@chris any idea?
I donât really know the device, but I would check the associations are correctly set so that reports are sent to the controller. (Iâm assuming there are association groups in this device of course ).
I found the manual here:
but itâs really confusing, could you have a look? Iâm just using factory settings, so I would expect the default is that all keys are send to the controller.
@chimera doesnât mentioned something special when describing how to intercept the events.
@brononius sayed âFor me, itâs working fine in OH2, out of the boxâŠâ
I just want to receive the 6 scene IDs when pressing the button - who is able to remember for combinations?
@chris: You were right, the association group has to be explicitly set to the openHAB controller
1: Lifeline -> openHAB Controller and
2: Square - On/Off -> openHAB Controller
etc. - thatâs strange:roll_eyes:
but thanks for the tip!!
markus,
Can you elaborate a bit more what you did in order make the keyfob send a keyscen number to the item.
After I added the device in habmin interface I had it in a state that any button pressed was not giving any led light confirmation. And the item
Number KeyFob_scene "Keyfob scene [%.0f]" {channel="zwave:device:1580d5a6c7b:node6:scene_number"}
Was not up updating. However the device was on line all the time in PAPER UI or Habmin.
For your last update I did added the the associations in HABmin for Lifeline and buttons on/off to openhab controler.
Now I get green led on the button presses but still I dont get the Item to update.
But the changes on the assosiations are in the pending state.
Do I need any extra step to get it working?
What interface did you use to make the changes?
TIA
@xsherlock I donât know what markus did, but in case you still need it I can tell you what I did in openhab2
Before I start:
I use only Habmin to find and include the z-wave devices as things and (and itâs important!) for setting the z-wave parameters. Then I use configuration files for everything else, but I do sometimes peek into PaperUI to see the exact channel name: battery level for instance is called âbattery-levelâ and not âbattery_levelâ, as one would expect.
1 â ensure your thing is discovered and so on.
2 â configure the Keyfob according to the documentation of its manufacturer. Get the manual from their website -> support -> manuals etc.
You have to check every parameter starting from the 3rd one â the first and the second I will mention at the end. Reading through the manual you can decide whether you want to use multiple button-press, press-and-hold and sequences of 2 â 5 buttons. You donât have to use combinations and so on. You also donât need to use associations, but you can - I will mention it at the end of this post.
3 - you need an item like this one:
Number key_fob "Keyfob" <contact> { channel="zwave:device:ZWAVE_DEVICE:NODE_ID:scene_number" }
And if you want, also one like this:
Number key_fob_batt "Keyfob battery" <battery> { channel="zwave:device:ZWAVE_DEVICE:NODE_ID:battery-level" }
4 - After you saved those items and assuming your parameters are all set well, you need to press the circle and the plus keys on your keyfob simultaneously. It will be confirmed by white light flashing a few times. It is supposed to wake the keyfob up and allow it to get the settings from openhab. You can check in events.log if the scenes are updated and they really should be. Sometimes itâs good to reload the Habmin to see all changes there.
5 - create a keyfob.rules file according to this example:
rule "keyfob in use"
Item key_fob received update
if (key_fob.state == 1.0) { // KeyFob square pressed once
if (key_fob.state == 1.1) { // KeyFob square released
if (key_fob.state == 1.2) { // KeyFob square hold
if (key_fob.state == 1.3) { // KeyFob square pressed twice
if (key_fob.state == 1.4) { // KeyFob square pressed 3 times
( repeat for each button i.e. 2.0, 2.1, 2.2, 2.3, 2.4, 3.0 etc. up to 6.4 )
if (key_fob.state == 7.0) { // First sequence defined in parameters
if (key_fob.state == 8.0) { // Second sequence defined in parameters
( repeat for all six sequences up to 12.0 )
And that should do it. You donât need to use associations - it will work fine without it.
However you can also set associations in habmin according to you needs. I for instance use three buttons for three different dimmers, so I had to set the multilevel association. Markus used the on/off association if Iâm not mistaken. You can set only for the buttons you need and let others not associated - itâs fine and itâs all up to you.
However, if you set any you should rather not use the respective scene number in the .rules file.
It is all working well including associations, multi-press and combinations.
There is a dark side as well. Without the working lock function the keyfob has a very, very limited utility. You literally cannot put it in the pocket: there is no way you donât push the buttons accidentally.
According to Fibaro documentation for the lock to be set you need to:
- set the unlocking sequence in parameter 1
- set the lock timeout and lock button in parameter 2
- send a PROTECTION class from the controller to the keyfob.
Sadly the last one seems not to be available in openhabâŠ
Just yesterday i sorted it out the brute force way. New RPI3, new openhabian install with stable 2.1 and I just put the usb zwave dongle from old setup , configured serial port with old identifier, and I had it up and running without setting associations.
Thanks for the hint that state is actually a float, this will be super useful.
It all works with all nodes online but I get an error in the logs that I do not understand. That is a bit off topic
2017-09-29 17:33:39.965 [ERROR] [ve.internal.protocol.ZWaveController] - Exception during ZWave thread: Input 2. {}
java.lang.IllegalStateException: Could not update state, because callback is missing
Continuing the discussion from Fibar Group Keyfob : FGKF-601 (no node.xml):
Had the same problem.
Protection class not availble.
Used my Domoticz install to set it. It has the function to set it.
Works like a charm now in openhab.
