Hi, I´m new and after reading here a while and getting enthusiasted I have started with my own project.
I´m running Openhab 2.2.0-1 on Ubuntu 16.04. LTS using Oracle Java 32bit.
First I want to get some FGRM222 Roller Shutter up and running.
I´m using as a Z-Wave Serial controller a Z-WAVE.ME which is identifies as zwave:serial_zstick:a4b26c03:serial_sof in the Paper UI.
In the next step I have connected the first FGRM222 Roller Shutter to the wall plug and after I have pressed “SEARCH FOR THINGS” in Paper UI inbox it cames up and I have added it, so it was listed under “Configuration => Things” together in a list with the Z-Wave controller.
I did the same with to other FGRM222´s, so after some times restarting the Openhub2 service I could saw the Z-WAVE.ME and all 3 FGRM222.
Then I have installed the FGRM222 Roller Shutter´s so now all of them are connected with electricity, also the Roller Shutters are working well using the wall switch which is connected to the FGRM222.
But: I can see in Paper UI “Configuration => Things” onle the Z-Wave Serial Controller and the first FGRM222 as online, the other two FGRM222´s are offline.
In HABmin I can find this information:
Z-Wave Serial Controller => green checkmark
First FGRM222 Roller Shutter => green checkmark => Node Initialising: Ping
Second FGRM222 Roller Shutter => grey X => Node is not communicating with the controller
Third FGRM222 Roller Shutter => grey X => Node is not communicating with the controller
If I click in Paper UI “Configuration => Things” an offline FGRM222 I can find a text explaining me how to include the device.
I tried it by doing:
I pushed the button which is connected to S1 on the FGRM222 for 3 seconds
and
I pushed the button which is connected to S1 on the FGRM222 for 3 times each time +/- 1 second
There is a button on the FGRM222 which I clicked so there came a led up changing 4 times the colour until the led switched off. I pushed this button 3 times.
Nothing helps. Even I noticed that at 2.) the instruction says “Set the main controller into the learn mode” but I couldn´t found any instruction how to put the Z-WAVE.ME into learn mode.
So what´s my mistake?
In advance thanks to all for each help!
openhab.log
2018-02-24 16:54:28.406 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2018-02-24 16:54:28.408 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2018-02-24 16:54:31.611 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 1: Node found
2018-02-24 16:54:31.613 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 2: Node found
2018-02-24 16:54:31.614 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 3: Node found
2018-02-24 16:54:31.616 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 4: Node found
2018-02-24 16:54:31.617 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller using Controller API
2018-02-24 16:54:31.620 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller is Primary Controller
2018-02-24 16:54:31.621 [INFO ] [age.SerialApiGetInitDataMessageClass] - ------------Number of Nodes Found Registered to ZWave Controller------------
2018-02-24 16:54:31.623 [INFO ] [age.SerialApiGetInitDataMessageClass] - # Nodes = 4
2018-02-24 16:54:31.624 [INFO ] [age.SerialApiGetInitDataMessageClass] - ----------------------------------------------------------------------------
2018-02-24 16:54:32.220 [WARN ] [rialmessage.IsFailedNodeMessageClass] - NODE 3: Is currently marked as failed by the controller!
2018-02-24 16:54:32.240 [WARN ] [rialmessage.IsFailedNodeMessageClass] - NODE 2: Is currently marked as failed by the controller!
2018-02-24 16:54:40.623 [WARN ] [rialmessage.IsFailedNodeMessageClass] - NODE 2: Is currently marked as failed by the controller!
2018-02-24 16:57:04.445 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Device discovery could not resolve to a thingType! 7FFFFFFF:7FFFFFFF:7FFFFFFF::0.0
2018-02-24 16:57:04.454 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 4: Device discovery could not resolve to a thingType! 7FFFFFFF:7FFFFFFF:7FFFFFFF::0.0
2018-02-24 17:05:56.415 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Device discovery could not resolve to a thingType! 7FFFFFFF:7FFFFFFF:7FFFFFFF::0.0
2018-02-24 17:05:56.420 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 4: Device discovery could not resolve to a thingType! 7FFFFFFF:7FFFFFFF:7FFFFFFF::0.0
2018-02-24 17:47:52.615 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Device discovery could not resolve to a thingType! 7FFFFFFF:7FFFFFFF:7FFFFFFF::0.0
2018-02-24 17:47:52.623 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 4: Device discovery could not resolve to a thingType! 7FFFFFFF:7FFFFFFF:7FFFFFFF::0.0
2018-02-24 18:07:59.181 [ERROR] [ing.zwave.handler.ZWaveSerialHandler] - ZWave port is not set.
