Hi Guys,
So the issue is that I just cant switch the darn light off. Its controlled by a Aeotec Multisensor for mother, the Dimmer itself is a Fibaro Dimmer 2.
There are NO zwave logs for the motion sensor, but plenty for the light. I cant determine which device is at fault, the Motion sensor turning the lights on, or the lights just turning on!
Here is the debug I see for the light.
Ive tried resetting the life line, healing the device and I also notice the Motion Sensor is showing 0 of 7 channels linked.
Odd!
02-Feb-2019 20:57:57.234 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 4: Message payload = 00 04 07 60 0D 01 01 26 03 63
02-Feb-2019 20:57:57.235 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Application Command Request (ALIVE:DONE)
02-Feb-2019 20:57:57.235 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: resetResendCount initComplete=true isDead=false
02-Feb-2019 20:57:57.235 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
02-Feb-2019 20:57:57.235 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 1
02-Feb-2019 20:57:57.235 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: SECURITY NOT required on COMMAND_CLASS_SWITCH_MULTILEVEL
02-Feb-2019 20:57:57.235 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 4: Received COMMAND_CLASS_SWITCH_MULTILEVEL V3 SWITCH_MULTILEVEL_REPORT
02-Feb-2019 20:57:57.235 [DEBUG] [col.commandclass.ZWaveMultiLevelSwitchCommandClass] - NODE 4: Switch Multi Level report, value = 99
02-Feb-2019 20:57:57.236 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
02-Feb-2019 20:57:57.236 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got a value event from Z-Wave network, endpoint = 1, command class = COMMAND_CLASS_SWITCH_MULTILEVEL, value = 99
02-Feb-2019 20:57:57.236 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Updating channel state zwave:device:a1562d1c:node4:switch_dimmer1 to 100 [PercentType]
02-Feb-2019 20:57:57.236 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Commands processed 1.
02-Feb-2019 20:57:57.236 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@562f0e32.
02-Feb-2019 20:57:57.894 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 4: Message payload = 00 04 07 60 0D 01 01 26 03 63
02-Feb-2019 20:57:57.895 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Application Command Request (ALIVE:DONE)
02-Feb-2019 20:57:57.895 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: resetResendCount initComplete=true isDead=false
02-Feb-2019 20:57:57.895 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
02-Feb-2019 20:57:57.895 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 1
02-Feb-2019 20:57:57.895 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: SECURITY NOT required on COMMAND_CLASS_SWITCH_MULTILEVEL
02-Feb-2019 20:57:57.896 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 4: Received COMMAND_CLASS_SWITCH_MULTILEVEL V3 SWITCH_MULTILEVEL_REPORT
02-Feb-2019 20:57:57.896 [DEBUG] [col.commandclass.ZWaveMultiLevelSwitchCommandClass] - NODE 4: Switch Multi Level report, value = 99
02-Feb-2019 20:57:57.896 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
02-Feb-2019 20:57:57.896 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got a value event from Z-Wave network, endpoint = 1, command class = COMMAND_CLASS_SWITCH_MULTILEVEL, value = 99
02-Feb-2019 20:57:57.896 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Updating channel state zwave:device:a1562d1c:node4:switch_dimmer1 to 100 [PercentType]
02-Feb-2019 20:57:57.897 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Commands processed 1.
02-Feb-2019 20:57:57.897 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@68249b44.
