Hey guys. The Fibaro Dimmer 2 is driving me nuts.
My desired Setup:
One FGD212 is in the Bathrom controlling the lights there.
A second FGD212 is installed in the Bedroom, controlling thebedroom lights. WIth S2 on that Dimmer I want to be able to also control the Bathroom Dimmer. That works somewhat well with Associations but I want to integrate them all in openhab.
I also own a Switch 2 and all readouts work perfectly there - When use the Wall switch the log happily returns:
2018-02-11 23:49:09.723 [ome.event.ItemCommandEvent] - Item 'wz_switch2_switch2' received command ON
But that does not happen with S2 on my Dimmer. What am I doing wrong? I tried nearly everything.
I installed the FGD212 via Thing search and then manually added an .items file.
These are my items for the Dimmer:
////Dimmer SZ
Dimmer sz_dimmer2_dimmer "Dimmer" (Schlafzimmer) {channel="zwave:device:zwave_usb:node8:switch_dimmer"}
Switch sz_dimmer2_switch "Dimmer An/Aus" (Schlafzimmer) {channel="zwave:device:zwave_usb:node8:switch_dimmer"}
Dimmer sz_dimmer2_dimmer1 "Dimmer 1" (Schlafzimmer) {channel="zwave:device:zwave_usb:node8:switch_dimmer1"}
Switch sz_dimmer2_switch1 "Switch 1" (Schlafzimmer) {channel="zwave:device:zwave_usb:node8:switch_dimmer1"}
Switch sz_dimmer2_switch2 "Switch 2" (Schlafzimmer) {channel="zwave:device:zwave_usb:node8:switch_dimmer2"}
Dimmer sz_dimmer2_dimmer2 "Dimmer2" (Schlafzimmer) {channel="zwave:device:zwave_usb:node8:switch_dimmer2"}
Number sz_dimmer2_scene "Scene Number" (Schlafzimmer) {channel="zwave:device:zwave_usb:node8:scene_number"}
Number sz_dimmer2_sensor "Sensor" (Schlafzimmer) {channel="zwave:device:zwave_usb:node8:sensor_power"}
Number sz_dimmer2_sensor1 "Sensor 1" (Schlafzimmer) {channel="zwave:device:zwave_usb:node8:sensor_power1"}
Number sz_dimmer2_kwh "Verbrauch in KwH" (Schlafzimmer) {channel="zwave:device:zwave_usb:node8:meter_kwh"}
Number sz_dimmer2_watts "Leistung in Watt" (Schlafzimmer) {channel="zwave:device:zwave_usb:node8:meter_watts"}
Switch sz_dimmer2_reset "Verbrauch zurückzestzen"(Schlafzimmer) {channel="zwave:device:zwave_usb:node8:meter_reset"}
Log File only returns the following when I press S1 Wall switch:
2018-02-11 23:15:30.985 [vent.ItemStateChangedEvent] - sz_dimmer2_scene changed from 26 to 16
I would prefer it to state
sz_dimmer2_switch2 received command ON
or something similar. When I use the switch on my Sitemap the update is working. but then with associations the Bathroom lights will not turn on. . .
I don’t feel like using the scene selection in a rule.
Do you guys have any idea??
Thanks!
