Hi
I’m using the latest 2.5.0 docker snapshot (latest == from yesterday evening), although I had the same problem with 2.5.0.M1. I know this did work OK at one time (2.4.0 I think).
I have some Fibaro FGS211 single relay switches, and I’m finding that although they have the correct Controller Updates association, and the controller receives commands from the devices when the switches are operated manually, the item state is not updated.
Here’s some output captured when manually toggling a bedroom light on and off from its switch, followed by doing the same with the bathroom light. The bedroom light (NODE 82) is an FGS213 and the bathroom light (NODE 15) is an FGS211. I have three FGS211 in the house and they all exhibit the same problem.
I can operate the lights fine from openHAB, which would seem to indicate that the Item is correctly associated with the Thing.
I have tried deleting the Thing from openHAB (NB not removing it from the Z-wave network) and re-adding it, that didn’t fix it.
I thought the issue would be that the Controller Updates group wasn’t set, but it looks like that’s not the case given that the messages appear in the zwave log in real time as the switch is changed.
This is the command I run, so that the output from the various logs will interleave on screen:
tail -F /opt/openhab/userdata/logs/events.log /opt/openhab/userdata/logs/zwave.log
Here’s the output:
==> /opt/openhab/userdata/logs/zwave.log <==
27-Mar-2019 12:12:09.736 [DEBUG] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0D 00 04 00 52 07 60 0D 01 01 25 03 FF 17
27-Mar-2019 12:12:09.737 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=82, callback=0, payload=00 52 07 60 0D 01 01 25 03 FF
27-Mar-2019 12:12:09.737 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=82, callback=0, payload=00 52 07 60 0D 01 01 25 03 FF
27-Mar-2019 12:12:09.737 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - lastTransaction null
27-Mar-2019 12:12:09.737 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 82: Application Command Request (ALIVE:DONE)
27-Mar-2019 12:12:09.737 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 82: resetResendCount initComplete=true isDead=false
27-Mar-2019 12:12:09.738 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 82: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
27-Mar-2019 12:12:09.738 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 82: Incoming command class COMMAND_CLASS_SWITCH_BINARY, endpoint 1
27-Mar-2019 12:12:09.738 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 82: SECURITY NOT required on COMMAND_CLASS_SWITCH_BINARY
27-Mar-2019 12:12:09.738 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 82: Received COMMAND_CLASS_SWITCH_BINARY V1 SWITCH_BINARY_REPORT
27-Mar-2019 12:12:09.738 [DEBUG] [rotocol.commandclass.ZWaveBinarySwitchCommandClass] - NODE 82: Switch Binary report, value = 255
27-Mar-2019 12:12:09.738 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 82: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
27-Mar-2019 12:12:09.739 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 82: Got a value event from Z-Wave network, endpoint=1, command class=COMMAND_CLASS_SWITCH_BINARY, value=255
27-Mar-2019 12:12:09.739 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 82: Updating channel state zwave:device:521e1911:node82:switch_binary1 to ON [OnOffType]
27-Mar-2019 12:12:09.739 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 82: Commands processed 1.
27-Mar-2019 12:12:09.739 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 82: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@2235a15.
27-Mar-2019 12:12:09.739 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
27-Mar-2019 12:12:09.739 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
27-Mar-2019 12:12:09.739 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
==> /opt/openhab/userdata/logs/events.log <==
2019-03-27 12:12:09.740 [vent.ItemStateChangedEvent] - Light_MasterBedroom_Ceiling changed from OFF to ON
27-Mar-2019 12:12:11.858 [DEBUG] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 12 00 04 00 52 0C 60 0D 01 01 32 02 21 32 01 08 00 00 F0
27-Mar-2019 12:12:11.858 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=82, callback=0, payload=00 52 0C 60 0D 01 01 32 02 21 32 01 08 00 00
27-Mar-2019 12:12:11.859 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=82, callback=0, payload=00 52 0C 60 0D 01 01 32 02 21 32 01 08 00 00
27-Mar-2019 12:12:11.859 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - lastTransaction null
27-Mar-2019 12:12:11.859 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 82: Application Command Request (ALIVE:DONE)
27-Mar-2019 12:12:11.859 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 82: resetResendCount initComplete=true isDead=false
27-Mar-2019 12:12:11.859 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 82: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
27-Mar-2019 12:12:11.859 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 82: Incoming command class COMMAND_CLASS_METER, endpoint 1
27-Mar-2019 12:12:11.859 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 82: SECURITY NOT required on COMMAND_CLASS_METER
27-Mar-2019 12:12:11.859 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 82: Received COMMAND_CLASS_METER V3 METER_REPORT
27-Mar-2019 12:12:11.860 [DEBUG] [ernal.protocol.commandclass.ZWaveMeterCommandClass] - NODE 82: Meter: Type=Electric(1), Scale=W(2), Value=26.4
27-Mar-2019 12:12:11.860 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 82: Got an event from Z-Wave network: ZWaveMeterValueEvent
27-Mar-2019 12:12:11.860 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 82: Got a value event from Z-Wave network, endpoint=1, command class=COMMAND_CLASS_METER, value=26.4
27-Mar-2019 12:12:11.860 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 82: Updating channel state zwave:device:521e1911:node82:meter_watts1 to 26.4 [DecimalType]
27-Mar-2019 12:12:11.860 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 82: Commands processed 1.
