In PaperUI under bindings it says 2.3.0 with the option to uninstall. Not sure if that specific version is installed. openHAB 2.3.0-1.
The error in the previous reply is probably unrelated.
Here’s all debug log for the second I did the inlusion. I don’t read what’s relevant or not very well and there’s a LOT of debug code. Let me know if I cut the debug code too short or if the relevant part isn’t there at all.
Node35 appeared after the inclusion. Nothing happens (in the log) when I click the physical switch. I figure a next logical testing step would be to connect a physical lamp to the switch. Could the fact that nothings connected to it matter?
Right now it seems like the node only creates log items during exclusion and inclusion.
2018-06-24 17:24:44.507 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@883b2f[p=0,l=200,c=32768,r=200]={<<<event: message\nda...usInfoEvent"}\n\n>>>1 Wall Switch\\",\\...WdVsL+xokX6hp4b} complete=false committing=false callback=Blocker@1f12879{null}
2018-06-24 17:24:44.512 [DEBUG] [.eclipse.jetty.server.HttpConnection] - org.eclipse.jetty.server.HttpConnection$SendCallback@f7496f[PROCESSING][i=null,cb=Blocker@1f12879{null}] generate: FLUSH (null,[p=0,l=200,c=32768,r=200],false)@COMMITTED
2018-06-24 17:24:44.515 [DEBUG] [io.socket.client.Manager ] - writing packet io.socket.parser.Packet@eeb9ce
2018-06-24 17:24:44.520 [DEBUG] [io.socket.parser.Parser ] - encoding packet io.socket.parser.Packet@eeb9ce
2018-06-24 17:24:44.519 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - write: WriteFlusher@40f1bf{IDLE} [HeapByteBuffer@8d85b5[p=0,l=6,c=1024,r=6]={<<<\r\nC8\r\n>>>\n\n\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00},DirectByteBuffer@883b2f[p=0,l=200,c=32768,r=200]={<<<event: message\nda...usInfoEvent"}\n\n>>>1 Wall Switch\\",\\...WdVsL+xokX6hp4b}]
2018-06-24 17:24:44.523 [DEBUG] [io.socket.parser.Parser ] - encoded io.socket.parser.Packet@eeb9ce as 2["itemupdate",{"itemName":"FF_Kitchen_CC_Idle","itemStatus":"ON"}]
2018-06-24 17:24:44.526 [DEBUG] [io.socket.engineio.client.Socket ] - flushing 1 packets in socket
2018-06-24 17:24:44.529 [DEBUG] [io.socket.client.Manager ] - writing packet io.socket.parser.Packet@294a23
2018-06-24 17:24:44.531 [DEBUG] [io.socket.parser.Parser ] - encoding packet io.socket.parser.Packet@294a23
2018-06-24 17:24:44.530 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - update WriteFlusher@40f1bf{WRITING}:IDLE-->WRITING
2018-06-24 17:24:44.534 [DEBUG] [io.socket.parser.Parser ] - encoded io.socket.parser.Packet@294a23 as 2["itemupdate",{"itemName":"FF_Kitchen_CC_Volum","itemStatus":"1"}]
2018-06-24 17:24:44.537 [DEBUG] [io.socket.engineio.client.Socket ] - flushing 1 packets in socket
2018-06-24 17:24:44.541 [DEBUG] [org.eclipse.jetty.io.ChannelEndPoint] - flushed 206 SelectChannelEndPoint@1205f5e{/192.168.0.8:53712<->8080,Open,in,out,-,W,7067/30000,HttpConnection@d70d76}{io=0/0,kio=0,kro=1}
2018-06-24 17:24:44.544 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - Flushed=true 6/6+1 WriteFlusher@40f1bf{WRITING}
2018-06-24 17:24:44.546 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - update WriteFlusher@40f1bf{IDLE}:WRITING-->IDLE
2018-06-24 17:24:44.549 [DEBUG] [.eclipse.jetty.server.HttpConnection] - org.eclipse.jetty.server.HttpConnection$SendCallback@f7496f[PROCESSING][i=null,cb=Blocker@1f12879{null}] generate: DONE (null,[p=200,l=200,c=32768,r=0],false)@COMMITTED
