I’m a little confused. You’re using a sensor_binary channel in this item definition, but the device database entry for the FGK101 v2.5 shows there is no sensor_binary channel, only a sensor_door channel.
The device database entry shows that there is no alarm_tamper channel. If you can post a debug log showing that the device produces a tamper alarm, we can update the database to add that channel.
But I want to find out if I go to 2.4 (which causes the need for all my z-wave devices to delete and re-add) I had problems. So I deleted one of my perfect working sensors and re-add him again. Now the possible channels are totally different to the other devices still stay at old config. The old once still working. For me it looks like there is a change in the database. On chris homepage I cannot see this change. looks still good.
The only thing I can think of is that between the time when you originally added the device to your system (2 years ago?) and when you installed 2.3, the database changed for that device. Then by deleting and readding the device, you picked up the database definition that came with 2.3.
It’s hard to comment too much about code that is so old. It would be good if you can update to 2.4 - shortly (a few weeks) there will be 2.4 final - if there is a bug, then it would be good to fix it before it is released otherwise people will have to wait another 6 months for the next release.
Thanks for the reply. Can I use the z-wave 2.4 binding with my OH 2.3 installation?
Steps to do (as i remember from other posts)
install new z-wave binding
delete all z-wave things in habmin
delete all xml-files
re-add all things in habmin
wake them up to get inf data
Is there a way back if it will not work? I have 40 door/window sensors and a lot of other z-wave devices which should work after the update. If not, my wife will kill me
