete and ACK received(0) 14:03:13.053 [DEBUG] [ApplicationCommandMessageClass:38 ] - NODE 55: Application Command Request (ALIVE:DYNAMIC_VALUES) 14:03:13.053 [DEBUG] [ApplicationCommandMessageClass:56 ] - NODE 55: Incoming command class SENSOR_ALARM 14:03:13.054 [DEBUG] [c.ZWaveAlarmSensorCommandClass:85 ] - NODE 55: Received Sensor Alarm Request 14:03:13.054 [DEBUG] [c.ZWaveAlarmSensorCommandClass:104 ] - NODE 55: Alarm Report: Source=55, Type=Flood(5), Value=0 14:03:13.054 [DEBUG] [.z.internal.ZWaveActiveBinding:450 ] - NODE 55: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_ALARM, value = 0 14:03:13.056 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1013 ] - NODE 55: Node advancer - DYNAMIC_VALUES: Transaction complete (SendData:Request) success(true) 14:03:13.056 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:203 ] - NODE 55: Node advancer - checking initialisation queue. Queue size 3. 14:03:13.056 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:209 ] - NODE 55: Node advancer - message removed from queue. Queue size 2. 14:03:13.057 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:269 ] - NODE 55: Node advancer - DYNAMIC_VALUES: queue length(2), free to send(true) 14:03:13.057 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:242 ] - NODE 55: Node advancer - queued packet. Queue length is 2 14:03:13.057 [DEBUG] [WaveController$ZWaveSendThread:1327 ] - NODE 55: Response processed after 42ms/4176ms. 14:03:13.058 [DEBUG] [WaveController$ZWaveSendThread:1268 ] - NODE 55: Sending REQUEST Message = 01 0D 00 13 37 06 60 0D 01 01 30 02 25 14 BE 14:03:13.067 [DEBUG] [b.z.i.p.s.SendDataMessageClass:38 ] - NODE 55: Sent Data successfully placed on stack. 14:03:13.087 [DEBUG] [b.z.i.p.s.SendDataMessageClass:74 ] - NODE 55: SendData Request. CallBack ID = 20, Status = Transmission complete and ACK received(0) 14:03:13.097 [DEBUG] [ApplicationCommandMessageClass:38 ] - NODE 55: Application Command Request (ALIVE:DYNAMIC_VALUES) 14:03:13.097 [DEBUG] [ApplicationCommandMessageClass:56 ] - NODE 55: Incoming command class MULTI_INSTANCE 14:03:13.098 [DEBUG] [ZWaveMultiInstanceCommandClass:145 ] - NODE 55: Received Multi-instance/Multi-channel Request 14:03:13.098 [DEBUG] [ZWaveMultiInstanceCommandClass:452 ] - NODE 55: Requested Command Class = SENSOR_BINARY (0x30) 14:03:13.099 [DEBUG] [ZWaveMultiInstanceCommandClass:472 ] - NODE 55: Endpoint = 1, calling handleApplicationCommandRequest. 14:03:13.099 [DEBUG] [.ZWaveBinarySensorCommandClass:82 ] - NODE 55: Received Sensor Binary Request (v1) 14:03:13.100 [DEBUG] [.ZWaveBinarySensorCommandClass:102 ] - NODE 55: Sensor Binary report, type=Unknown, value=0 14:03:13.102 [DEBUG] [.z.internal.ZWaveActiveBinding:450 ] - NODE 55: Got a value event from Z-Wave network, endpoint = 1, command class = SENSOR_BINARY, value = 0 14:03:13.103 [WARN ] [.z.internal.ZWaveActiveBinding:467 ] - NODE 55: No item bound for event, endpoint = 1, command class = SENSOR_BINARY, value = 0, ignoring. 14:03:13.104 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1013 ] - NODE 55: Node advancer - DYNAMIC_VALUES: Transaction complete (SendData:Request) success(true) 14:03:13.105 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:203 ] - NODE 55: Node advancer - checking initialisation queue. Queue size 2. 14:03:13.105 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:209 ] - NODE 55: Node advancer - message removed from queue. Queue size 1. 14:03:13.105 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:269 ] - NODE 55: Node advancer - DYNAMIC_VALUES: queue length(1), free to send(true) 14:03:13.106 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:242 ] - NODE 55: Node advancer - queued packet. Queue length is 1 14:03:13.107 [DEBUG] [WaveController$ZWaveSendThread:1327 ] - NODE 55: Response processed after 49ms/4176ms. 14:03:13.108 [DEBUG] [WaveController$ZWaveSendThread:1268 ] - NODE 55: Sending REQUEST Message = 01 0D 00 13 37 06 60 0D 01 02 31 04 25 15 BB 14:03:13.117 [DEBUG] [b.z.i.p.s.SendDataMessageClass:38 ] - NODE 55: Sent Data successfully placed on stack. 14:03:13.138 [DEBUG] [b.z.i.p.s.SendDataMessageClass:74 ] - NODE 55: SendData Request. CallBack ID = 21, Status = Transmission complete and ACK received(0) 14:03:13.149 [DEBUG] [ApplicationCommandMessageClass:38 ] - NODE 55: Application Command Request (ALIVE:DYNAMIC_VALUES) 14:03:13.150 [DEBUG] [ApplicationCommandMessageClass:56 ] - NODE 55: Incoming command class MULTI_INSTANCE 14:03:13.150 [DEBUG] [ZWaveMultiInstanceCommandClass:145 ] - NODE 55: Received Multi-instance/Multi-channel Request 14:03:13.150 [DEBUG] [ZWaveMultiInstanceCommandClass:452 ] - NODE 55: Requested Command Class = SENSOR_MULTILEVEL (0x31) 14:03:13.150 [DEBUG] [ZWaveMultiInstanceCommandClass:472 ] - NODE 55: Endpoint = 2, calling handleApplicationCommandRequest. 