2018-06-24 17:24:44.553 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@151b781[p=0,l=200,c=32768,r=200]={<<<event: message\nda...usInfoEvent"}\n\n>>>1 Wall Switch\\",\\..."zwave_class_sp} complete=false committing=false callback=Blocker@19b5d29{null}
2018-06-24 17:24:44.556 [DEBUG] [.eclipse.jetty.server.HttpConnection] - org.eclipse.jetty.server.HttpConnection$SendCallback@1632f71[PROCESSING][i=null,cb=Blocker@19b5d29{null}] generate: FLUSH (null,[p=0,l=200,c=32768,r=200],false)@COMMITTED
2018-06-24 17:24:44.558 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - write: WriteFlusher@8d500c{IDLE} [HeapByteBuffer@692140[p=0,l=6,c=1024,r=6]={<<<\r\nC8\r\n>>>\n\n\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00},DirectByteBuffer@151b781[p=0,l=200,c=32768,r=200]={<<<event: message\nda...usInfoEvent"}\n\n>>>1 Wall Switch\\",\\..."zwave_class_sp}]
2018-06-24 17:24:44.561 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - update WriteFlusher@8d500c{WRITING}:IDLE-->WRITING
2018-06-24 17:24:44.564 [DEBUG] [org.eclipse.jetty.io.ChannelEndPoint] - flushed 206 SelectChannelEndPoint@1dfc61{/192.168.0.8:53989<->8080,Open,in,out,-,W,7070/30000,HttpConnection@1d73ad8}{io=0/0,kio=0,kro=1}
2018-06-24 17:24:44.567 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - Flushed=true 6/6+1 WriteFlusher@8d500c{WRITING}
2018-06-24 17:24:44.569 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - update WriteFlusher@8d500c{IDLE}:WRITING-->IDLE
2018-06-24 17:24:44.572 [DEBUG] [.eclipse.jetty.server.HttpConnection] - org.eclipse.jetty.server.HttpConnection$SendCallback@1632f71[PROCESSING][i=null,cb=Blocker@19b5d29{null}] generate: DONE (null,[p=200,l=200,c=32768,r=0],false)@COMMITTED
2018-06-24 17:24:44.576 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@883b2f[p=0,l=149,c=32768,r=149]={<<<event: message\nda...mStateEvent"}\n\n>>>etail\\":\\"NONE\\"}...WdVsL+xokX6hp4b} complete=false committing=false callback=Blocker@1f12879{null}
2018-06-24 17:24:44.578 [DEBUG] [.eclipse.jetty.server.HttpConnection] - org.eclipse.jetty.server.HttpConnection$SendCallback@f7496f[PROCESSING][i=null,cb=Blocker@1f12879{null}] generate: FLUSH (null,[p=0,l=149,c=32768,r=149],false)@COMMITTED
2018-06-24 17:24:44.581 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - write: WriteFlusher@40f1bf{IDLE} [HeapByteBuffer@8d85b5[p=0,l=6,c=1024,r=6]={<<<\r\n95\r\n>>>\n\n\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00},DirectByteBuffer@883b2f[p=0,l=149,c=32768,r=149]={<<<event: message\nda...mStateEvent"}\n\n>>>etail\\":\\"NONE\\"}...WdVsL+xokX6hp4b}]
2018-06-24 17:24:44.583 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - update WriteFlusher@40f1bf{WRITING}:IDLE-->WRITING
2018-06-24 17:24:44.585 [DEBUG] [org.eclipse.jetty.io.ChannelEndPoint] - flushed 155 SelectChannelEndPoint@1205f5e{/192.168.0.8:53712<->8080,Open,in,out,-,W,42/30000,HttpConnection@d70d76}{io=0/0,kio=0,kro=1}
2018-06-24 17:24:44.587 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - Flushed=true 6/6+1 WriteFlusher@40f1bf{WRITING}
2018-06-24 17:24:44.588 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - update WriteFlusher@40f1bf{IDLE}:WRITING-->IDLE
2018-06-24 17:24:44.590 [DEBUG] [.eclipse.jetty.server.HttpConnection] - org.eclipse.jetty.server.HttpConnection$SendCallback@f7496f[PROCESSING][i=null,cb=Blocker@1f12879{null}] generate: DONE (null,[p=149,l=149,c=32768,r=0],false)@COMMITTED