2018-02-24 18:12:12.920 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Stopped ZWave serial handler
2018-02-24 18:13:15.239 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Device discovery could not resolve to a thingType! 7FFFFFFF:7FFFFFFF:7FFFFFFF::0.0
2018-02-24 18:13:15.243 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 4: Device discovery could not resolve to a thingType! 7FFFFFFF:7FFFFFFF:7FFFFFFF::0.0
2018-02-24 18:13:15.249 [ERROR] [ing.zwave.handler.ZWaveSerialHandler] - Got I/O exception Input/output error in writeArray during sending. exiting thread.
2018-02-24 18:13:20.252 [ERROR] [ing.zwave.handler.ZWaveSerialHandler] - Got I/O exception Input/output error in writeArray during sending. exiting thread.
2018-02-24 18:13:25.255 [ERROR] [ing.zwave.handler.ZWaveSerialHandler] - Got I/O exception Input/output error in writeArray during sending. exiting thread.
2018-02-24 18:13:30.257 [ERROR] [ing.zwave.handler.ZWaveSerialHandler] - Got I/O exception Input/output error in writeArray during sending. exiting thread.
2018-02-24 18:13:45.237 [ERROR] [ing.zwave.handler.ZWaveSerialHandler] - Got I/O exception Input/output error in writeArray during sending. exiting thread.
2018-02-24 18:13:50.239 [ERROR] [ing.zwave.handler.ZWaveSerialHandler] - Got I/O exception Input/output error in writeArray during sending. exiting thread.
2018-02-24 18:13:55.241 [ERROR] [ing.zwave.handler.ZWaveSerialHandler] - Got I/O exception Input/output error in writeArray during sending. exiting thread.
2018-02-24 18:14:00.243 [ERROR] [ing.zwave.handler.ZWaveSerialHandler] - Got I/O exception Input/output error in writeArray during sending. exiting thread.
2018-02-24 18:31:42.843 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
2018-02-24 18:31:42.896 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2018-02-24 18:37:07.209 [ERROR] [ing.zwave.handler.ZWaveSerialHandler] - Got I/O exception Input/output error in writeArray during sending. exiting thread.
2018-02-24 18:37:12.211 [ERROR] [ing.zwave.handler.ZWaveSerialHandler] - Got I/O exception Input/output error in writeArray during sending. exiting thread.
2018-02-24 18:37:12.220 [ERROR] [ing.zwave.handler.ZWaveSerialHandler] - Got I/O exception Input/output error in writeArray during sending. exiting thread.
2018-02-24 18:37:17.222 [ERROR] [ing.zwave.handler.ZWaveSerialHandler] - Got I/O exception Input/output error in writeArray during sending. exiting thread.
2018-02-24 18:37:17.223 [ERROR] [ing.zwave.handler.ZWaveSerialHandler] - Got I/O exception Input/output error in writeArray during sending. exiting thread.
2018-02-24 18:37:22.231 [ERROR] [ing.zwave.handler.ZWaveSerialHandler] - Got I/O exception Input/output error in writeArray during sending. exiting thread.
events.log
2018-02-22 17:37:47.298 [hingStatusInfoChangedEvent] - ‘zwave:serial_zstick:161be608c6c’ changed from UNINITIALIZED to INITIALIZING
2018-02-22 17:39:20.303 [hingStatusInfoChangedEvent] - ‘zwave:serial_zstick:e003a061’ changed from OFFLINE (COMMUNICATION_ERROR): Serial Error: Port /dev/ttyACM0 does not exist to UNIN$
2018-02-22 17:39:20.312 [hingStatusInfoChangedEvent] - ‘zwave:serial_zstick:e003a061’ changed from OFFLINE (COMMUNICATION_ERROR): Serial Error: Port /dev/ttyACM0 does not exist to UNIN$
2018-02-22 17:41:13.241 [hingStatusInfoChangedEvent] - ‘zwave:serial_zstick:161be608c6c’ changed from INITIALIZING to UNINITIALIZED
2018-02-22 17:41:13.257 [hingStatusInfoChangedEvent] - ‘zwave:serial_zstick:161be608c6c’ changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2018-02-22 17:41:40.990 [hingStatusInfoChangedEvent] - ‘zwave:serial_zstick:161be608c6c’ changed from UNINITIALIZED to INITIALIZING
2018-02-22 17:42:02.880 [me.event.ThingUpdatedEvent] - Thing ‘zwave:serial_zstick:161be608c6c’ has been updated.