14:03:13.151 [DEBUG] [veMultiLevelSensorCommandClass:97 ] - NODE 55: Received Sensor Multi Level Request 14:03:13.151 [DEBUG] [veMultiLevelSensorCommandClass:131 ] - NODE 55: Sensor Multi Level REPORT received 14:03:13.151 [DEBUG] [veMultiLevelSensorCommandClass:141 ] - NODE 55: Sensor Type = Temperature(1), Scale = 0 14:03:13.168 [DEBUG] [veMultiLevelSensorCommandClass:150 ] - NODE 55: Sensor Value = 27.92 14:03:13.169 [DEBUG] [.z.internal.ZWaveActiveBinding:450 ] - NODE 55: Got a value event from Z-Wave network, endpoint = 2, command class = SENSOR_MULTILEVEL, value = 27.92 14:03:13.169 [WARN ] [.z.internal.ZWaveActiveBinding:467 ] - NODE 55: No item bound for event, endpoint = 2, command class = SENSOR_MULTILEVEL, value = 27.92, ignoring. 14:03:13.171 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1013 ] - NODE 55: Node advancer - DYNAMIC_VALUES: Transaction complete (SendData:Request) success(true) 14:03:13.171 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:203 ] - NODE 55: Node advancer - checking initialisation queue. Queue size 1. 14:03:13.171 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:209 ] - NODE 55: Node advancer - message removed from queue. Queue size 0. 14:03:13.171 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:269 ] - NODE 55: Node advancer - DYNAMIC_VALUES: queue length(0), free to send(true) 14:03:13.171 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:335 ] - NODE 55: Node advancer: loop - DYNAMIC_VALUES try 1: stageAdvanced(false) 14:03:13.171 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:781 ] - NODE 55: Node advancer: DYNAMIC_VALUES - checking BATTERY 14:03:13.171 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:784 ] - NODE 55: Node advancer: DYNAMIC_VALUES - found BATTERY 14:03:13.172 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:788 ] - NODE 55: Found 1 instances of BATTERY 14:03:13.172 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:781 ] - NODE 55: Node advancer: DYNAMIC_VALUES - checking SENSOR_BINARY 14:03:13.172 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:784 ] - NODE 55: Node advancer: DYNAMIC_VALUES - found SENSOR_BINARY 14:03:13.172 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:788 ] - NODE 55: Found 1 instances of SENSOR_BINARY 14:03:13.172 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:781 ] - NODE 55: Node advancer: DYNAMIC_VALUES - checking SENSOR_ALARM 14:03:13.172 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:784 ] - NODE 55: Node advancer: DYNAMIC_VALUES - found SENSOR_ALARM 14:03:13.172 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:788 ] - NODE 55: Found 1 instances of SENSOR_ALARM 14:03:13.173 [DEBUG] [c.ZWaveAlarmSensorCommandClass:284 ] - NODE 55: ====---- Checking alarm GENERAL - init true 14:03:13.173 [DEBUG] [c.ZWaveAlarmSensorCommandClass:284 ] - NODE 55: ====---- Checking alarm FLOOD - init true 14:03:13.173 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:781 ] - NODE 55: Node advancer: DYNAMIC_VALUES - checking WAKE_UP 14:03:13.173 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:781 ] - NODE 55: Node advancer: DYNAMIC_VALUES - checking MANUFACTURER_SPECIFIC 14:03:13.173 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:781 ] - NODE 55: Node advancer: DYNAMIC_VALUES - checking NO_OPERATION 14:03:13.173 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:781 ] - NODE 55: Node advancer: DYNAMIC_VALUES - checking MULTI_INSTANCE 14:03:13.174 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:802 ] - NODE 55: Node advancer: DYNAMIC_VALUES - checking SENSOR_BINARY for endpoint 1 14:03:13.174 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:806 ] - NODE 55: Node advancer: DYNAMIC_VALUES - found SENSOR_BINARY 14:03:13.174 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:802 ] - NODE 55: Node advancer: DYNAMIC_VALUES - checking BASIC for endpoint 1 14:03:13.174 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:802 ] - NODE 55: Node advancer: DYNAMIC_VALUES - checking SENSOR_MULTILEVEL for endpoint 2 14:03:13.174 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:806 ] - NODE 55: Node advancer: DYNAMIC_VALUES - found SENSOR_MULTILEVEL 14:03:13.175 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:802 ] - NODE 55: Node advancer: DYNAMIC_VALUES - checking BASIC for endpoint 2 14:03:13.175 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:781 ] - NODE 55: Node advancer: DYNAMIC_VALUES - checking VERSION 14:03:13.175 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:781 ] - NODE 55: Node advancer: DYNAMIC_VALUES - checking ASSOCIATION 14:03:13.175 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:781 ] - NODE 55: Node