2018-06-24 17:24:44.591 [DEBUG] [org.eclipse.jetty.io.IdleTimeout ] - SelectChannelEndPoint@1205f5e{/192.168.0.8:53712<->8080,Open,in,out,-,-,4/30000,HttpConnection@d70d76}{io=0/0,kio=0,kro=1} idle timeout check, elapsed: 4 ms, remaining: 29996 ms
2018-06-24 17:24:44.593 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@151b781[p=0,l=149,c=32768,r=149]={<<<event: message\nda...mStateEvent"}\n\n>>>etail\\":\\"NONE\\"}..."zwave_class_sp} complete=false committing=false callback=Blocker@19b5d29{null}
2018-06-24 17:24:44.594 [DEBUG] [.eclipse.jetty.server.HttpConnection] - org.eclipse.jetty.server.HttpConnection$SendCallback@1632f71[PROCESSING][i=null,cb=Blocker@19b5d29{null}] generate: FLUSH (null,[p=0,l=149,c=32768,r=149],false)@COMMITTED
2018-06-24 17:24:44.596 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - write: WriteFlusher@8d500c{IDLE} [HeapByteBuffer@692140[p=0,l=6,c=1024,r=6]={<<<\r\n95\r\n>>>\n\n\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00},DirectByteBuffer@151b781[p=0,l=149,c=32768,r=149]={<<<event: message\nda...mStateEvent"}\n\n>>>etail\\":\\"NONE\\"}..."zwave_class_sp}]
2018-06-24 17:24:44.598 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - update WriteFlusher@8d500c{WRITING}:IDLE-->WRITING
2018-06-24 17:24:44.600 [DEBUG] [org.eclipse.jetty.io.ChannelEndPoint] - flushed 155 SelectChannelEndPoint@1dfc61{/192.168.0.8:53989<->8080,Open,in,out,-,W,33/30000,HttpConnection@1d73ad8}{io=0/0,kio=0,kro=1}
2018-06-24 17:24:44.601 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - Flushed=true 6/6+1 WriteFlusher@8d500c{WRITING}
2018-06-24 17:24:44.603 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - update WriteFlusher@8d500c{IDLE}:WRITING-->IDLE
2018-06-24 17:24:44.605 [DEBUG] [.eclipse.jetty.server.HttpConnection] - org.eclipse.jetty.server.HttpConnection$SendCallback@1632f71[PROCESSING][i=null,cb=Blocker@19b5d29{null}] generate: DONE (null,[p=149,l=149,c=32768,r=0],false)@COMMITTED
2018-06-24 17:24:44.608 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@883b2f[p=0,l=151,c=32768,r=151]={<<<event: message\nda...mStateEvent"}\n\n>>>ail\\":\\"NONE\\"}",...WdVsL+xokX6hp4b} complete=false committing=false callback=Blocker@1f12879{null}
2018-06-24 17:24:44.609 [DEBUG] [.eclipse.jetty.server.HttpConnection] - org.eclipse.jetty.server.HttpConnection$SendCallback@f7496f[PROCESSING][i=null,cb=Blocker@1f12879{null}] generate: FLUSH (null,[p=0,l=151,c=32768,r=151],false)@COMMITTED
2018-06-24 17:24:44.611 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - write: WriteFlusher@40f1bf{IDLE} [HeapByteBuffer@8d85b5[p=0,l=6,c=1024,r=6]={<<<\r\n97\r\n>>>\n\n\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00},DirectByteBuffer@883b2f[p=0,l=151,c=32768,r=151]={<<<event: message\nda...mStateEvent"}\n\n>>>ail\\":\\"NONE\\"}",...WdVsL+xokX6hp4b}]
2018-06-24 17:24:44.612 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - update WriteFlusher@40f1bf{WRITING}:IDLE-->WRITING
2018-06-24 17:24:44.614 [DEBUG] [org.eclipse.jetty.io.ChannelEndPoint] - flushed 157 SelectChannelEndPoint@1205f5e{/192.168.0.8:53712<->8080,Open,in,out,-,W,27/30000,HttpConnection@d70d76}{io=0/0,kio=0,kro=1}
2018-06-24 17:24:44.616 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - Flushed=true 6/6+1 WriteFlusher@40f1bf{WRITING}
2018-06-24 17:24:44.617 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - update WriteFlusher@40f1bf{IDLE}:WRITING-->IDLE
