Perfect guys
You all pointed me into the right direction.
While reading the log, I saw that Dimmer1 channel was updated very quick after hitting the wall switch, and Dimmer (without Number) channel, which was used by me, later as described before. So very easy change and now it works.
Just good to know, for which reason is Dimmer channel available?
Dimmer1 channel is the correct one.
Have a nice evening and thanks very much for your help.
Sebastian
2025-02-06 20:34:15.113 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 00 03 08 56 01 2B 01 10 00 7B 08 C3 00 3D
2025-02-06 20:34:15.123 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=3, callback=0, payload=00 03 08 56 01 2B 01 10 00 7B 08 C3 00
2025-02-06 20:34:15.125 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=3, callback=0, payload=00 03 08 56 01 2B 01 10 00 7B 08 C3 00
2025-02-06 20:34:15.125 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2025-02-06 20:34:15.126 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Application Command Request (ALIVE:DONE)
2025-02-06 20:34:15.126 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: resetResendCount initComplete=true isDead=false
2025-02-06 20:34:15.126 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Decapsulating COMMAND_CLASS_CRC_16_ENCAP
2025-02-06 20:34:15.127 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Incoming command class COMMAND_CLASS_SCENE_ACTIVATION, endpoint 0
2025-02-06 20:34:15.128 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_SCENE_ACTIVATION
2025-02-06 20:34:15.128 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 3: Received COMMAND_CLASS_SCENE_ACTIVATION V1 SCENEACTIVATION_SET
2025-02-06 20:34:15.129 [DEBUG] [ass.ZWaveSceneActivationCommandClass] - NODE 3: Scene activation: Scene 16, Time 0
2025-02-06 20:34:15.129 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2025-02-06 20:34:15.129 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SCENE_ACTIVATION, value=16
2025-02-06 20:34:15.130 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Updating channel state zwave:device:49c171dfd7:node3:scene_number to 16 [DecimalType]
2025-02-06 20:34:15.131 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Commands processed 1.
2025-02-06 20:34:15.131 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@5b448f42.
2025-02-06 20:34:15.132 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2025-02-06 20:34:15.133 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2025-02-06 20:34:15.133 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2025-02-06 20:34:15.455 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 16 00 04 00 03 0E 56 01 60 0D 01 01 31 05 04 22 00 14 43 02 C3 00 5E
2025-02-06 20:34:15.468 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=3, callback=0, payload=00 03 0E 56 01 60 0D 01 01 31 05 04 22 00 14 43 02 C3 00
2025-02-06 20:34:15.469 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=3, callback=0, payload=00 03 0E 56 01 60 0D 01 01 31 05 04 22 00 14 43 02 C3 00
2025-02-06 20:34:15.469 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2025-02-06 20:34:15.470 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Application Command Request (ALIVE:DONE)
2025-02-06 20:34:15.470 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: resetResendCount initComplete=true isDead=false
2025-02-06 20:34:15.470 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Decapsulating COMMAND_CLASS_CRC_16_ENCAP
2025-02-06 20:34:15.471 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2025-02-06 20:34:15.471 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Incoming command class COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint 1
2025-02-06 20:34:15.472 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_SENSOR_MULTILEVEL
2025-02-06 20:34:15.472 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 3: Received COMMAND_CLASS_SENSOR_MULTILEVEL V4 SENSOR_MULTILEVEL_REPORT
2025-02-06 20:34:15.473 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 3: Sensor Type = Power(4), Scale = 0
2025-02-06 20:34:15.473 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 3: Sensor Value = 2
2025-02-06 20:34:15.474 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2025-02-06 20:34:15.474 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got a value event from Z-Wave network, endpoint=1, command class=COMMAND_CLASS_SENSOR_MULTILEVEL, value=2
2025-02-06 20:34:15.475 [DEBUG] [erter.ZWaveMultiLevelSensorConverter] - NODE 3: Sensor conversion not performed for POWER.