advancer: DYNAMIC_VALUES - checking BASIC 14:03:13.175 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:781 ] - NODE 55: Node advancer: DYNAMIC_VALUES - checking CONFIGURATION 14:03:13.175 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:816 ] - NODE 55: Node advancer: DYNAMIC_VALUES - queued 0 frames 14:03:13.176 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:868 ] - NODE 55: Node advancer - advancing to DONE 14:03:13.176 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:335 ] - NODE 55: Node advancer: loop - DONE try 0: stageAdvanced(true) 14:03:13.176 [DEBUG] [.b.z.i.p.i.ZWaveNodeSerializer:107 ] - NODE 55: Serializing to file etc/zwave/node55.xml 14:03:13.208 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:827 ] - NODE 55: Node advancer: Initialisation complete! 14:03:13.209 [DEBUG] [.z.internal.ZWaveActiveBinding:425 ] - NODE 55: ZWaveIncomingEvent Called, Network Event, Init Done. Setting device ready. 14:03:13.210 [DEBUG] [WaveController$ZWaveSendThread:1327 ] - NODE 55: Response processed after 102ms/4176ms. 14:03:14.170 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:506 ] - NODE 55: No more messages, go back to sleep 14:03:14.171 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:202 ] - NODE 55: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION 14:03:14.171 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ] - NODE 55: Creating empty message of class = SendData (0x13), type = Request (0x00) 14:03:14.173 [DEBUG] [WaveController$ZWaveSendThread:1268 ] - NODE 55: Sending REQUEST Message = 01 09 00 13 37 02 84 08 25 16 6F 14:03:14.184 [DEBUG] [b.z.i.p.s.SendDataMessageClass:38 ] - NODE 55: Sent Data successfully placed on stack. 14:03:14.199 [DEBUG] [b.z.i.p.s.SendDataMessageClass:74 ] - NODE 55: SendData Request. CallBack ID = 22, Status = Transmission complete and ACK received(0) 14:03:14.201 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:372 ] - NODE 55: Went to sleep 14:03:14.202 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:435 ] - NODE 55: Is sleeping 14:03:14.202 [DEBUG] [WaveController$ZWaveSendThread:1327 ] - NODE 55: Response processed after 28ms/4176ms. 14:03:15.557 [DEBUG] [.b.z.i.c.ZWaveBatteryConverter:60 ] - NODE 55: Generating poll message for BATTERY endpoint 0 14:03:15.557 [DEBUG] [i.p.c.ZWaveBatteryCommandClass:137 ] - NODE 55: Creating new message for application command BATTERY_GET 14:03:15.558 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ] - NODE 55: Creating empty message of class = SendData (0x13), type = Request (0x00) 14:03:15.558 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:241 ] - NODE 55: Putting message SendData in wakeup queue. 14:08:15.288 [DEBUG] [ApplicationCommandMessageClass:38 ] - NODE 55: Application Command Request (ALIVE:DONE) 14:08:15.288 [DEBUG] [ApplicationCommandMessageClass:56 ] - NODE 55: Incoming command class WAKE_UP 14:08:15.289 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:136 ] - NODE 55: Received Wake Up Request 14:08:15.289 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:182 ] - NODE 55: Received WAKE_UP_NOTIFICATION 14:08:15.289 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:411 ] - NODE 55: Is awake with 1 messages in the wake-up queue. 14:08:15.291 [DEBUG] [WaveController$ZWaveSendThread:1268 ] - NODE 55: Sending REQUEST Message = 01 09 00 13 37 02 80 02 25 1B 6C 14:08:15.300 [DEBUG] [b.z.i.p.s.SendDataMessageClass:38 ] - NODE 55: Sent Data successfully placed on stack. 14:08:15.317 [DEBUG] [b.z.i.p.s.SendDataMessageClass:74 ] - NODE 55: SendData Request. CallBack ID = 27, Status = Transmission complete and ACK received(0) 14:08:15.329 [DEBUG] [ApplicationCommandMessageClass:38 ] - NODE 55: Application Command Request (ALIVE:DONE) 14:08:15.329 [DEBUG] [ApplicationCommandMessageClass:56 ] - NODE 55: Incoming command class BATTERY 14:08:15.329 [DEBUG] [i.p.c.ZWaveBatteryCommandClass:81 ] - NODE 55: Received Battery Request 14:08:15.329 [DEBUG] [i.p.c.ZWaveBatteryCommandClass:96 ] - NODE 55: Battery report value = 40 14:08:15.330 [DEBUG] [.z.internal.ZWaveActiveBinding:450 ] - NODE 55: Got a value event from Z-Wave network, endpoint = 0, command class = BATTERY, value = 40 14:08:15.331 [DEBUG] [WaveController$ZWaveSendThread:1327 ] - NODE 55: Response processed after 40ms/4176ms. 14:08:16.331 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:506 ] - NODE 55: No more messages, go back to sleep 14:08:16.331 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:202 ] - NODE 55: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION 14:08:16.332 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ] - NODE 55: Creating empty message of class = SendData (0x13), type = Request (0x00) 14:08:16.335 [DEBUG] [WaveController$ZWaveSendThread:1268 ] - NODE 55: Sending REQUEST Message = 01 09 00 13 37 02 84 08 25 1C 65 14:08:16.344 [DEBUG] [b.z.i.p.s.SendDataMessageClass:38 ] - NODE 55: Sent Data successfully placed on stack. 