Does your keyfob work ok now with OpenHAB, I get 2 channels: Scene number and battery, and these never change regardless wich button is pressed on the fob.
Yes it does.
Scene numbers 1.0 to 6.0 and battery. Although battery does not show in all
gui’s eg not in Android ( where I am now)
Trick I found to be good, was set inclusion time to 60 sec, and wake the
key fob up several times immediately after inclusion. Then delete it, and
rescan.
I currently use the experimental binding which supports security and
snapshot 2.1
2.1.0-SNAPSHOT
Build #858
openhab> system:version
4.0.8
I use the experiemental binding … Not sure about version on that one feature:info openhab-binding-zwave
Feature openhab-binding-zwave 2.1.0.SNAPSHOT
Description:
Z-Wave Binding
Feature has no configuration
Feature has no configuration files
Feature depends on:
openhab-runtime-base 0.0.0
openhab-transport-serial 0.0.0
Feature contains followed bundles:
mvn:org.openhab.binding/org.openhab.binding.zwave/2.1.0-SNAPSHOT start-level=80
Feature has no conditionals.
hm,…i’m happy owner of the KeyFOB since today…on OH1.83 with Binding 1.11 Snapshot but the RemoteControl is not recognized by the system…only named "Fibaro Systems ID:1000 Type 1001). Also i cannot see any configuration items…so its empty.
Any Idea? I already woke up the keyfob several times…nothing…i’m rather close to the controller…about 3 meters.
Upgrade to 2.1. I had the same issues with OH1.9, and logged a ticket - but rightly so, cd-jackson doesn’t want to spend time working on the zwave database for older versions of OH. I upgraded and still have issue with OH2.1, so have just updated the database with the new device id. So hoping this will be fixed for me soon.
I just can’t get the locking method to work.
What I’ve done so far:
Through HABmin, I’ve put parameter 1 to 54 (= 2 times button X)
Parameter 2 to 1546 (= 10 seconds and button X).
HABmin is now ‘waiting’
I wake up the device (button 0 and X)
The status HABmin ‘waiting’ goes away (after refresh browser)
But no luck, the locking scene isn’t working.
ps The guy that sold me this told me that he did succesfully configured on a demo device the lock function through the ‘fibaro home center’. So he thought the problem could be in the configuration way? So before we start to debug: did anybody got this lock config working?
For reference, my items, rules…
And with following item&rule:
rule "remote"
Item Sch_Remote received update
if (Sch_Remote.state == 1.0) {
logInfo("Remotes", "Remote nr 1 push")
sendCommand( Light1, ON )
Thread::sleep(2000)
sendCommand( Light1, OFF )
if (Sch_Remote.state == 2.0) {
logInfo("Remotes", "Remote nr 2 push")
The keyfob can’t be configured to avoid unwanted key press.
You need to push a certain key combination before the actual key push will be forwarded to the zwave network.
For this, you need to put parameter 1 to a certain value (in my example 54).
But when I try to configure this parameter, it’s like the keyfob doesn’t pick up the value from openhab.
I was able to include the KeyFob and define the channels. I’m receiving battery updates, but not the button clicks (scene ids). I did several wakeups, but no change. Pressing a button is not reported to openhab even the led didn’t blink. Any idea?
2.1 stable shows the same behaviour: I see the wakeup in the logs, OH shows the battery state, but when pressing a key everything stays silent. It feels like the knob is in locking mode, but parameter 1,2 have been set to 0/0 (default was 0/60)