2025-02-06 20:34:15.476 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Updating channel state zwave:device:49c171dfd7:node3:sensor_power1 to 2 [DecimalType]
2025-02-06 20:34:15.476 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Commands processed 1.
2025-02-06 20:34:15.477 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1fbc8d56.
2025-02-06 20:34:15.477 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2025-02-06 20:34:15.478 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2025-02-06 20:34:15.478 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2025-02-06 20:34:16.091 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 13 00 04 00 03 0B 56 01 60 0D 01 01 26 03 63 D9 3F C1 00 BB
2025-02-06 20:34:16.103 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=3, callback=0, payload=00 03 0B 56 01 60 0D 01 01 26 03 63 D9 3F C1 00
2025-02-06 20:34:16.105 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=3, callback=0, payload=00 03 0B 56 01 60 0D 01 01 26 03 63 D9 3F C1 00
2025-02-06 20:34:16.105 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2025-02-06 20:34:16.106 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Application Command Request (ALIVE:DONE)
2025-02-06 20:34:16.106 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: resetResendCount initComplete=true isDead=false
2025-02-06 20:34:16.107 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Decapsulating COMMAND_CLASS_CRC_16_ENCAP
2025-02-06 20:34:16.107 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2025-02-06 20:34:16.108 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 1
2025-02-06 20:34:16.108 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_SWITCH_MULTILEVEL
2025-02-06 20:34:16.109 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 3: Received COMMAND_CLASS_SWITCH_MULTILEVEL V3 SWITCH_MULTILEVEL_REPORT
2025-02-06 20:34:16.109 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 3: Switch Multi Level report, value = 99
2025-02-06 20:34:16.109 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2025-02-06 20:34:16.110 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got a value event from Z-Wave network, endpoint=1, command class=COMMAND_CLASS_SWITCH_MULTILEVEL, value=99
2025-02-06 20:34:16.111 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Updating channel state zwave:device:49c171dfd7:node3:switch_dimmer1 to 100 [PercentType]
2025-02-06 20:34:16.111 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Commands processed 1.
2025-02-06 20:34:16.112 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@bd58326.
2025-02-06 20:34:16.113 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2025-02-06 20:34:16.114 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2025-02-06 20:34:16.115 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2025-02-06 20:34:16.117 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2025-02-06 20:34:16.114 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Licht_Bad_Dimmer_1' changed from 0 to 100
2025-02-06 20:34:25.440 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 16 00 04 00 03 0E 56 01 60 0D 01 01 31 05 04 22 01 E1 CF 89 C1 00 AF
2025-02-06 20:34:25.452 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=3, callback=0, payload=00 03 0E 56 01 60 0D 01 01 31 05 04 22 01 E1 CF 89 C1 00
2025-02-06 20:34:25.453 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=3, callback=0, payload=00 03 0E 56 01 60 0D 01 01 31 05 04 22 01 E1 CF 89 C1 00
2025-02-06 20:34:25.453 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2025-02-06 20:34:25.454 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Application Command Request (ALIVE:DONE)
2025-02-06 20:34:25.454 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: resetResendCount initComplete=true isDead=false
2025-02-06 20:34:25.455 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Decapsulating COMMAND_CLASS_CRC_16_ENCAP
2025-02-06 20:34:25.455 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2025-02-06 20:34:25.456 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Incoming command class COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint 1
2025-02-06 20:34:25.456 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_SENSOR_MULTILEVEL
2025-02-06 20:34:25.457 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 3: Received COMMAND_CLASS_SENSOR_MULTILEVEL V4 SENSOR_MULTILEVEL_REPORT
2025-02-06 20:34:25.457 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 3: Sensor Type = Power(4), Scale = 0
2025-02-06 20:34:25.458 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 3: Sensor Value = 48.1
2025-02-06 20:34:25.458 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2025-02-06 20:34:25.459 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got a value event from Z-Wave network, endpoint=1, command class=COMMAND_CLASS_SENSOR_MULTILEVEL, value=48.1
2025-02-06 20:34:25.460 [DEBUG] [erter.ZWaveMultiLevelSensorConverter] - NODE 3: Sensor conversion not performed for POWER.