14:08:16.362 [DEBUG] [b.z.i.p.s.SendDataMessageClass:74 ] - NODE 55: SendData Request. CallBack ID = 28, Status = Transmission complete and ACK received(0) 14:08:16.364 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:372 ] - NODE 55: Went to sleep 14:08:16.364 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:435 ] - NODE 55: Is sleeping 14:08:16.364 [DEBUG] [WaveController$ZWaveSendThread:1327 ] - NODE 55: Response processed after 29ms/4176ms. 14:13:17.925 [DEBUG] [ApplicationCommandMessageClass:38 ] - NODE 55: Application Command Request (ALIVE:DONE) 14:13:17.925 [DEBUG] [ApplicationCommandMessageClass:56 ] - NODE 55: Incoming command class WAKE_UP 14:13:17.926 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:136 ] - NODE 55: Received Wake Up Request 14:13:17.926 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:182 ] - NODE 55: Received WAKE_UP_NOTIFICATION 14:13:17.926 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:411 ] - NODE 55: Is awake with 0 messages in the wake-up queue. 14:13:18.926 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:506 ] - NODE 55: No more messages, go back to sleep 14:13:18.927 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:202 ] - NODE 55: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION 14:13:18.927 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ] - NODE 55: Creating empty message of class = SendData (0x13), type = Request (0x00) 14:13:18.929 [DEBUG] [WaveController$ZWaveSendThread:1268 ] - NODE 55: Sending REQUEST Message = 01 09 00 13 37 02 84 08 25 22 5B 14:13:18.938 [DEBUG] [b.z.i.p.s.SendDataMessageClass:38 ] - NODE 55: Sent Data successfully placed on stack. 14:13:18.954 [DEBUG] [b.z.i.p.s.SendDataMessageClass:74 ] - NODE 55: SendData Request. CallBack ID = 34, Status = Transmission complete and ACK received(0)
14:13:18.957 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:372 ] - NODE 55: Went to sleep 14:13:18.957 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:435 ] - NODE 55: Is sleeping 14:13:18.957 [DEBUG] [WaveController$ZWaveSendThread:1327 ] - NODE 55: Response processed after 28ms/4176ms. 14:18:20.627 [DEBUG] [ApplicationCommandMessageClass:38 ] - NODE 55: Application Command Request (ALIVE:DONE) 14:18:20.628 [DEBUG] [ApplicationCommandMessageClass:56 ] - NODE 55: Incoming command class WAKE_UP 14:18:20.628 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:136 ] - NODE 55: Received Wake Up Request 14:18:20.628 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:182 ] - NODE 55: Received WAKE_UP_NOTIFICATION 14:18:20.628 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:411 ] - NODE 55: Is awake with 0 messages in the wake-up queue. 14:18:21.629 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:506 ] - NODE 55: No more messages, go back to sleep 14:18:21.630 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:202 ] - NODE 55: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION 14:18:21.630 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ] - NODE 55: Creating empty message of class = SendData (0x13), type = Request (0x00) 14:18:21.632 [DEBUG] [WaveController$ZWaveSendThread:1268 ] - NODE 55: Sending REQUEST Message = 01 09 00 13 37 02 84 08 25 27 5E 14:18:21.641 [DEBUG] [b.z.i.p.s.SendDataMessageClass:38 ] - NODE 55: Sent Data successfully placed on stack. 14:18:21.659 [DEBUG] [b.z.i.p.s.SendDataMessageClass:74 ] - NODE 55: SendData Request. CallBack ID = 39, Status = Transmission complete and ACK received(0) 14:18:21.661 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:372 ] - NODE 55: Went to sleep 14:18:21.661 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:435 ] - NODE 55: Is sleeping 14:18:21.662 [DEBUG] [WaveController$ZWaveSendThread:1327 ] - NODE 55: Response processed after 30ms/4176ms. 14:23:23.377 [DEBUG] [ApplicationCommandMessageClass:38 ] - NODE 55: Application Command Request (ALIVE:DONE) 14:23:23.377 [DEBUG] [ApplicationCommandMessageClass:56 ] - NODE 55: Incoming command class WAKE_UP 14:23:23.377 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:136 ] - NODE 55: Received Wake Up Request 14:23:23.377 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:182 ] - NODE 55: Received WAKE_UP_NOTIFICATION 14:23:23.378 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:411 ] - NODE 55: Is awake with 0 messages in the wake-up queue. 