- Platform information:
- Hardware: CPUArchitecture/RAM/storage
- OS: what OS is used and which version
- Java Runtime Environment: which java platform is used and what version
- openHAB version:
- Issue of the topic: please be detailed explaining your issue
- Please post configurations (if applicable):
- Items configuration related to the issue
- Sitemap configuration related to the issue
- Rules code related to the issue
- Services configuration related to the issue
- If logs where generated please post these here using code fences:
Hi All,
I can use some help. I have added a Fibaro Motion sensor to Openhab2. Unfortunately i have issues switching the lights on when motion is detected. I have below items / sitemap and rules. Strange thing is that when motion is detected i can see that it switches the toggle in the sitemap but somehow it refuses to turn on the light. Already tried a lot of options like “received update” or “changed” or “changed from 0 to 1” but nothing works. Anyone any idea??
Item:
Switch Motion_Alarm { channel=“zwave:device:0cd1a64c:node2:sensor_binary” }
Sitemap:
Frame {
// Motion
Switch item= Motion_Alarm
Rule:
rule "Motion_Lights"
Switch Motion_Alarm changed from OFF to ON
sendCommand(Office_Toggle, ON)
try instead of
this code
Item Motion_Alarm changed from OFF to ON
Ciao
HFM
Thanks a lot HFM!! Works now!!
You are welcome!