2025-02-06 20:34:25.460 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Updating channel state zwave:device:49c171dfd7:node3:sensor_power1 to 48.1 [DecimalType]
2025-02-06 20:34:25.461 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Commands processed 1.
2025-02-06 20:34:25.461 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@350d3acf.
2025-02-06 20:34:25.461 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2025-02-06 20:34:25.462 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2025-02-06 20:34:25.462 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2025-02-06 20:34:25.463 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2025-02-06 20:34:45.153 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Polling...
2025-02-06 20:34:45.154 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Polling zwave:device:49c171dfd7:node3:switch_dimmer
2025-02-06 20:34:45.155 [DEBUG] [erter.ZWaveMultiLevelSwitchConverter] - NODE 3: Generating poll message for COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 0
2025-02-06 20:34:45.155 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 3: Creating new message for command SWITCH_MULTILEVEL_GET
2025-02-06 20:34:45.156 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_SWITCH_MULTILEVEL
2025-02-06 20:34:45.156 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Command Class COMMAND_CLASS_SWITCH_MULTILEVEL is NOT required to be secured
2025-02-06 20:34:45.157 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Polling skipped for zwave:device:49c171dfd7:node3:switch_dimmer on COMMAND_CLASS_BASIC
2025-02-06 20:34:45.157 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Polling zwave:device:49c171dfd7:node3:meter_kwh
2025-02-06 20:34:45.158 [DEBUG] [ternal.converter.ZWaveMeterConverter] - NODE 3: Generating poll message for COMMAND_CLASS_METER, endpoint 0
2025-02-06 20:34:45.159 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 3: Creating new message for application command METER_GET
2025-02-06 20:34:45.159 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_METER
2025-02-06 20:34:45.160 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Command Class COMMAND_CLASS_METER is NOT required to be secured
2025-02-06 20:34:45.160 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Polling zwave:device:49c171dfd7:node3:meter_watts
2025-02-06 20:34:45.160 [DEBUG] [ternal.converter.ZWaveMeterConverter] - NODE 3: Generating poll message for COMMAND_CLASS_METER, endpoint 0
2025-02-06 20:34:45.161 [DEBUG] [ternal.converter.ZWaveMeterConverter] - NODE 3: Generating poll message for COMMAND_CLASS_METER, endpoint 0
2025-02-06 20:34:45.161 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 3: Creating new message for application command METER_GET
2025-02-06 20:34:45.162 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_METER
2025-02-06 20:34:45.162 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Command Class COMMAND_CLASS_METER is NOT required to be secured
2025-02-06 20:34:45.163 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Polling zwave:device:49c171dfd7:node3:switch_dimmer1
2025-02-06 20:34:45.163 [DEBUG] [erter.ZWaveMultiLevelSwitchConverter] - NODE 3: Generating poll message for COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 1
2025-02-06 20:34:45.164 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 3: Creating new message for command SWITCH_MULTILEVEL_GET
2025-02-06 20:34:45.164 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Encapsulating message, instance / endpoint 1
2025-02-06 20:34:45.165 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 3: Creating new message for command MULTI_CHANNEL_ENCAP endpoint 1
2025-02-06 20:34:45.165 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_MULTI_CHANNEL
2025-02-06 20:34:45.165 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Command Class COMMAND_CLASS_MULTI_CHANNEL is NOT required to be secured
2025-02-06 20:34:45.166 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Polling skipped for zwave:device:49c171dfd7:node3:switch_dimmer1 on COMMAND_CLASS_BASIC
2025-02-06 20:34:45.166 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Polling zwave:device:49c171dfd7:node3:switch_dimmer2
2025-02-06 20:34:45.167 [DEBUG] [erter.ZWaveMultiLevelSwitchConverter] - NODE 3: Generating poll message for COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 2
2025-02-06 20:34:45.167 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 3: Creating new message for command SWITCH_MULTILEVEL_GET
2025-02-06 20:34:45.167 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Encapsulating message, instance / endpoint 2
2025-02-06 20:34:45.168 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 3: Creating new message for command MULTI_CHANNEL_ENCAP endpoint 2
2025-02-06 20:34:45.168 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_MULTI_CHANNEL