27-Mar-2019 12:12:11.860 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 82: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@28b52f83.
27-Mar-2019 12:12:11.860 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
27-Mar-2019 12:12:11.860 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
27-Mar-2019 12:12:11.860 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
27-Mar-2019 12:12:13.057 [DEBUG] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0D 00 04 00 52 07 60 0D 01 01 25 03 00 E8
27-Mar-2019 12:12:13.058 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=82, callback=0, payload=00 52 07 60 0D 01 01 25 03 00
27-Mar-2019 12:12:13.058 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=82, callback=0, payload=00 52 07 60 0D 01 01 25 03 00
27-Mar-2019 12:12:13.058 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - lastTransaction null
27-Mar-2019 12:12:13.058 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 82: Application Command Request (ALIVE:DONE)
27-Mar-2019 12:12:13.058 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 82: resetResendCount initComplete=true isDead=false
27-Mar-2019 12:12:13.058 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 82: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
27-Mar-2019 12:12:13.058 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 82: Incoming command class COMMAND_CLASS_SWITCH_BINARY, endpoint 1
27-Mar-2019 12:12:13.058 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 82: SECURITY NOT required on COMMAND_CLASS_SWITCH_BINARY
27-Mar-2019 12:12:13.059 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 82: Received COMMAND_CLASS_SWITCH_BINARY V1 SWITCH_BINARY_REPORT
27-Mar-2019 12:12:13.059 [DEBUG] [rotocol.commandclass.ZWaveBinarySwitchCommandClass] - NODE 82: Switch Binary report, value = 0
27-Mar-2019 12:12:13.059 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 82: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
27-Mar-2019 12:12:13.059 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 82: Got a value event from Z-Wave network, endpoint=1, command class=COMMAND_CLASS_SWITCH_BINARY, value=0
27-Mar-2019 12:12:13.059 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 82: Updating channel state zwave:device:521e1911:node82:switch_binary1 to OFF [OnOffType]
27-Mar-2019 12:12:13.059 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 82: Commands processed 1.
27-Mar-2019 12:12:13.059 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 82: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@6282439b.
27-Mar-2019 12:12:13.059 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
27-Mar-2019 12:12:13.060 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
27-Mar-2019 12:12:13.060 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-03-27 12:12:13.060 [vent.ItemStateChangedEvent] - Light_MasterBedroom_Ceiling changed from ON to OFF
27-Mar-2019 12:12:13.858 [DEBUG] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 12 00 04 00 52 0C 60 0D 01 01 32 02 21 32 00 00 00 00 F9
27-Mar-2019 12:12:13.858 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=82, callback=0, payload=00 52 0C 60 0D 01 01 32 02 21 32 00 00 00 00
27-Mar-2019 12:12:13.859 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=82, callback=0, payload=00 52 0C 60 0D 01 01 32 02 21 32 00 00 00 00
27-Mar-2019 12:12:13.859 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - lastTransaction null
27-Mar-2019 12:12:13.859 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 82: Application Command Request (ALIVE:DONE)
27-Mar-2019 12:12:13.859 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 82: resetResendCount initComplete=true isDead=false
27-Mar-2019 12:12:13.859 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 82: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
27-Mar-2019 12:12:13.859 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 82: Incoming command class COMMAND_CLASS_METER, endpoint 1
27-Mar-2019 12:12:13.859 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 82: SECURITY NOT required on COMMAND_CLASS_METER
27-Mar-2019 12:12:13.859 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 82: Received COMMAND_CLASS_METER V3 METER_REPORT
27-Mar-2019 12:12:13.859 [DEBUG] [ernal.protocol.commandclass.ZWaveMeterCommandClass] - NODE 82: Meter: Type=Electric(1), Scale=W(2), Value=0E+1
27-Mar-2019 12:12:13.860 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 82: Got an event from Z-Wave network: ZWaveMeterValueEvent
27-Mar-2019 12:12:13.860 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 82: Got a value event from Z-Wave network, endpoint=1, command class=COMMAND_CLASS_METER, value=0E+1
27-Mar-2019 12:12:13.860 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 82: Updating channel state zwave:device:521e1911:node82:meter_watts1 to 0 [DecimalType]
27-Mar-2019 12:12:13.860 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 82: Commands processed 1.