02-Feb-2019 20:57:58.547 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 4: Message payload = 00 04 07 60 0D 01 01 26 03 63
02-Feb-2019 20:57:58.548 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Application Command Request (ALIVE:DONE)
02-Feb-2019 20:57:58.548 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: resetResendCount initComplete=true isDead=false
02-Feb-2019 20:57:58.548 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
02-Feb-2019 20:57:58.548 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 1
02-Feb-2019 20:57:58.548 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: SECURITY NOT required on COMMAND_CLASS_SWITCH_MULTILEVEL
02-Feb-2019 20:57:58.548 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 4: Received COMMAND_CLASS_SWITCH_MULTILEVEL V3 SWITCH_MULTILEVEL_REPORT
02-Feb-2019 20:57:58.549 [DEBUG] [col.commandclass.ZWaveMultiLevelSwitchCommandClass] - NODE 4: Switch Multi Level report, value = 99
02-Feb-2019 20:57:58.549 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
02-Feb-2019 20:57:58.549 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got a value event from Z-Wave network, endpoint = 1, command class = COMMAND_CLASS_SWITCH_MULTILEVEL, value = 99
02-Feb-2019 20:57:58.549 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Updating channel state zwave:device:a1562d1c:node4:switch_dimmer1 to 100 [PercentType]
02-Feb-2019 20:57:58.550 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Commands processed 1.
02-Feb-2019 20:57:58.550 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@3e7d6fbc.
02-Feb-2019 20:57:59.213 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 4: Message payload = 00 04 07 60 0D 01 01 26 03 63
02-Feb-2019 20:57:59.214 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Application Command Request (ALIVE:DONE)
02-Feb-2019 20:57:59.214 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: resetResendCount initComplete=true isDead=false
02-Feb-2019 20:57:59.214 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
02-Feb-2019 20:57:59.214 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 1
02-Feb-2019 20:57:59.214 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: SECURITY NOT required on COMMAND_CLASS_SWITCH_MULTILEVEL
02-Feb-2019 20:57:59.215 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 4: Received COMMAND_CLASS_SWITCH_MULTILEVEL V3 SWITCH_MULTILEVEL_REPORT
02-Feb-2019 20:57:59.215 [DEBUG] [col.commandclass.ZWaveMultiLevelSwitchCommandClass] - NODE 4: Switch Multi Level report, value = 99
02-Feb-2019 20:57:59.215 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
02-Feb-2019 20:57:59.215 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got a value event from Z-Wave network, endpoint = 1, command class = COMMAND_CLASS_SWITCH_MULTILEVEL, value = 99
02-Feb-2019 20:57:59.215 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Updating channel state zwave:device:a1562d1c:node4:switch_dimmer1 to 100 [PercentType]
02-Feb-2019 20:57:59.216 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Commands processed 1.
02-Feb-2019 20:57:59.216 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@7281b9fa.
02-Feb-2019 20:57:59.866 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 4: Message payload = 00 04 07 60 0D 01 01 26 03 63
02-Feb-2019 20:57:59.867 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Application Command Request (ALIVE:DONE)
02-Feb-2019 20:57:59.867 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: resetResendCount initComplete=true isDead=false
02-Feb-2019 20:57:59.867 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
02-Feb-2019 20:57:59.867 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 1
02-Feb-2019 20:57:59.867 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: SECURITY NOT required on COMMAND_CLASS_SWITCH_MULTILEVEL
02-Feb-2019 20:57:59.868 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 4: Received COMMAND_CLASS_SWITCH_MULTILEVEL V3 SWITCH_MULTILEVEL_REPORT
02-Feb-2019 20:57:59.868 [DEBUG] [col.commandclass.ZWaveMultiLevelSwitchCommandClass] - NODE 4: Switch Multi Level report, value = 99
02-Feb-2019 20:57:59.868 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
02-Feb-2019 20:57:59.868 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got a value event from Z-Wave network, endpoint = 1, command class = COMMAND_CLASS_SWITCH_MULTILEVEL, value = 99
02-Feb-2019 20:57:59.868 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Updating channel state zwave:device:a1562d1c:node4:switch_dimmer1 to 100 [PercentType]
02-Feb-2019 20:57:59.869 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Commands processed 1.
02-Feb-2019 20:57:59.869 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@5c716706.