2025-02-06 20:34:45.169 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Command Class COMMAND_CLASS_MULTI_CHANNEL is NOT required to be secured
2025-02-06 20:34:45.169 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Polling skipped for zwave:device:49c171dfd7:node3:switch_dimmer2 on COMMAND_CLASS_BASIC
2025-02-06 20:34:45.170 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Adding to device queue
2025-02-06 20:34:45.170 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Added 33571 to queue - size 1
2025-02-06 20:34:45.170 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2025-02-06 20:34:45.171 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 03 02 26 02 25 14 F1
2025-02-06 20:34:45.172 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 3: Sending REQUEST Message = 01 09 00 13 03 02 26 02 25 14 F1
2025-02-06 20:34:45.174 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2025-02-06 20:34:45.175 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2025-02-06 20:34:45.176 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2025-02-06 20:34:45.176 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2025-02-06 20:34:45.177 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2025-02-06 20:34:45.177 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2025-02-06 20:34:45.178 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2025-02-06 20:34:45.183 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2025-02-06 20:34:45.184 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 33571: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 20
2025-02-06 20:34:45.185 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Adding to device queue
2025-02-06 20:34:45.185 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Added 33572 to queue - size 1
2025-02-06 20:34:45.186 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2025-02-06 20:34:45.186 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Adding to device queue
2025-02-06 20:34:45.187 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Added 33573 to queue - size 2
2025-02-06 20:34:45.187 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2025-02-06 20:34:45.188 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Adding to device queue
2025-02-06 20:34:45.189 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Added 33574 to queue - size 3
2025-02-06 20:34:45.189 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2025-02-06 20:34:45.189 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Adding to device queue
2025-02-06 20:34:45.190 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Added 33575 to queue - size 4
2025-02-06 20:34:45.190 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2025-02-06 20:34:45.191 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2025-02-06 20:34:45.195 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2025-02-06 20:34:45.196 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2025-02-06 20:34:45.197 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 33571: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 20
2025-02-06 20:34:45.197 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2025-02-06 20:34:45.198 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 33571: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 20
2025-02-06 20:34:45.198 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2025-02-06 20:34:45.199 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 3: sentData successfully placed on stack.
2025-02-06 20:34:45.199 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 33571: Advanced to WAIT_REQUEST
2025-02-06 20:34:45.199 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: TID 33571: Transaction not completed
2025-02-06 20:34:45.200 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2025-02-06 20:34:45.200 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2025-02-06 20:34:45.336 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 18 00 13 14 00 00 10 01 C1 7F 7F 7F 7F 00 00 03 11 00 00 00 03 03 00 00 22
2025-02-06 20:34:45.348 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=20, payload=14 00 00 10 01 C1 7F 7F 7F 7F 00 00 03 11 00 00 00 03 03 00 00
2025-02-06 20:34:45.349 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=20, payload=14 00 00 10 01 C1 7F 7F 7F 7F 00 00 03 11 00 00 00 03 03 00 00
2025-02-06 20:34:45.349 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 33571: [WAIT_REQUEST] priority=Get, requiresResponse=true, callback: 20
2025-02-06 20:34:45.350 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2025-02-06 20:34:45.350 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 33571: [WAIT_REQUEST] priority=Get, requiresResponse=true, callback: 20
2025-02-06 20:34:45.351 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 33571: (Callback 20)
2025-02-06 20:34:45.351 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2025-02-06 20:34:45.351 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 33571: callback 20