2018-06-24 17:24:44.619 [DEBUG] [.eclipse.jetty.server.HttpConnection] - org.eclipse.jetty.server.HttpConnection$SendCallback@f7496f[PROCESSING][i=null,cb=Blocker@1f12879{null}] generate: DONE (null,[p=151,l=151,c=32768,r=0],false)@COMMITTED
2018-06-24 17:24:44.621 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@151b781[p=0,l=151,c=32768,r=151]={<<<event: message\nda...mStateEvent"}\n\n>>>ail\\":\\"NONE\\"}",..."zwave_class_sp} complete=false committing=false callback=Blocker@19b5d29{null}
2018-06-24 17:24:44.623 [DEBUG] [.eclipse.jetty.server.HttpConnection] - org.eclipse.jetty.server.HttpConnection$SendCallback@1632f71[PROCESSING][i=null,cb=Blocker@19b5d29{null}] generate: FLUSH (null,[p=0,l=151,c=32768,r=151],false)@COMMITTED
2018-06-24 17:24:44.624 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - write: WriteFlusher@8d500c{IDLE} [HeapByteBuffer@692140[p=0,l=6,c=1024,r=6]={<<<\r\n97\r\n>>>\n\n\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00},DirectByteBuffer@151b781[p=0,l=151,c=32768,r=151]={<<<event: message\nda...mStateEvent"}\n\n>>>ail\\":\\"NONE\\"}",..."zwave_class_sp}]
2018-06-24 17:24:44.626 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - update WriteFlusher@8d500c{WRITING}:IDLE-->WRITING
2018-06-24 17:24:44.628 [DEBUG] [org.eclipse.jetty.io.ChannelEndPoint] - flushed 157 SelectChannelEndPoint@1dfc61{/192.168.0.8:53989<->8080,Open,in,out,-,W,27/30000,HttpConnection@1d73ad8}{io=0/0,kio=0,kro=1}
2018-06-24 17:24:44.629 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - Flushed=true 6/6+1 WriteFlusher@8d500c{WRITING}
2018-06-24 17:24:44.631 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - update WriteFlusher@8d500c{IDLE}:WRITING-->IDLE
2018-06-24 17:24:44.633 [DEBUG] [.eclipse.jetty.server.HttpConnection] - org.eclipse.jetty.server.HttpConnection$SendCallback@1632f71[PROCESSING][i=null,cb=Blocker@19b5d29{null}] generate: DONE (null,[p=151,l=151,c=32768,r=0],false)@COMMITTED
2018-06-24 17:24:44.803 [DEBUG] [su.litvak.chromecast.api.v2.Channel ] - --> {"type":"GET_STATUS","requestId":172}
2018-06-24 17:24:44.892 [DEBUG] [su.litvak.chromecast.api.v2.Channel ] - <-- {"requestId":172,"status":{"volume":{"controlType":"attenuation","level":1.0,"muted":false,"stepInterval":0.05000000074505806}},"type":"RECEIVER_STATUS"}
2018-06-24 17:24:44.903 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@883b2f[p=0,l=200,c=32768,r=200]={<<<event: message\nda...usInfoEvent"}\n\n>>>1 Wall Switch\\",\\...WdVsL+xokX6hp4b} complete=false committing=false callback=Blocker@1f12879{null}
2018-06-24 17:24:44.906 [DEBUG] [.eclipse.jetty.server.HttpConnection] - org.eclipse.jetty.server.HttpConnection$SendCallback@f7496f[PROCESSING][i=null,cb=Blocker@1f12879{null}] generate: FLUSH (null,[p=0,l=200,c=32768,r=200],false)@COMMITTED
2018-06-24 17:24:44.909 [DEBUG] [io.socket.client.Manager ] - writing packet io.socket.parser.Packet@55931d
2018-06-24 17:24:44.912 [DEBUG] [io.socket.parser.Parser ] - encoding packet io.socket.parser.Packet@55931d
2018-06-24 17:24:44.909 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - write: WriteFlusher@40f1bf{IDLE} [HeapByteBuffer@8d85b5[p=0,l=6,c=1024,r=6]={<<<\r\nC8\r\n>>>\n\n\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00},DirectByteBuffer@883b2f[p=0,l=200,c=32768,r=200]={<<<event: message\nda...usInfoEvent"}\n\n>>>1 Wall Switch\\",\\...WdVsL+xokX6hp4b}]