02-Feb-2019 20:58:00.794 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 4: Message payload = 00 04 07 60 0D 01 01 26 03 63
02-Feb-2019 20:58:00.795 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Application Command Request (ALIVE:DONE)
02-Feb-2019 20:58:00.795 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: resetResendCount initComplete=true isDead=false
02-Feb-2019 20:58:00.795 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
02-Feb-2019 20:58:00.795 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 1
02-Feb-2019 20:58:00.795 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: SECURITY NOT required on COMMAND_CLASS_SWITCH_MULTILEVEL
02-Feb-2019 20:58:00.795 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 4: Received COMMAND_CLASS_SWITCH_MULTILEVEL V3 SWITCH_MULTILEVEL_REPORT
02-Feb-2019 20:58:00.796 [DEBUG] [col.commandclass.ZWaveMultiLevelSwitchCommandClass] - NODE 4: Switch Multi Level report, value = 99
02-Feb-2019 20:58:00.796 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
02-Feb-2019 20:58:00.796 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got a value event from Z-Wave network, endpoint = 1, command class = COMMAND_CLASS_SWITCH_MULTILEVEL, value = 99
02-Feb-2019 20:58:00.796 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Updating channel state zwave:device:a1562d1c:node4:switch_dimmer1 to 100 [PercentType]
02-Feb-2019 20:58:00.797 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Commands processed 1.
02-Feb-2019 20:58:00.797 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@10432977.
02-Feb-2019 20:58:01.184 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 4: Message payload = 00 04 07 60 0D 01 01 26 03 63
02-Feb-2019 20:58:01.185 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Application Command Request (ALIVE:DONE)
02-Feb-2019 20:58:01.185 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: resetResendCount initComplete=true isDead=false
02-Feb-2019 20:58:01.185 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
02-Feb-2019 20:58:01.185 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 1
02-Feb-2019 20:58:01.186 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: SECURITY NOT required on COMMAND_CLASS_SWITCH_MULTILEVEL
02-Feb-2019 20:58:01.186 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 4: Received COMMAND_CLASS_SWITCH_MULTILEVEL V3 SWITCH_MULTILEVEL_REPORT
02-Feb-2019 20:58:01.186 [DEBUG] [col.commandclass.ZWaveMultiLevelSwitchCommandClass] - NODE 4: Switch Multi Level report, value = 99
02-Feb-2019 20:58:01.186 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
02-Feb-2019 20:58:01.186 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got a value event from Z-Wave network, endpoint = 1, command class = COMMAND_CLASS_SWITCH_MULTILEVEL, value = 99
02-Feb-2019 20:58:01.187 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Updating channel state zwave:device:a1562d1c:node4:switch_dimmer1 to 100 [PercentType]
02-Feb-2019 20:58:01.187 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Commands processed 1.
02-Feb-2019 20:58:01.187 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@4596b44c.
02-Feb-2019 20:58:01.594 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 4: Message payload = 00 04 07 60 0D 01 01 26 03 63
02-Feb-2019 20:58:01.595 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Application Command Request (ALIVE:DONE)
02-Feb-2019 20:58:01.595 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: resetResendCount initComplete=true isDead=false
02-Feb-2019 20:58:01.595 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
02-Feb-2019 20:58:01.595 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 1
02-Feb-2019 20:58:01.595 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: SECURITY NOT required on COMMAND_CLASS_SWITCH_MULTILEVEL
02-Feb-2019 20:58:01.595 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 4: Received COMMAND_CLASS_SWITCH_MULTILEVEL V3 SWITCH_MULTILEVEL_REPORT
02-Feb-2019 20:58:01.596 [DEBUG] [col.commandclass.ZWaveMultiLevelSwitchCommandClass] - NODE 4: Switch Multi Level report, value = 99
02-Feb-2019 20:58:01.596 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
02-Feb-2019 20:58:01.596 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got a value event from Z-Wave network, endpoint = 1, command class = COMMAND_CLASS_SWITCH_MULTILEVEL, value = 99
02-Feb-2019 20:58:01.596 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Updating channel state zwave:device:a1562d1c:node4:switch_dimmer1 to 100 [PercentType]
02-Feb-2019 20:58:01.597 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Commands processed 1.