2025-02-06 20:34:45.352 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=20, payload=14 00 00 10 01 C1 7F 7F 7F 7F 00 00 03 11 00 00 00 03 03 00 00
2025-02-06 20:34:45.353 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 3: SendData Request. CallBack ID = 20, Status = Transmission complete and ACK received(0)
2025-02-06 20:34:45.353 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: resetResendCount initComplete=true isDead=false
2025-02-06 20:34:45.354 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 33571: Advanced to WAIT_DATA
2025-02-06 20:34:45.354 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: TID 33571: Transaction not completed
2025-02-06 20:34:45.354 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2025-02-06 20:34:45.355 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2025-02-06 20:34:45.404 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0B 00 04 00 03 03 26 03 63 C1 00 77
2025-02-06 20:34:45.416 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=3, callback=0, payload=00 03 03 26 03 63 C1 00
2025-02-06 20:34:45.417 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=3, callback=0, payload=00 03 03 26 03 63 C1 00
2025-02-06 20:34:45.417 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2025-02-06 20:34:45.418 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Application Command Request (ALIVE:DONE)
2025-02-06 20:34:45.418 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: resetResendCount initComplete=true isDead=false
2025-02-06 20:34:45.418 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 0
2025-02-06 20:34:45.419 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_SWITCH_MULTILEVEL
2025-02-06 20:34:45.419 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 3: Received COMMAND_CLASS_SWITCH_MULTILEVEL V3 SWITCH_MULTILEVEL_REPORT
2025-02-06 20:34:45.420 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 3: Switch Multi Level report, value = 99
2025-02-06 20:34:45.420 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2025-02-06 20:34:45.421 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SWITCH_MULTILEVEL, value=99
2025-02-06 20:34:45.421 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Updating channel state zwave:device:49c171dfd7:node3:switch_dimmer to 100 [PercentType]
2025-02-06 20:34:45.422 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Commands processed 1.
2025-02-06 20:34:45.423 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@4acc8db3.
2025-02-06 20:34:45.423 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@4acc8db3.
2025-02-06 20:34:45.424 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: notifyTransactionResponse TID:33571 DONE
2025-02-06 20:34:45.428 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2025-02-06 20:34:45.429 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2025-02-06 20:34:45.429 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2025-02-06 20:34:45.430 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2025-02-06 20:34:45.431 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2025-02-06 20:34:45.432 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 03 03 32 01 00 25 15 E5
2025-02-06 20:34:45.433 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 3: Sending REQUEST Message = 01 0A 00 13 03 03 32 01 00 25 15 E5
2025-02-06 20:34:45.435 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2025-02-06 20:34:45.436 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2025-02-06 20:34:45.439 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2025-02-06 20:34:45.447 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2025-02-06 20:34:45.448 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 33572: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 21
2025-02-06 20:34:45.449 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2025-02-06 20:34:45.449 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 33572: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 21
2025-02-06 20:34:45.449 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2025-02-06 20:34:45.450 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2025-02-06 20:34:45.450 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2025-02-06 20:34:45.459 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2025-02-06 20:34:45.460 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2025-02-06 20:34:45.461 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 33572: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 21
2025-02-06 20:34:45.461 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2025-02-06 20:34:45.462 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 33572: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 21
2025-02-06 20:34:45.462 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2025-02-06 20:34:45.462 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 3: sentData successfully placed on stack.