14:23:24.379 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:506 ] - NODE 55: No more messages, go back to sleep 14:23:24.379 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:202 ] - NODE 55: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION 14:23:24.379 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ] - NODE 55: Creating empty message of class = SendData (0x13), type = Request (0x00) 14:23:24.381 [DEBUG] [WaveController$ZWaveSendThread:1268 ] - NODE 55: Sending REQUEST Message = 01 09 00 13 37 02 84 08 25 2D 54 14:23:24.391 [DEBUG] [b.z.i.p.s.SendDataMessageClass:38 ] - NODE 55: Sent Data successfully placed on stack. 14:23:24.409 [DEBUG] [b.z.i.p.s.SendDataMessageClass:74 ] - NODE 55: SendData Request. CallBack ID = 45, Status = Transmission complete and ACK received(0) 14:23:24.412 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:372 ] - NODE 55: Went to sleep 14:23:24.412 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:435 ] - NODE 55: Is sleeping 14:23:24.413 [DEBUG] [WaveController$ZWaveSendThread:1327 ] - NODE 55: Response processed after 32ms/4176ms. 14:28:26.005 [DEBUG] [ApplicationCommandMessageClass:38 ] - NODE 55: Application Command Request (ALIVE:DONE) 14:28:26.005 [DEBUG] [ApplicationCommandMessageClass:56 ] - NODE 55: Incoming command class WAKE_UP 14:28:26.005 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:136 ] - NODE 55: Received Wake Up Request 14:28:26.005 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:182 ] - NODE 55: Received WAKE_UP_NOTIFICATION 14:28:26.005 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:411 ] - NODE 55: Is awake with 0 messages in the wake-up queue. 14:28:27.006 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:506 ] - NODE 55: No more messages, go back to sleep 14:28:27.006 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:202 ] - NODE 55: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION 14:28:27.007 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ] - NODE 55: Creating empty message of class = SendData (0x13), type = Request (0x00) 14:28:27.008 [DEBUG] [WaveController$ZWaveSendThread:1268 ] - NODE 55: Sending REQUEST Message = 01 09 00 13 37 02 84 08 25 31 48 14:28:27.018 [DEBUG] [b.z.i.p.s.SendDataMessageClass:38 ] - NODE 55: Sent Data successfully placed on stack. 14:28:27.035 [DEBUG] [b.z.i.p.s.SendDataMessageClass:74 ] - NODE 55: SendData Request. CallBack ID = 49, Status = Transmission complete and ACK received(0) 14:28:27.037 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:372 ] - NODE 55: Went to sleep 14:28:27.037 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:435 ] - NODE 55: Is sleeping 14:28:27.038 [DEBUG] [WaveController$ZWaveSendThread:1327 ] - NODE 55: Response processed after 30ms/4176ms. 14:33:28.772 [DEBUG] [ApplicationCommandMessageClass:38 ] - NODE 55: Application Command Request (ALIVE:DONE) 14:33:28.773 [DEBUG] [ApplicationCommandMessageClass:56 ] - NODE 55: Incoming command class WAKE_UP 14:33:28.773 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:136 ] - NODE 55: Received Wake Up Request 14:33:28.773 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:182 ] - NODE 55: Received WAKE_UP_NOTIFICATION 14:33:28.773 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:411 ] - NODE 55: Is awake with 0 messages in the wake-up queue. 14:33:29.774 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:506 ] - NODE 55: No more messages, go back to sleep 14:33:29.774 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:202 ] - NODE 55: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION 14:33:29.775 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ] - NODE 55: Creating empty message of class = SendData (0x13), type = Request (0x00) 14:33:29.776 [DEBUG] [WaveController$ZWaveSendThread:1268 ] - NODE 55: Sending REQUEST Message = 01 09 00 13 37 02 84 08 25 36 4F 14:33:29.786 [DEBUG] [b.z.i.p.s.SendDataMessageClass:38 ] - NODE 55: Sent Data successfully placed on stack. 14:33:29.802 [DEBUG] [b.z.i.p.s.SendDataMessageClass:74 ] - NODE 55: SendData Request. CallBack ID = 54, Status = Transmission complete and ACK received(0) 14:33:29.803 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:372 ] - NODE 55: Went to sleep 14:33:29.803 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:435 ] - NODE 55: Is sleeping 14:33:29.804 [DEBUG] [WaveController$ZWaveSendThread:1327 ] - NODE 55: Response processed after 27ms/4176ms. 14:35:22.097 [DEBUG] [.b.z.i.c.ZWaveBatteryConverter:60 ] - NODE 55: Generating poll message for BATTERY endpoint 0 14:35:22.098 [DEBUG] [i.p.c.ZWaveBatteryCommandClass:137 ] - NODE 55: Creating new message for application command BATTERY_GET 14:35:22.098 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ] - NODE 55: Creating empty message of class = SendData (0x13), type = Request (0x00) 14:35:22.099 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:241 ] - NODE 55: Putting message SendData in wakeup queue. 