- Platform information:
- Hardware: RPI3+
- OS: Linux/5.10.52-v7+ (arm)
- Java Runtime Environment: 11.0.12 (Zulu11.50+19-CA)
- openHAB version: openHAB 3.1.0
- Issue of the topic: When I use dimmer outputs and analog inputs at the same time, changing the voltage on the input changes the brightness of the outputs (analog inputs behave like buttons), the controller has the option to set “Local Protection”, in the documentation I see it in Endpoit 0 → COMMAND_CLASS_PROTECTION_V2, how to configure (set) this it in OH3? I need to set it up once and leave it, maybe there is a quick way to do it with a script or someway…?
I use standard z-wave DB in OH 3.1, Thing config:
zwave_class_basic: BASIC_TYPE_ROUTING_SLAVE
zwave_class_generic: GENERIC_TYPE_SWITCH_MULTILEVEL
zwave_frequent: false
zwave_neighbours: 1,5,6,7,8,9,10
modelId: FGRGBW-442
zwave_version: 5.0
zwave_listening: true
zwave_plus_devicetype: NODE_TYPE_ZWAVEPLUS_NODE
manufacturerId: 010F
manufacturerRef: 0902:1000,0902:2000,0902:3000,0902:4000
dbReference: 1127
zwave_deviceid: 4096
zwave_nodeid: 11
zwave_lastheal: 2021-10-02T00:27:26Z
vendor: Fibargroup
defaultAssociations: 1
zwave_routing: true
zwave_plus_roletype: ROLE_TYPE_SLAVE_ALWAYS_ON
zwave_beaming: true
zwave_secure: false
zwave_class_specific: SPECIFIC_TYPE_COLOR_TUNABLE_MULTILEVEL
zwave_manufacturer: 271
zwave_devicetype: 2306
Thanks for any help