2025-02-06 20:34:45.463 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 33572: Advanced to WAIT_REQUEST
2025-02-06 20:34:45.463 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: TID 33572: Transaction not completed
2025-02-06 20:34:45.463 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2025-02-06 20:34:45.464 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2025-02-06 20:34:45.522 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 18 00 13 15 00 00 09 01 C1 7F 7F 7F 7F 00 00 03 11 00 00 00 03 01 00 00 38
2025-02-06 20:34:45.536 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=21, payload=15 00 00 09 01 C1 7F 7F 7F 7F 00 00 03 11 00 00 00 03 01 00 00
2025-02-06 20:34:45.536 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=21, payload=15 00 00 09 01 C1 7F 7F 7F 7F 00 00 03 11 00 00 00 03 01 00 00
2025-02-06 20:34:45.537 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 33572: [WAIT_REQUEST] priority=Get, requiresResponse=true, callback: 21
2025-02-06 20:34:45.537 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2025-02-06 20:34:45.538 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 33572: [WAIT_REQUEST] priority=Get, requiresResponse=true, callback: 21
2025-02-06 20:34:45.538 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 33572: (Callback 21)
2025-02-06 20:34:45.538 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2025-02-06 20:34:45.539 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 33572: callback 21
2025-02-06 20:34:45.539 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=21, payload=15 00 00 09 01 C1 7F 7F 7F 7F 00 00 03 11 00 00 00 03 01 00 00
2025-02-06 20:34:45.540 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 3: SendData Request. CallBack ID = 21, Status = Transmission complete and ACK received(0)
2025-02-06 20:34:45.540 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: resetResendCount initComplete=true isDead=false
2025-02-06 20:34:45.541 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 33572: Advanced to WAIT_DATA
2025-02-06 20:34:45.541 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: TID 33572: Transaction not completed
2025-02-06 20:34:45.541 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2025-02-06 20:34:45.541 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2025-02-06 20:34:45.597 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 12 00 04 00 03 0A 32 02 21 44 00 00 1B 6F 00 00 C1 00 00
2025-02-06 20:34:45.632 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=3, callback=0, payload=00 03 0A 32 02 21 44 00 00 1B 6F 00 00 C1 00
2025-02-06 20:34:45.633 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=3, callback=0, payload=00 03 0A 32 02 21 44 00 00 1B 6F 00 00 C1 00
2025-02-06 20:34:45.633 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2025-02-06 20:34:45.634 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Application Command Request (ALIVE:DONE)
2025-02-06 20:34:45.634 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: resetResendCount initComplete=true isDead=false
2025-02-06 20:34:45.634 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Incoming command class COMMAND_CLASS_METER, endpoint 0
2025-02-06 20:34:45.635 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_METER
2025-02-06 20:34:45.635 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 3: Received COMMAND_CLASS_METER V3 METER_REPORT
2025-02-06 20:34:45.636 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 3: Meter: Type=Electric(1), Scale=kWh(0), Value=70.23
2025-02-06 20:34:45.636 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveMeterValueEvent
2025-02-06 20:34:45.637 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_METER, value=70.23
2025-02-06 20:34:45.637 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Updating channel state zwave:device:49c171dfd7:node3:meter_kwh to 70.23 [DecimalType]
2025-02-06 20:34:45.638 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Commands processed 1.
2025-02-06 20:34:45.638 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@31616f81.
2025-02-06 20:34:45.639 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@31616f81.
2025-02-06 20:34:45.640 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: notifyTransactionResponse TID:33572 DONE
2025-02-06 20:34:45.641 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2025-02-06 20:34:45.642 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2025-02-06 20:34:45.643 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2025-02-06 20:34:45.643 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2025-02-06 20:34:45.643 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2025-02-06 20:34:45.644 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 03 03 32 01 10 25 16 F6
2025-02-06 20:34:45.644 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 3: Sending REQUEST Message = 01 0A 00 13 03 03 32 01 10 25 16 F6
2025-02-06 20:34:45.647 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2025-02-06 20:34:45.647 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2025-02-06 20:34:45.651 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2025-02-06 20:34:45.655 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2025-02-06 20:34:45.656 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 33573: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 22
2025-02-06 20:34:45.656 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2025-02-06 20:34:45.657 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 33573: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 22
2025-02-06 20:34:45.657 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2025-02-06 20:34:45.657 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2025-02-06 20:34:45.657 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2025-02-06 20:34:45.667 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2025-02-06 20:34:45.668 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2025-02-06 20:34:45.668 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 33573: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 22
2025-02-06 20:34:45.669 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2025-02-06 20:34:45.669 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 33573: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 22
2025-02-06 20:34:45.669 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2025-02-06 20:34:45.670 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 3: sentData successfully placed on stack.