2018-06-24 17:24:44.914 [DEBUG] [io.socket.parser.Parser ] - encoded io.socket.parser.Packet@55931d as 2["itemupdate",{"itemName":"FF_Stue_CC_Idle","itemStatus":"ON"}]
2018-06-24 17:24:44.916 [DEBUG] [io.socket.engineio.client.Socket ] - flushing 1 packets in socket
2018-06-24 17:24:44.916 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - update WriteFlusher@40f1bf{WRITING}:IDLE-->WRITING
2018-06-24 17:24:44.919 [DEBUG] [org.eclipse.jetty.io.ChannelEndPoint] - flushed 206 SelectChannelEndPoint@1205f5e{/192.168.0.8:53712<->8080,Open,in,out,-,W,304/30000,HttpConnection@d70d76}{io=0/0,kio=0,kro=1}
2018-06-24 17:24:44.922 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - Flushed=true 6/6+1 WriteFlusher@40f1bf{WRITING}
2018-06-24 17:24:44.923 [DEBUG] [io.socket.client.Manager ] - writing packet io.socket.parser.Packet@927227
2018-06-24 17:24:44.925 [DEBUG] [io.socket.parser.Parser ] - encoding packet io.socket.parser.Packet@927227
2018-06-24 17:24:44.925 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - update WriteFlusher@40f1bf{IDLE}:WRITING-->IDLE
2018-06-24 17:24:44.927 [DEBUG] [io.socket.parser.Parser ] - encoded io.socket.parser.Packet@927227 as 2["itemupdate",{"itemName":"FF_Stue_CC_Volum","itemStatus":"100"}]
2018-06-24 17:24:44.929 [DEBUG] [io.socket.engineio.client.Socket ] - flushing 1 packets in socket
2018-06-24 17:24:44.930 [DEBUG] [.eclipse.jetty.server.HttpConnection] - org.eclipse.jetty.server.HttpConnection$SendCallback@f7496f[PROCESSING][i=null,cb=Blocker@1f12879{null}] generate: DONE (null,[p=200,l=200,c=32768,r=0],false)@COMMITTED
2018-06-24 17:24:44.932 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@151b781[p=0,l=200,c=32768,r=200]={<<<event: message\nda...usInfoEvent"}\n\n>>>1 Wall Switch\\",\\..."zwave_class_sp} complete=false committing=false callback=Blocker@19b5d29{null}
2018-06-24 17:24:44.933 [DEBUG] [.eclipse.jetty.server.HttpConnection] - org.eclipse.jetty.server.HttpConnection$SendCallback@1632f71[PROCESSING][i=null,cb=Blocker@19b5d29{null}] generate: FLUSH (null,[p=0,l=200,c=32768,r=200],false)@COMMITTED
2018-06-24 17:24:44.935 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - write: WriteFlusher@8d500c{IDLE} [HeapByteBuffer@692140[p=0,l=6,c=1024,r=6]={<<<\r\nC8\r\n>>>\n\n\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00},DirectByteBuffer@151b781[p=0,l=200,c=32768,r=200]={<<<event: message\nda...usInfoEvent"}\n\n>>>1 Wall Switch\\",\\..."zwave_class_sp}]
2018-06-24 17:24:44.937 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - update WriteFlusher@8d500c{WRITING}:IDLE-->WRITING
2018-06-24 17:24:44.939 [DEBUG] [org.eclipse.jetty.io.ChannelEndPoint] - flushed 206 SelectChannelEndPoint@1dfc61{/192.168.0.8:53989<->8080,Open,in,out,-,W,309/30000,HttpConnection@1d73ad8}{io=0/0,kio=0,kro=1}
2018-06-24 17:24:44.940 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - Flushed=true 6/6+1 WriteFlusher@8d500c{WRITING}
2018-06-24 17:24:44.942 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - update WriteFlusher@8d500c{IDLE}:WRITING-->IDLE
2018-06-24 17:24:44.943 [DEBUG] [.eclipse.jetty.server.HttpConnection] - org.eclipse.jetty.server.HttpConnection$SendCallback@1632f71[PROCESSING][i=null,cb=Blocker@19b5d29{null}] generate: DONE (null,[p=200,l=200,c=32768,r=0],false)@COMMITTED