02-Feb-2019 20:58:01.597 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@3a279b6d.
02-Feb-2019 20:58:01.764 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 4: Message payload = 00 04 07 60 0D 01 01 26 03 63
02-Feb-2019 20:58:01.765 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Application Command Request (ALIVE:DONE)
02-Feb-2019 20:58:01.765 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: resetResendCount initComplete=true isDead=false
02-Feb-2019 20:58:01.765 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
02-Feb-2019 20:58:01.765 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 1
02-Feb-2019 20:58:01.765 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: SECURITY NOT required on COMMAND_CLASS_SWITCH_MULTILEVEL
02-Feb-2019 20:58:01.766 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 4: Received COMMAND_CLASS_SWITCH_MULTILEVEL V3 SWITCH_MULTILEVEL_REPORT
02-Feb-2019 20:58:01.766 [DEBUG] [col.commandclass.ZWaveMultiLevelSwitchCommandClass] - NODE 4: Switch Multi Level report, value = 99
02-Feb-2019 20:58:01.766 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
02-Feb-2019 20:58:01.766 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got a value event from Z-Wave network, endpoint = 1, command class = COMMAND_CLASS_SWITCH_MULTILEVEL, value = 99
02-Feb-2019 20:58:01.766 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Updating channel state zwave:device:a1562d1c:node4:switch_dimmer1 to 100 [PercentType]
02-Feb-2019 20:58:01.767 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Commands processed 1.
02-Feb-2019 20:58:01.767 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@6db99278.
02-Feb-2019 20:58:02.103 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 4: Message payload = 00 04 07 60 0D 01 01 26 03 63
02-Feb-2019 20:58:02.105 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Application Command Request (ALIVE:DONE)
02-Feb-2019 20:58:02.105 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: resetResendCount initComplete=true isDead=false
02-Feb-2019 20:58:02.105 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
02-Feb-2019 20:58:02.105 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 1
02-Feb-2019 20:58:02.105 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: SECURITY NOT required on COMMAND_CLASS_SWITCH_MULTILEVEL
02-Feb-2019 20:58:02.105 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 4: Received COMMAND_CLASS_SWITCH_MULTILEVEL V3 SWITCH_MULTILEVEL_REPORT
02-Feb-2019 20:58:02.105 [DEBUG] [col.commandclass.ZWaveMultiLevelSwitchCommandClass] - NODE 4: Switch Multi Level report, value = 99
02-Feb-2019 20:58:02.106 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
02-Feb-2019 20:58:02.106 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got a value event from Z-Wave network, endpoint = 1, command class = COMMAND_CLASS_SWITCH_MULTILEVEL, value = 99
02-Feb-2019 20:58:02.106 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Updating channel state zwave:device:a1562d1c:node4:switch_dimmer1 to 100 [PercentType]
02-Feb-2019 20:58:02.106 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Commands processed 1.
02-Feb-2019 20:58:02.106 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@64380629.
02-Feb-2019 20:58:03.023 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 4: Message payload = 00 04 07 60 0D 01 01 26 03 63
02-Feb-2019 20:58:03.024 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Application Command Request (ALIVE:DONE)
02-Feb-2019 20:58:03.024 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: resetResendCount initComplete=true isDead=false
02-Feb-2019 20:58:03.025 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
02-Feb-2019 20:58:03.025 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 1
02-Feb-2019 20:58:03.025 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: SECURITY NOT required on COMMAND_CLASS_SWITCH_MULTILEVEL
02-Feb-2019 20:58:03.025 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 4: Received COMMAND_CLASS_SWITCH_MULTILEVEL V3 SWITCH_MULTILEVEL_REPORT
02-Feb-2019 20:58:03.025 [DEBUG] [col.commandclass.ZWaveMultiLevelSwitchCommandClass] - NODE 4: Switch Multi Level report, value = 99
02-Feb-2019 20:58:03.026 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
02-Feb-2019 20:58:03.026 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got a value event from Z-Wave network, endpoint = 1, command class = COMMAND_CLASS_SWITCH_MULTILEVEL, value = 99
02-Feb-2019 20:58:03.026 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Updating channel state zwave:device:a1562d1c:node4:switch_dimmer1 to 100 [PercentType]
02-Feb-2019 20:58:03.026 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Commands processed 1.