14:35:22.115 [DEBUG] [.i.c.ZWaveAlarmSensorConverter:66 ] - NODE 55: Generating poll message for SENSOR_ALARM, endpoint 0 14:35:22.116 [DEBUG] [c.ZWaveAlarmSensorCommandClass:209 ] - NODE 55: Creating new message for command SENSOR_ALARM_GET, type Flood 14:35:22.116 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ] - NODE 55: Creating empty message of class = SendData (0x13), type = Request (0x00) 14:35:22.116 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:241 ] - NODE 55: Putting message SendData in wakeup queue. 14:36:32.127 [DEBUG] [.b.z.i.c.ZWaveBatteryConverter:60 ] - NODE 55: Generating poll message for BATTERY endpoint 0 14:36:32.127 [DEBUG] [i.p.c.ZWaveBatteryCommandClass:137 ] - NODE 55: Creating new message for application command BATTERY_GET 14:36:32.128 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ] - NODE 55: Creating empty message of class = SendData (0x13), type = Request (0x00) 14:36:32.129 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:237 ] - NODE 55: Message already on the wake-up queue. Removing original. 14:36:32.129 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:241 ] - NODE 55: Putting message SendData in wakeup queue. 14:36:32.130 [DEBUG] [.i.c.ZWaveAlarmSensorConverter:66 ] - NODE 55: Generating poll message for SENSOR_ALARM, endpoint 0 14:36:32.130 [DEBUG] [c.ZWaveAlarmSensorCommandClass:209 ] - NODE 55: Creating new message for command SENSOR_ALARM_GET, type Flood 14:36:32.130 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ] - NODE 55: Creating empty message of class = SendData (0x13), type = Request (0x00) 14:36:32.131 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:237 ] - NODE 55: Message already on the wake-up queue. Removing original. 14:36:32.131 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:241 ] - NODE 55: Putting message SendData in wakeup queue. 14:38:31.562 [DEBUG] [ApplicationCommandMessageClass:38 ] - NODE 55: Application Command Request (ALIVE:DONE) 14:38:31.562 [DEBUG] [ApplicationCommandMessageClass:56 ] - NODE 55: Incoming command class WAKE_UP 14:38:31.562 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:136 ] - NODE 55: Received Wake Up Request 14:38:31.562 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:182 ] - NODE 55: Received WAKE_UP_NOTIFICATION 14:38:31.563 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:411 ] - NODE 55: Is awake with 2 messages in the wake-up queue. 14:38:31.565 [DEBUG] [WaveController$ZWaveSendThread:1268 ] - NODE 55: Sending REQUEST Message = 01 09 00 13 37 02 80 02 25 3E 49 14:38:31.575 [DEBUG] [b.z.i.p.s.SendDataMessageClass:38 ] - NODE 55: Sent Data successfully placed on stack. 14:38:31.592 [DEBUG] [b.z.i.p.s.SendDataMessageClass:74 ] - NODE 55: SendData Request. CallBack ID = 62, Status = Transmission complete and ACK received(0) 14:38:31.601 [DEBUG] [ApplicationCommandMessageClass:38 ] - NODE 55: Application Command Request (ALIVE:DONE) 14:38:31.601 [DEBUG] [ApplicationCommandMessageClass:56 ] - NODE 55: Incoming command class BATTERY 14:38:31.602 [DEBUG] [i.p.c.ZWaveBatteryCommandClass:81 ] - NODE 55: Received Battery Request 14:38:31.602 [DEBUG] [i.p.c.ZWaveBatteryCommandClass:96 ] - NODE 55: Battery report value = 40 14:38:31.602 [DEBUG] [.z.internal.ZWaveActiveBinding:450 ] - NODE 55: Got a value event from Z-Wave network, endpoint = 0, command class = BATTERY, value = 40 14:38:31.603 [DEBUG] [WaveController$ZWaveSendThread:1327 ] - NODE 55: Response processed after 38ms/4176ms. 14:38:31.604 [DEBUG] [WaveController$ZWaveSendThread:1268 ] - NODE 55: Sending REQUEST Message = 01 0A 00 13 37 03 9C 01 05 25 3F 50 14:38:31.614 [DEBUG] [b.z.i.p.s.SendDataMessageClass:38 ] - NODE 55: Sent Data successfully placed on stack. 14:38:31.631 [DEBUG] [b.z.i.p.s.SendDataMessageClass:74 ] - NODE 55: SendData Request. CallBack ID = 63, Status = Transmission complete and ACK received(0) 14:38:31.643 [DEBUG] [ApplicationCommandMessageClass:38 ] - NODE 55: Application Command Request (ALIVE:DONE) 14:38:31.643 [DEBUG] [ApplicationCommandMessageClass:56 ] - NODE 55: Incoming command class SENSOR_ALARM 14:38:31.643 [DEBUG] [c.ZWaveAlarmSensorCommandClass:85 ] - NODE 55: Received Sensor Alarm Request 14:38:31.644 [DEBUG] [c.ZWaveAlarmSensorCommandClass:104 ] - NODE 55: Alarm Report: Source=55, Type=Flood(5), Value=0 14:38:31.644 [DEBUG] [.z.internal.ZWaveActiveBinding:450 ] - NODE 55: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_ALARM, value = 0 14:38:31.647 [DEBUG] [WaveController$ZWaveSendThread:1327 ] - NODE 55: Response processed after 43ms/4176ms. 14:38:32.647 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:506 ] - NODE 55: No more messages, go back to sleep 14:38:32.648 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:202 ] - NODE 55: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION 14:38:32.648 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ] - NODE 55: Creating empty message of class = SendData (0x13), type = Request (0x00) 14:38:32.649 [DEBUG] [WaveController$ZWaveSendThread:1268 ] - NODE 55: Sending REQUEST Message = 01 09 00 13 37 02 84 08 25 40 39 14:38:32.659 [DEBUG] [b.z.i.p.s.SendDataMessageClass:38 ] - NODE 55: Sent Data successfully placed on stack. 