I don’t think this is an OpenHab question directly, but you guys are the most Z-Wave friendly bunch I know…
I have a Fibaro Dimmer 2 connected to a traditional light switch (not momentary, etc.) on S1. This works fine. I’m trying to use associations to get a couple of lamps (on TKB TZ68 plugin switches) to follow the state of the main lights. The lamps work fine in their own right. I realise that the lights are dimmable and the lamps are not, but I’m using association group 2 which should just send ON/OFF commands based on the S1 input.
I’ve set:
- 21 (Value sent to associated devices on single click) to “Dimmer 2 state synchronizes brightness level”
- 24 (Command frames sent in 2nd and 3rd assoc group) to “all actions send to association groups”
- 27 (Associations in Z-Wave network security mode) to “all groups (II-V) sent as non-secure”
I’m pretty sure this is set up right. I can see the associations in group 2 in OH, both in PaperUI and Habmin. (I’m aware that there are occasional rendering errors on the UI). I’ve reinitialised the dimmer and put the logs through @chris’s log viewer, and it seems that the associations are set correctly.
However… when I operate the lights from the switch, the lamps don’t react at all.
I’m using OH 2.4.0 Build #1454.
Any suggestions on where to look next?