02-Feb-2019 20:58:03.027 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@14fcfa36.
02-Feb-2019 20:58:03.683 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 4: Message payload = 00 04 07 60 0D 01 01 26 03 63
02-Feb-2019 20:58:03.684 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Application Command Request (ALIVE:DONE)
02-Feb-2019 20:58:03.685 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: resetResendCount initComplete=true isDead=false
02-Feb-2019 20:58:03.685 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
02-Feb-2019 20:58:03.685 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 1
02-Feb-2019 20:58:03.685 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: SECURITY NOT required on COMMAND_CLASS_SWITCH_MULTILEVEL
02-Feb-2019 20:58:03.685 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 4: Received COMMAND_CLASS_SWITCH_MULTILEVEL V3 SWITCH_MULTILEVEL_REPORT
02-Feb-2019 20:58:03.685 [DEBUG] [col.commandclass.ZWaveMultiLevelSwitchCommandClass] - NODE 4: Switch Multi Level report, value = 99
02-Feb-2019 20:58:03.686 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
02-Feb-2019 20:58:03.686 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got a value event from Z-Wave network, endpoint = 1, command class = COMMAND_CLASS_SWITCH_MULTILEVEL, value = 99
02-Feb-2019 20:58:03.686 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Updating channel state zwave:device:a1562d1c:node4:switch_dimmer1 to 100 [PercentType]
02-Feb-2019 20:58:03.687 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Commands processed 1.
02-Feb-2019 20:58:03.687 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1286f737.
02-Feb-2019 20:58:05.794 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 4: Message payload = 84 04 1A 04 11 01 5E 20 86 72 26 5A 59 85 73 98 7A 56 70 31 32 8E 60 75 71 27 22 EF 2B
02-Feb-2019 20:58:05.796 [DEBUG] [otocol.serialmessage.ApplicationUpdateMessageClass] - NODE 4: Application update request. Node information received. Transaction null
02-Feb-2019 20:58:05.797 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: resetResendCount initComplete=true isDead=false
02-Feb-2019 20:58:05.797 [DEBUG] [otocol.serialmessage.ApplicationUpdateMessageClass] - NODE 4: Application update - no transaction.
02-Feb-2019 20:58:06.048 [TRACE] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Node is listening - ignore wakeup
02-Feb-2019 20:58:06.112 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 4: Message payload = 00 04 0A 60 0D 01 01 31 05 04 22 00 A3
02-Feb-2019 20:58:06.113 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Application Command Request (ALIVE:DONE)
02-Feb-2019 20:58:06.113 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: resetResendCount initComplete=true isDead=false
02-Feb-2019 20:58:06.113 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
02-Feb-2019 20:58:06.113 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Incoming command class COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint 1
02-Feb-2019 20:58:06.114 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: SECURITY NOT required on COMMAND_CLASS_SENSOR_MULTILEVEL
02-Feb-2019 20:58:06.114 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 4: Received COMMAND_CLASS_SENSOR_MULTILEVEL V4 SENSOR_MULTILEVEL_REPORT
02-Feb-2019 20:58:06.114 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 4: Sensor Type = Power(4), Scale = 0
02-Feb-2019 20:58:06.114 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 4: Sensor Value = 16.3
02-Feb-2019 20:58:06.114 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
02-Feb-2019 20:58:06.114 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got a value event from Z-Wave network, endpoint = 1, command class = COMMAND_CLASS_SENSOR_MULTILEVEL, value = 16.3
02-Feb-2019 20:58:06.115 [DEBUG] [.internal.converter.ZWaveMultiLevelSensorConverter] - NODE 4: Sensor conversion not performed for POWER.