14:38:32.676 [DEBUG] [b.z.i.p.s.SendDataMessageClass:74 ] - NODE 55: SendData Request. CallBack ID = 64, Status = Transmission complete and ACK received(0) 14:38:32.678 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:372 ] - NODE 55: Went to sleep 14:38:32.679 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:435 ] - NODE 55: Is sleeping 14:38:32.679 [DEBUG] [WaveController$ZWaveSendThread:1327 ] - NODE 55: Response processed after 29ms/4176ms. 14:43:34.240 [DEBUG] [ApplicationCommandMessageClass:38 ] - NODE 55: Application Command Request (ALIVE:DONE) 14:43:34.241 [DEBUG] [ApplicationCommandMessageClass:56 ] - NODE 55: Incoming command class WAKE_UP 14:43:34.241 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:136 ] - NODE 55: Received Wake Up Request 14:43:34.241 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:182 ] - NODE 55: Received WAKE_UP_NOTIFICATION 14:43:34.241 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:411 ] - NODE 55: Is awake with 0 messages in the wake-up queue. 14:43:35.242 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:506 ] - NODE 55: No more messages, go back to sleep 14:43:35.243 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:202 ] - NODE 55: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION 14:43:35.243 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ] - NODE 55: Creating empty message of class = SendData (0x13), type = Request (0x00) 14:43:35.243 [DEBUG] [WaveController$ZWaveSendThread:1268 ] - NODE 55: Sending REQUEST Message = 01 09 00 13 37 02 84 08 25 46 3F 14:43:35.252 [DEBUG] [b.z.i.p.s.SendDataMessageClass:38 ] - NODE 55: Sent Data successfully placed on stack. 14:43:35.270 [DEBUG] [b.z.i.p.s.SendDataMessageClass:74 ] - NODE 55: SendData Request. CallBack ID = 70, Status = Transmission complete and ACK received(0) 14:43:35.273 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:372 ] - NODE 55: Went to sleep 14:43:35.273 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:435 ] - NODE 55: Is sleeping 14:43:35.273 [DEBUG] [WaveController$ZWaveSendThread:1327 ] - NODE 55: Response processed after 30ms/4176ms. 14:48:37.087 [DEBUG] [ApplicationCommandMessageClass:38 ] - NODE 55: Application Command Request (ALIVE:DONE) 14:48:37.088 [DEBUG] [ApplicationCommandMessageClass:56 ] - NODE 55: Incoming command class WAKE_UP 14:48:37.088 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:136 ] - NODE 55: Received Wake Up Request 14:48:37.088 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:182 ] - NODE 55: Received WAKE_UP_NOTIFICATION 14:48:37.089 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:411 ] - NODE 55: Is awake with 0 messages in the wake-up queue. 14:48:38.090 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:506 ] - NODE 55: No more messages, go back to sleep 14:48:38.090 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:202 ] - NODE 55: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION 14:48:38.090 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ] - NODE 55: Creating empty message of class = SendData (0x13), type = Request (0x00) 14:48:38.091 [DEBUG] [WaveController$ZWaveSendThread:1268 ] - NODE 55: Sending REQUEST Message = 01 09 00 13 37 02 84 08 25 4B 32 14:48:38.101 [DEBUG] [b.z.i.p.s.SendDataMessageClass:38 ] - NODE 55: Sent Data successfully placed on stack. 14:48:38.118 [DEBUG] [b.z.i.p.s.SendDataMessageClass:74 ] - NODE 55: SendData Request. CallBack ID = 75, Status = Transmission complete and ACK received(0) 14:48:38.120 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:372 ] - NODE 55: Went to sleep 14:48:38.121 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:435 ] - NODE 55: Is sleeping 14:48:38.121 [DEBUG] [WaveController$ZWaveSendThread:1327 ] - NODE 55: Response processed after 30ms/4176ms. 14:53:40.186 [DEBUG] [ApplicationCommandMessageClass:38 ] - NODE 55: Application Command Request (ALIVE:DONE) 14:53:40.186 [DEBUG] [ApplicationCommandMessageClass:56 ] - NODE 55: Incoming command class WAKE_UP 14:53:40.186 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:136 ] - NODE 55: Received Wake Up Request 14:53:40.187 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:182 ] - NODE 55: Received WAKE_UP_NOTIFICATION 14:53:40.187 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:411 ] - NODE 55: Is awake with 0 messages in the wake-up queue. 