2018-06-24 17:24:44.946 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@883b2f[p=0,l=146,c=32768,r=146]={<<<event: message\nda...mStateEvent"}\n\n>>>usDetail\\":\\"NONE...WdVsL+xokX6hp4b} complete=false committing=false callback=Blocker@1f12879{null}
2018-06-24 17:24:44.947 [DEBUG] [.eclipse.jetty.server.HttpConnection] - org.eclipse.jetty.server.HttpConnection$SendCallback@f7496f[PROCESSING][i=null,cb=Blocker@1f12879{null}] generate: FLUSH (null,[p=0,l=146,c=32768,r=146],false)@COMMITTED
2018-06-24 17:24:44.949 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - write: WriteFlusher@40f1bf{IDLE} [HeapByteBuffer@8d85b5[p=0,l=6,c=1024,r=6]={<<<\r\n92\r\n>>>\n\n\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00},DirectByteBuffer@883b2f[p=0,l=146,c=32768,r=146]={<<<event: message\nda...mStateEvent"}\n\n>>>usDetail\\":\\"NONE...WdVsL+xokX6hp4b}]
2018-06-24 17:24:44.951 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - update WriteFlusher@40f1bf{WRITING}:IDLE-->WRITING
2018-06-24 17:24:44.952 [DEBUG] [org.eclipse.jetty.io.ChannelEndPoint] - flushed 152 SelectChannelEndPoint@1205f5e{/192.168.0.8:53712<->8080,Open,in,out,-,W,31/30000,HttpConnection@d70d76}{io=0/0,kio=0,kro=1}
2018-06-24 17:24:44.954 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - Flushed=true 6/6+1 WriteFlusher@40f1bf{WRITING}
2018-06-24 17:24:44.955 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - update WriteFlusher@40f1bf{IDLE}:WRITING-->IDLE
2018-06-24 17:24:44.957 [DEBUG] [.eclipse.jetty.server.HttpConnection] - org.eclipse.jetty.server.HttpConnection$SendCallback@f7496f[PROCESSING][i=null,cb=Blocker@1f12879{null}] generate: DONE (null,[p=146,l=146,c=32768,r=0],false)@COMMITTED
2018-06-24 17:24:44.960 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@151b781[p=0,l=146,c=32768,r=146]={<<<event: message\nda...mStateEvent"}\n\n>>>usDetail\\":\\"NONE..."zwave_class_sp} complete=false committing=false callback=Blocker@19b5d29{null}
2018-06-24 17:24:44.961 [DEBUG] [.eclipse.jetty.server.HttpConnection] - org.eclipse.jetty.server.HttpConnection$SendCallback@1632f71[PROCESSING][i=null,cb=Blocker@19b5d29{null}] generate: FLUSH (null,[p=0,l=146,c=32768,r=146],false)@COMMITTED
2018-06-24 17:24:44.963 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - write: WriteFlusher@8d500c{IDLE} [HeapByteBuffer@692140[p=0,l=6,c=1024,r=6]={<<<\r\n92\r\n>>>\n\n\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00},DirectByteBuffer@151b781[p=0,l=146,c=32768,r=146]={<<<event: message\nda...mStateEvent"}\n\n>>>usDetail\\":\\"NONE..."zwave_class_sp}]
2018-06-24 17:24:44.964 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - update WriteFlusher@8d500c{WRITING}:IDLE-->WRITING
2018-06-24 17:24:44.966 [DEBUG] [org.eclipse.jetty.io.ChannelEndPoint] - flushed 152 SelectChannelEndPoint@1dfc61{/192.168.0.8:53989<->8080,Open,in,out,-,W,26/30000,HttpConnection@1d73ad8}{io=0/0,kio=0,kro=1}
2018-06-24 17:24:44.968 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - Flushed=true 6/6+1 WriteFlusher@8d500c{WRITING}
2018-06-24 17:24:44.969 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - update WriteFlusher@8d500c{IDLE}:WRITING-->IDLE
2018-06-24 17:24:44.971 [DEBUG] [.eclipse.jetty.server.HttpConnection] - org.eclipse.jetty.server.HttpConnection$SendCallback@1632f71[PROCESSING][i=null,cb=Blocker@19b5d29{null}] generate: DONE (null,[p=146,l=146,c=32768,r=0],false)@COMMITTED