02-Feb-2019 20:58:06.115 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Updating channel state zwave:device:a1562d1c:node4:sensor_power1 to 16.3 [DecimalType]
02-Feb-2019 20:58:06.115 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Commands processed 1.
02-Feb-2019 20:58:06.115 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@330d9d4d.
02-Feb-2019 20:58:08.194 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 4: Message payload = 00 04 07 60 0D 01 01 26 03 63
02-Feb-2019 20:58:08.195 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Application Command Request (ALIVE:DONE)
02-Feb-2019 20:58:08.195 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: resetResendCount initComplete=true isDead=false
02-Feb-2019 20:58:08.195 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
02-Feb-2019 20:58:08.195 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 1
02-Feb-2019 20:58:08.196 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: SECURITY NOT required on COMMAND_CLASS_SWITCH_MULTILEVEL
02-Feb-2019 20:58:08.196 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 4: Received COMMAND_CLASS_SWITCH_MULTILEVEL V3 SWITCH_MULTILEVEL_REPORT
02-Feb-2019 20:58:08.196 [DEBUG] [col.commandclass.ZWaveMultiLevelSwitchCommandClass] - NODE 4: Switch Multi Level report, value = 99
02-Feb-2019 20:58:08.196 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
02-Feb-2019 20:58:08.196 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got a value event from Z-Wave network, endpoint = 1, command class = COMMAND_CLASS_SWITCH_MULTILEVEL, value = 99
02-Feb-2019 20:58:08.196 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Updating channel state zwave:device:a1562d1c:node4:switch_dimmer1 to 100 [PercentType]
02-Feb-2019 20:58:08.197 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Commands processed 1.
02-Feb-2019 20:58:08.197 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1720dc4b.
02-Feb-2019 20:58:09.124 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 4: Message payload = 00 04 0A 60 0D 01 01 31 05 04 22 01 37
02-Feb-2019 20:58:09.125 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Application Command Request (ALIVE:DONE)
02-Feb-2019 20:58:09.125 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: resetResendCount initComplete=true isDead=false
02-Feb-2019 20:58:09.126 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
02-Feb-2019 20:58:09.126 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Incoming command class COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint 1
02-Feb-2019 20:58:09.126 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: SECURITY NOT required on COMMAND_CLASS_SENSOR_MULTILEVEL
02-Feb-2019 20:58:09.126 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 4: Received COMMAND_CLASS_SENSOR_MULTILEVEL V4 SENSOR_MULTILEVEL_REPORT
02-Feb-2019 20:58:09.126 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 4: Sensor Type = Power(4), Scale = 0
02-Feb-2019 20:58:09.127 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 4: Sensor Value = 31.1
02-Feb-2019 20:58:09.127 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
02-Feb-2019 20:58:09.127 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got a value event from Z-Wave network, endpoint = 1, command class = COMMAND_CLASS_SENSOR_MULTILEVEL, value = 31.1
02-Feb-2019 20:58:09.127 [DEBUG] [.internal.converter.ZWaveMultiLevelSensorConverter] - NODE 4: Sensor conversion not performed for POWER.
02-Feb-2019 20:58:09.127 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Updating channel state zwave:device:a1562d1c:node4:sensor_power1 to 31.1 [DecimalType]
02-Feb-2019 20:58:09.128 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Commands processed 1.
02-Feb-2019 20:58:09.128 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@64feb9d3.