27-Mar-2019 12:12:13.860 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 82: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@247f1391.
27-Mar-2019 12:12:13.860 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
27-Mar-2019 12:12:13.860 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
27-Mar-2019 12:12:13.860 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
27-Mar-2019 12:12:16.877 [DEBUG] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 0F 03 25 03 FF 27
27-Mar-2019 12:12:16.878 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=15, callback=0, payload=00 0F 03 25 03 FF
27-Mar-2019 12:12:16.878 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=15, callback=0, payload=00 0F 03 25 03 FF
27-Mar-2019 12:12:16.878 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - lastTransaction null
27-Mar-2019 12:12:16.878 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 15: Application Command Request (ALIVE:DONE)
27-Mar-2019 12:12:16.878 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 15: resetResendCount initComplete=true isDead=false
27-Mar-2019 12:12:16.878 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 15: Incoming command class COMMAND_CLASS_SWITCH_BINARY, endpoint 0
27-Mar-2019 12:12:16.879 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
27-Mar-2019 12:12:16.879 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 15: Received COMMAND_CLASS_SWITCH_BINARY V1 SWITCH_BINARY_REPORT
27-Mar-2019 12:12:16.879 [DEBUG] [rotocol.commandclass.ZWaveBinarySwitchCommandClass] - NODE 15: Switch Binary report, value = 255
27-Mar-2019 12:12:16.879 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
27-Mar-2019 12:12:16.879 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 15: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SWITCH_BINARY, value=255
27-Mar-2019 12:12:16.879 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 15: Commands processed 1.
27-Mar-2019 12:12:16.879 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 15: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@3c1416f9.
27-Mar-2019 12:12:16.879 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
27-Mar-2019 12:12:16.880 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
27-Mar-2019 12:12:16.880 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
27-Mar-2019 12:12:16.880 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
# NOTE: at this point, I would expect to see an entry in events.log saying Light_MasterEnsuite_Ceiling changed from OFF to ON
27-Mar-2019 12:12:22.948 [DEBUG] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 0F 03 25 03 00 D8
27-Mar-2019 12:12:22.949 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=15, callback=0, payload=00 0F 03 25 03 00
27-Mar-2019 12:12:22.949 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=15, callback=0, payload=00 0F 03 25 03 00
27-Mar-2019 12:12:22.949 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - lastTransaction null
27-Mar-2019 12:12:22.949 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 15: Application Command Request (ALIVE:DONE)
27-Mar-2019 12:12:22.949 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 15: resetResendCount initComplete=true isDead=false
27-Mar-2019 12:12:22.949 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 15: Incoming command class COMMAND_CLASS_SWITCH_BINARY, endpoint 0
27-Mar-2019 12:12:22.949 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
27-Mar-2019 12:12:22.949 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 15: Received COMMAND_CLASS_SWITCH_BINARY V1 SWITCH_BINARY_REPORT
27-Mar-2019 12:12:22.950 [DEBUG] [rotocol.commandclass.ZWaveBinarySwitchCommandClass] - NODE 15: Switch Binary report, value = 0
27-Mar-2019 12:12:22.950 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
27-Mar-2019 12:12:22.950 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 15: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SWITCH_BINARY, value=0
27-Mar-2019 12:12:22.950 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 15: Commands processed 1.
27-Mar-2019 12:12:22.950 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 15: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@3ddcffcf.
27-Mar-2019 12:12:22.950 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
27-Mar-2019 12:12:22.950 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
27-Mar-2019 12:12:22.950 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
# NOTE: at this point, I would expect to see an entry in events.log saying Light_MasterEnsuite_Ceiling changed from ON to OFF
