I am trying to setup a Fibaro 101 Door/Window sensor but cannot make it send the contact status. I am seeing in the debug-logs that the device is sending an alarm frame when the contact is opened or closed. However, whatever I set as a channel does not work.
Is anybody using this device and can share the parameters, associated groups and channel-configuration?