02-Feb-2019 20:58:10.484 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 4: Message payload = 84 04 1A 04 11 01 5E 20 86 72 26 5A 59 85 73 98 7A 56 70 31 32 8E 60 75 71 27 22 EF 2B
02-Feb-2019 20:58:10.487 [DEBUG] [otocol.serialmessage.ApplicationUpdateMessageClass] - NODE 4: Application update request. Node information received. Transaction null
02-Feb-2019 20:58:10.487 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: resetResendCount initComplete=true isDead=false
02-Feb-2019 20:58:10.487 [DEBUG] [otocol.serialmessage.ApplicationUpdateMessageClass] - NODE 4: Application update - no transaction.
02-Feb-2019 20:58:10.738 [TRACE] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Node is listening - ignore wakeup
02-Feb-2019 20:58:11.034 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 4: Message payload = 00 04 07 60 0D 01 01 26 03 63
02-Feb-2019 20:58:11.036 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Application Command Request (ALIVE:DONE)
02-Feb-2019 20:58:11.036 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: resetResendCount initComplete=true isDead=false
02-Feb-2019 20:58:11.036 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
02-Feb-2019 20:58:11.036 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 1
02-Feb-2019 20:58:11.036 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: SECURITY NOT required on COMMAND_CLASS_SWITCH_MULTILEVEL
02-Feb-2019 20:58:11.037 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 4: Received COMMAND_CLASS_SWITCH_MULTILEVEL V3 SWITCH_MULTILEVEL_REPORT
02-Feb-2019 20:58:11.037 [DEBUG] [col.commandclass.ZWaveMultiLevelSwitchCommandClass] - NODE 4: Switch Multi Level report, value = 99
02-Feb-2019 20:58:11.037 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
02-Feb-2019 20:58:11.037 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got a value event from Z-Wave network, endpoint = 1, command class = COMMAND_CLASS_SWITCH_MULTILEVEL, value = 99
02-Feb-2019 20:58:11.038 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Updating channel state zwave:device:a1562d1c:node4:switch_dimmer1 to 100 [PercentType]
02-Feb-2019 20:58:11.038 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Commands processed 1.
02-Feb-2019 20:58:11.038 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1edccfa0.
02-Feb-2019 20:58:12.733 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 4: Message payload = 00 04 07 60 0D 01 01 26 03 63
02-Feb-2019 20:58:12.735 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Application Command Request (ALIVE:DONE)
02-Feb-2019 20:58:12.735 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: resetResendCount initComplete=true isDead=false
02-Feb-2019 20:58:12.735 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
02-Feb-2019 20:58:12.735 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 1
02-Feb-2019 20:58:12.736 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: SECURITY NOT required on COMMAND_CLASS_SWITCH_MULTILEVEL
02-Feb-2019 20:58:12.736 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 4: Received COMMAND_CLASS_SWITCH_MULTILEVEL V3 SWITCH_MULTILEVEL_REPORT
02-Feb-2019 20:58:12.736 [DEBUG] [col.commandclass.ZWaveMultiLevelSwitchCommandClass] - NODE 4: Switch Multi Level report, value = 99
02-Feb-2019 20:58:12.736 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
02-Feb-2019 20:58:12.736 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got a value event from Z-Wave network, endpoint = 1, command class = COMMAND_CLASS_SWITCH_MULTILEVEL, value = 99
02-Feb-2019 20:58:12.737 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Updating channel state zwave:device:a1562d1c:node4:switch_dimmer1 to 100 [PercentType]
02-Feb-2019 20:58:12.737 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Commands processed 1.
02-Feb-2019 20:58:12.738 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@f0f8ab4.
