Hello all, I have a problem with my OH setup that I can’t seem to be able to crack: I have a FGS223 (Fibaro 2-channel switch, node 21). I use S1 input to directly control the light attached to it. I want to use S2 input to control another device (ZW096 smart switch by aeotec; node 25).
On node 21 I have set association group “4: On/Off S2” to point to Node 25 and I expected that now S2 will control switch on node 25. Problem is that it isn’t working.
Note that I can see the status of node21 S2 in the controller (paper ui, …) and I can also control node 25 switch from the controller.
I have also tried to associate the switch with another switch (another FGS223) in my home, with the same result - node21 S2 doesn’t switch this other switch.
At this moment I’m quite lost as to what could possibly be wrong or how I can diagnose the problem. Any suggestions anyone?
Running OH 2.4.0.
