The device is not recognized. Sometimes after a while it is recognized but then suddenly it is not recognized anymore and OH2 reports online and offline and not recognized.
This indicates that the binding has not been able to communicate with the device. It probably means that you haven’t woken up the device (potentially required a few times) to allow this communication to take place.
There will be a button in the device to do this - maybe you have to click it quickly three times or something to wake it up - the manual should tell you how to do this.
My problems are not resolved. After a reboot, due to an upgrade of OpenHAB to the latest snapshot, the following is shown in the log. And the device is listed as offline. It is a FGMS001. I find this behaviour strange as my other battery operated zwave smoke detector (FGSD002) starts and is active right from the start.
Actually looking to the FGSD002 it says Status: ONLINE Node initialising: WAIT. Which I rather understand as I think it waits for the device to wake-up before a timeout.
Can anyone help?
2017-10-30 14:05:44.580 [hingStatusInfoChangedEvent] - 'zwave:device:03f9975a:node10' changed from ONLINE to UNINITIALIZED
2017-10-30 14:05:44.632 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occurred while disposing handler of thing 'zwave:device:03f9975a:node10': java.lang.NullPointerException
2017-10-30 14:05:44.710 [hingStatusInfoChangedEvent] - 'zwave:device:03f9975a:node10' changed from ONLINE to UNINITIALIZED (HANDLER_MISSING_ERROR)
2017-10-30 14:05:49.829 [temChannelLinkRemovedEvent] - Link 'zwave_device_03f9975a_node10_alarm_tamper => zwave:device:03f9975a:node10:alarm_tamper' has been removed.
2017-10-30 14:05:49.959 [temChannelLinkRemovedEvent] - Link 'zwave_device_03f9975a_node10_sensor_binary => zwave:device:03f9975a:node10:sensor_binary' has been removed.
2017-10-30 14:07:48.501 [.ItemChannelLinkAddedEvent] - Link 'zwave_device_03f9975a_node10_battery_level-zwave:device:03f9975a:node10:battery-level' has been added.
2017-10-30 14:07:48.663 [.ItemChannelLinkAddedEvent] - Link 'zwave_device_03f9975a_node10_alarm_tamper-zwave:device:03f9975a:node10:alarm_tamper' has been added.
2017-10-30 14:07:48.697 [.ItemChannelLinkAddedEvent] - Link 'zwave_device_03f9975a_node10_sensor_seismicintensity-zwave:device:03f9975a:node10:sensor_seismicintensity' has been added.
2017-10-30 14:07:48.870 [.ItemChannelLinkAddedEvent] - Link 'zwave_device_03f9975a_node10_sensor_temperature-zwave:device:03f9975a:node10:sensor_temperature' has been added.
2017-10-30 14:07:48.914 [.ItemChannelLinkAddedEvent] - Link 'zwave_device_03f9975a_node10_sensor_binary-zwave:device:03f9975a:node10:sensor_binary' has been added.
2017-10-30 14:07:48.995 [.ItemChannelLinkAddedEvent] - Link 'zwave_device_03f9975a_node10_alarm_motion-zwave:device:03f9975a:node10:alarm_motion' has been added.
2017-10-30 14:07:49.073 [.ItemChannelLinkAddedEvent] - Link 'zwave_device_03f9975a_node10_sensor_luminance-zwave:device:03f9975a:node10:sensor_luminance' has been added.
2017-10-30 14:07:49.236 [.ItemChannelLinkAddedEvent] - Link 'zwave_device_03f9975a_node10_alarm_general-zwave:device:03f9975a:node10:alarm_general' has been added.
2017-10-30 14:08:54.832 [vent.ItemStateChangedEvent] - zwave_device_03f9975a_node10_battery_level changed from NULL to 100
2017-10-30 14:08:54.895 [vent.ItemStateChangedEvent] - zwave_device_03f9975a_node10_alarm_tamper changed from NULL to OFF
2017-10-30 14:08:54.902 [vent.ItemStateChangedEvent] - zwave_device_03f9975a_node10_sensor_seismicintensity changed from NULL to 0
2017-10-30 14:08:54.956 [vent.ItemStateChangedEvent] - zwave_device_03f9975a_node10_sensor_temperature changed from NULL to 21.3
2017-10-30 14:08:54.967 [vent.ItemStateChangedEvent] - zwave_device_03f9975a_node10_sensor_binary changed from NULL to OFF
2017-10-30 14:08:54.986 [vent.ItemStateChangedEvent] - zwave_device_03f9975a_node10_alarm_motion changed from NULL to OFF
2017-10-30 14:08:55.004 [vent.ItemStateChangedEvent] - zwave_device_03f9975a_node10_sensor_luminance changed from NULL to 33
2017-10-30 14:08:55.064 [vent.ItemStateChangedEvent] - zwave_device_03f9975a_node10_alarm_general changed from NULL to OFF
2017-10-30 14:09:08.190 [hingStatusInfoChangedEvent] - 'zwave:device:03f9975a:node10' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2017-10-30 14:09:09.029 [hingStatusInfoChangedEvent] - 'zwave:device:03f9975a:node10' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2017-10-30 14:09:09.033 [hingStatusInfoChangedEvent] - 'zwave:device:03f9975a:node10' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2017-10-30 14:09:17.889 [hingStatusInfoChangedEvent] - 'zwave:device:03f9975a:node10' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
This item still is not working. I think it does not configure itself in the correct way.
See the image below what it thinks its properties are. The zwave_class_basic and zwave_class_generic are not_known. This cannot be correct. How can I change that?