2018-02-22 17:42:02.933 [me.event.ThingUpdatedEvent] - Thing ‘zwave:serial_zstick:161be608c6c’ has been updated.
2018-02-22 17:42:02.958 [hingStatusInfoChangedEvent] - ‘zwave:serial_zstick:161be608c6c’ changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2018-02-22 17:42:02.960 [hingStatusInfoChangedEvent] - ‘zwave:serial_zstick:161be608c6c’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE (COMMUNICATION_ERROR): $
2018-02-22 17:42:36.379 [me.event.ThingUpdatedEvent] - Thing ‘zwave:serial_zstick:161be608c6c’ has been updated.
2018-02-22 17:52:39.543 [hingStatusInfoChangedEvent] - ‘zwave:serial_zstick:161be608c6c’ changed from OFFLINE (COMMUNICATION_ERROR): Serial Error: Port /dev/ttyACM0 does not exist to U$
2018-02-22 17:52:39.557 [hingStatusInfoChangedEvent] - ‘zwave:serial_zstick:161be608c6c’ changed from OFFLINE (COMMUNICATION_ERROR): Serial Error: Port /dev/ttyACM0 does not exist to U$
2018-02-22 17:53:30.503 [hingStatusInfoChangedEvent] - ‘zwave:serial_zstick:b718da05’ changed from UNINITIALIZED to INITIALIZING
2018-02-22 17:53:30.521 [me.event.ThingUpdatedEvent] - Thing ‘zwave:serial_zstick:b718da05’ has been updated.
2018-02-22 17:53:30.527 [hingStatusInfoChangedEvent] - ‘zwave:serial_zstick:b718da05’ changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2018-02-22 17:53:30.540 [hingStatusInfoChangedEvent] - ‘zwave:serial_zstick:b718da05’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE (COMMUNICATION_ERROR): Ser$
2018-02-22 17:54:02.527 [hingStatusInfoChangedEvent] - ‘zwave:serial_zstick:161be6f82df’ changed from UNINITIALIZED to INITIALIZING
2018-02-22 17:54:37.894 [hingStatusInfoChangedEvent] - ‘zwave:serial_zstick:b718da05’ changed from OFFLINE (COMMUNICATION_ERROR): Serial Error: Port /dev/ttyACM0 does not exist to UNIN$
2018-02-22 17:54:37.896 [hingStatusInfoChangedEvent] - ‘zwave:serial_zstick:b718da05’ changed from OFFLINE (COMMUNICATION_ERROR): Serial Error: Port /dev/ttyACM0 does not exist to UNIN$
2018-02-22 18:04:09.810 [hingStatusInfoChangedEvent] - ‘zwave:serial_zstick:161be6f82df’ changed from INITIALIZING to UNINITIALIZED
2018-02-22 18:04:09.822 [hingStatusInfoChangedEvent] - ‘zwave:serial_zstick:161be6f82df’ changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2018-02-22 18:04:38.365 [hingStatusInfoChangedEvent] - ‘zwave:serial_zstick:161be6f82df’ changed from UNINITIALIZED to INITIALIZING
2018-02-22 18:05:15.643 [me.event.ThingUpdatedEvent] - Thing ‘zwave:serial_zstick:161be6f82df’ has been updated.
2018-02-22 18:05:47.557 [hingStatusInfoChangedEvent] - ‘zwave:serial_zstick:161be6f82df’ changed from INITIALIZING to REMOVING
2018-02-22 18:05:47.570 [hingStatusInfoChangedEvent] - ‘zwave:serial_zstick:161be6f82df’ changed from REMOVING to REMOVED
2018-02-22 18:05:47.611 [hingStatusInfoChangedEvent] - ‘zwave:serial_zstick:161be6f82df’ changed from REMOVED to UNINITIALIZED
2018-02-22 18:05:47.627 [hingStatusInfoChangedEvent] - ‘zwave:serial_zstick:161be6f82df’ changed from REMOVED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2018-02-22 18:06:05.742 [hingStatusInfoChangedEvent] - ‘zwave:serial_zstick:a4b26c03’ changed from UNINITIALIZED to INITIALIZING