14:53:41.187 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:506 ] - NODE 55: No more messages, go back to sleep 14:53:41.187 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:202 ] - NODE 55: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION 14:53:41.187 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ] - NODE 55: Creating empty message of class = SendData (0x13), type = Request (0x00) 14:53:41.189 [DEBUG] [WaveController$ZWaveSendThread:1268 ] - NODE 55: Sending REQUEST Message = 01 09 00 13 37 02 84 08 25 4F 36 14:53:41.198 [DEBUG] [b.z.i.p.s.SendDataMessageClass:38 ] - NODE 55: Sent Data successfully placed on stack. 14:53:41.214 [DEBUG] [b.z.i.p.s.SendDataMessageClass:74 ] - NODE 55: SendData Request. CallBack ID = 79, Status = Transmission complete and ACK received(0) 14:53:41.216 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:372 ] - NODE 55: Went to sleep 14:53:41.216 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:435 ] - NODE 55: Is sleeping 14:53:41.216 [DEBUG] [WaveController$ZWaveSendThread:1327 ] - NODE 55: Response processed after 27ms/4176ms. 14:58:43.145 [DEBUG] [ApplicationCommandMessageClass:38 ] - NODE 55: Application Command Request (ALIVE:DONE) 14:58:43.145 [DEBUG] [ApplicationCommandMessageClass:56 ] - NODE 55: Incoming command class WAKE_UP 14:58:43.146 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:136 ] - NODE 55: Received Wake Up Request 14:58:43.146 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:182 ] - NODE 55: Received WAKE_UP_NOTIFICATION 14:58:43.146 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:411 ] - NODE 55: Is awake with 0 messages in the wake-up queue. 14:58:44.147 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:506 ] - NODE 55: No more messages, go back to sleep 14:58:44.147 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:202 ] - NODE 55: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION 14:58:44.148 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ] - NODE 55: Creating empty message of class = SendData (0x13), type = Request (0x00) 14:58:44.148 [DEBUG] [WaveController$ZWaveSendThread:1268 ] - NODE 55: Sending REQUEST Message = 01 09 00 13 37 02 84 08 25 53 2A 14:58:44.157 [DEBUG] [b.z.i.p.s.SendDataMessageClass:38 ] - NODE 55: Sent Data successfully placed on stack. 14:58:44.174 [DEBUG] [b.z.i.p.s.SendDataMessageClass:74 ] - NODE 55: SendData Request. CallBack ID = 83, Status = Transmission complete and ACK received(0) 14:58:44.175 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:372 ] - NODE 55: Went to sleep 14:58:44.175 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:435 ] - NODE 55: Is sleeping 14:58:44.175 [DEBUG] [WaveController$ZWaveSendThread:1327 ] - NODE 55: Response processed after 27ms/4176ms. 15:03:46.052 [DEBUG] [ApplicationCommandMessageClass:38 ] - NODE 55: Application Command Request (ALIVE:DONE) 15:03:46.053 [DEBUG] [ApplicationCommandMessageClass:56 ] - NODE 55: Incoming command class WAKE_UP 15:03:46.053 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:136 ] - NODE 55: Received Wake Up Request 15:03:46.053 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:182 ] - NODE 55: Received WAKE_UP_NOTIFICATION 15:03:46.054 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:411 ] - NODE 55: Is awake with 0 messages in the wake-up queue. 15:03:47.054 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:506 ] - NODE 55: No more messages, go back to sleep 15:03:47.055 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:202 ] - NODE 55: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION 15:03:47.055 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ] - NODE 55: Creating empty message of class = SendData (0x13), type = Request (0x00) 15:03:47.057 [DEBUG] [WaveController$ZWaveSendThread:1268 ] - NODE 55: Sending REQUEST Message = 01 09 00 13 37 02 84 08 25 58 21 15:03:47.067 [DEBUG] [b.z.i.p.s.SendDataMessageClass:38 ] - NODE 55: Sent Data successfully placed on stack. 15:03:47.083 [DEBUG] [b.z.i.p.s.SendDataMessageClass:74 ] - NODE 55: SendData Request. CallBack ID = 88, Status = Transmission complete and ACK received(0) 15:03:47.085 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:372 ] - NODE 55: Went to sleep 15:03:47.086 [DEBUG] [.i.p.c.ZWaveWakeUpCommandClass:435 ] - NODE 55: Is sleeping 15:03:47.086 [DEBUG] [WaveController$ZWaveSendThread:1327 ] - NODE 55: Response processed after 29ms/4176ms.
thanks @chris
issue solved with latest binding1.8.2 , flood sensor reporting battery level after every 3600 seconds…
Just to note that the database won’t impact this at all… At least it’s working
I would recommend that you upgrade to the latest version of the binding - eg 1.9.0.