2018-06-24 17:24:44.973 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@883b2f[p=0,l=150,c=32768,r=150]={<<<event: message\nda...mStateEvent"}\n\n>>>tail\\":\\"NONE\\"}"...WdVsL+xokX6hp4b} complete=false committing=false callback=Blocker@1f12879{null}
2018-06-24 17:24:44.975 [DEBUG] [.eclipse.jetty.server.HttpConnection] - org.eclipse.jetty.server.HttpConnection$SendCallback@f7496f[PROCESSING][i=null,cb=Blocker@1f12879{null}] generate: FLUSH (null,[p=0,l=150,c=32768,r=150],false)@COMMITTED
2018-06-24 17:24:44.977 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - write: WriteFlusher@40f1bf{IDLE} [HeapByteBuffer@8d85b5[p=0,l=6,c=1024,r=6]={<<<\r\n96\r\n>>>\n\n\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00},DirectByteBuffer@883b2f[p=0,l=150,c=32768,r=150]={<<<event: message\nda...mStateEvent"}\n\n>>>tail\\":\\"NONE\\"}"...WdVsL+xokX6hp4b}]
2018-06-24 17:24:44.978 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - update WriteFlusher@40f1bf{WRITING}:IDLE-->WRITING
2018-06-24 17:24:44.980 [DEBUG] [org.eclipse.jetty.io.ChannelEndPoint] - flushed 156 SelectChannelEndPoint@1205f5e{/192.168.0.8:53712<->8080,Open,in,out,-,W,26/30000,HttpConnection@d70d76}{io=0/0,kio=0,kro=1}
2018-06-24 17:24:44.981 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - Flushed=true 6/6+1 WriteFlusher@40f1bf{WRITING}
2018-06-24 17:24:44.983 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - update WriteFlusher@40f1bf{IDLE}:WRITING-->IDLE
2018-06-24 17:24:44.985 [DEBUG] [.eclipse.jetty.server.HttpConnection] - org.eclipse.jetty.server.HttpConnection$SendCallback@f7496f[PROCESSING][i=null,cb=Blocker@1f12879{null}] generate: DONE (null,[p=150,l=150,c=32768,r=0],false)@COMMITTED
2018-06-24 17:24:44.987 [DEBUG] [org.eclipse.jetty.server.HttpChannel] - sendResponse info=null content=DirectByteBuffer@151b781[p=0,l=150,c=32768,r=150]={<<<event: message\nda...mStateEvent"}\n\n>>>tail\\":\\"NONE\\"}"..."zwave_class_sp} complete=false committing=false callback=Blocker@19b5d29{null}
2018-06-24 17:24:44.989 [DEBUG] [.eclipse.jetty.server.HttpConnection] - org.eclipse.jetty.server.HttpConnection$SendCallback@1632f71[PROCESSING][i=null,cb=Blocker@19b5d29{null}] generate: FLUSH (null,[p=0,l=150,c=32768,r=150],false)@COMMITTED
2018-06-24 17:24:44.990 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - write: WriteFlusher@8d500c{IDLE} [HeapByteBuffer@692140[p=0,l=6,c=1024,r=6]={<<<\r\n96\r\n>>>\n\n\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00},DirectByteBuffer@151b781[p=0,l=150,c=32768,r=150]={<<<event: message\nda...mStateEvent"}\n\n>>>tail\\":\\"NONE\\"}"..."zwave_class_sp}]
2018-06-24 17:24:44.992 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - update WriteFlusher@8d500c{WRITING}:IDLE-->WRITING
2018-06-24 17:24:44.994 [DEBUG] [org.eclipse.jetty.io.ChannelEndPoint] - flushed 156 SelectChannelEndPoint@1dfc61{/192.168.0.8:53989<->8080,Open,in,out,-,W,26/30000,HttpConnection@1d73ad8}{io=0/0,kio=0,kro=1}
2018-06-24 17:24:44.995 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - Flushed=true 6/6+1 WriteFlusher@8d500c{WRITING}
2018-06-24 17:24:44.997 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - update WriteFlusher@8d500c{IDLE}:WRITING-->IDLE
2018-06-24 17:24:44.999 [DEBUG] [.eclipse.jetty.server.HttpConnection] - org.eclipse.jetty.server.HttpConnection$SendCallback@1632f71[PROCESSING][i=null,cb=Blocker@19b5d29{null}] generate: DONE (null,[p=150,l=150,c=32768,r=0],false)@COMMITTED