02-Feb-2019 20:58:13.254 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 4: Message payload = 00 04 07 60 0D 01 01 26 03 63
02-Feb-2019 20:58:13.255 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Application Command Request (ALIVE:DONE)
02-Feb-2019 20:58:13.255 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: resetResendCount initComplete=true isDead=false
02-Feb-2019 20:58:13.255 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
02-Feb-2019 20:58:13.256 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 1
02-Feb-2019 20:58:13.256 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: SECURITY NOT required on COMMAND_CLASS_SWITCH_MULTILEVEL
02-Feb-2019 20:58:13.256 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 4: Received COMMAND_CLASS_SWITCH_MULTILEVEL V3 SWITCH_MULTILEVEL_REPORT
02-Feb-2019 20:58:13.256 [DEBUG] [col.commandclass.ZWaveMultiLevelSwitchCommandClass] - NODE 4: Switch Multi Level report, value = 99
02-Feb-2019 20:58:13.256 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
02-Feb-2019 20:58:13.256 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got a value event from Z-Wave network, endpoint = 1, command class = COMMAND_CLASS_SWITCH_MULTILEVEL, value = 99
02-Feb-2019 20:58:13.257 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Updating channel state zwave:device:a1562d1c:node4:switch_dimmer1 to 100 [PercentType]
02-Feb-2019 20:58:13.257 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Commands processed 1.
02-Feb-2019 20:58:13.258 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1e2e9aa7.
02-Feb-2019 20:58:13.773 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 4: Message payload = 00 04 07 60 0D 01 01 26 03 63
02-Feb-2019 20:58:13.774 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Application Command Request (ALIVE:DONE)
02-Feb-2019 20:58:13.774 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: resetResendCount initComplete=true isDead=false
02-Feb-2019 20:58:13.775 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
02-Feb-2019 20:58:13.775 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 1
02-Feb-2019 20:58:13.775 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: SECURITY NOT required on COMMAND_CLASS_SWITCH_MULTILEVEL
02-Feb-2019 20:58:13.775 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 4: Received COMMAND_CLASS_SWITCH_MULTILEVEL V3 SWITCH_MULTILEVEL_REPORT
02-Feb-2019 20:58:13.775 [DEBUG] [col.commandclass.ZWaveMultiLevelSwitchCommandClass] - NODE 4: Switch Multi Level report, value = 99
02-Feb-2019 20:58:13.775 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
02-Feb-2019 20:58:13.775 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got a value event from Z-Wave network, endpoint = 1, command class = COMMAND_CLASS_SWITCH_MULTILEVEL, value = 99
02-Feb-2019 20:58:13.776 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Updating channel state zwave:device:a1562d1c:node4:switch_dimmer1 to 100 [PercentType]
02-Feb-2019 20:58:13.776 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Commands processed 1.
02-Feb-2019 20:58:13.776 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@79842123.
02-Feb-2019 20:58:14.288 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 4: Message payload = 00 04 07 60 0D 01 01 26 03 63
02-Feb-2019 20:58:14.290 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Application Command Request (ALIVE:DONE)
02-Feb-2019 20:58:14.290 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: resetResendCount initComplete=true isDead=false
02-Feb-2019 20:58:14.290 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
02-Feb-2019 20:58:14.291 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 1
02-Feb-2019 20:58:14.291 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: SECURITY NOT required on COMMAND_CLASS_SWITCH_MULTILEVEL
02-Feb-2019 20:58:14.291 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 4: Received COMMAND_CLASS_SWITCH_MULTILEVEL V3 SWITCH_MULTILEVEL_REPORT
02-Feb-2019 20:58:14.291 [DEBUG] [col.commandclass.ZWaveMultiLevelSwitchCommandClass] - NODE 4: Switch Multi Level report, value = 99
02-Feb-2019 20:58:14.291 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
02-Feb-2019 20:58:14.291 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got a value event from Z-Wave network, endpoint = 1, command class = COMMAND_CLASS_SWITCH_MULTILEVEL, value = 99
02-Feb-2019 20:58:14.292 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Updating channel state zwave:device:a1562d1c:node4:switch_dimmer1 to 100 [PercentType]
02-Feb-2019 20:58:14.292 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Commands processed 1.
02-Feb-2019 20:58:14.292 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1dd407c.
02-Feb-2019 20:58:14.814 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 4: Message payload = 00 04 07 60 0D 01 01 26 03 63