2025-02-06 20:34:45.670 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 33573: Advanced to WAIT_REQUEST
2025-02-06 20:34:45.670 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: TID 33573: Transaction not completed
2025-02-06 20:34:45.670 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2025-02-06 20:34:45.671 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2025-02-06 20:34:45.712 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 18 00 13 16 00 00 07 01 C1 7F 7F 7F 7F 00 00 03 11 00 00 00 03 01 00 00 35
2025-02-06 20:34:45.724 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=22, payload=16 00 00 07 01 C1 7F 7F 7F 7F 00 00 03 11 00 00 00 03 01 00 00
2025-02-06 20:34:45.724 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=22, payload=16 00 00 07 01 C1 7F 7F 7F 7F 00 00 03 11 00 00 00 03 01 00 00
2025-02-06 20:34:45.725 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 33573: [WAIT_REQUEST] priority=Get, requiresResponse=true, callback: 22
2025-02-06 20:34:45.725 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2025-02-06 20:34:45.725 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 33573: [WAIT_REQUEST] priority=Get, requiresResponse=true, callback: 22
2025-02-06 20:34:45.726 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 33573: (Callback 22)
2025-02-06 20:34:45.726 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2025-02-06 20:34:45.726 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 33573: callback 22
2025-02-06 20:34:45.727 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=22, payload=16 00 00 07 01 C1 7F 7F 7F 7F 00 00 03 11 00 00 00 03 01 00 00
2025-02-06 20:34:45.727 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 3: SendData Request. CallBack ID = 22, Status = Transmission complete and ACK received(0)
2025-02-06 20:34:45.728 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: resetResendCount initComplete=true isDead=false
2025-02-06 20:34:45.728 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 33573: Advanced to WAIT_DATA
2025-02-06 20:34:45.729 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: TID 33573: Transaction not completed
2025-02-06 20:34:45.729 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2025-02-06 20:34:45.729 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2025-02-06 20:34:45.786 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 00 03 08 32 02 21 32 01 E1 00 00 C1 00 E2
2025-02-06 20:34:45.795 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=3, callback=0, payload=00 03 08 32 02 21 32 01 E1 00 00 C1 00
2025-02-06 20:34:45.796 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=3, callback=0, payload=00 03 08 32 02 21 32 01 E1 00 00 C1 00
2025-02-06 20:34:45.797 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2025-02-06 20:34:45.797 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Application Command Request (ALIVE:DONE)
2025-02-06 20:34:45.797 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: resetResendCount initComplete=true isDead=false
2025-02-06 20:34:45.798 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Incoming command class COMMAND_CLASS_METER, endpoint 0
2025-02-06 20:34:45.798 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_METER
2025-02-06 20:34:45.798 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 3: Received COMMAND_CLASS_METER V3 METER_REPORT
2025-02-06 20:34:45.799 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 3: Meter: Type=Electric(1), Scale=W(2), Value=48.1
2025-02-06 20:34:45.799 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveMeterValueEvent
2025-02-06 20:34:45.800 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_METER, value=48.1
2025-02-06 20:34:45.800 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Updating channel state zwave:device:49c171dfd7:node3:meter_watts to 48.1 [DecimalType]
2025-02-06 20:34:45.801 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Commands processed 1.
2025-02-06 20:34:45.802 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@160a1638.
2025-02-06 20:34:45.803 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@160a1638.
2025-02-06 20:34:45.804 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: notifyTransactionResponse TID:33573 DONE
2025-02-06 20:34:45.806 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2025-02-06 20:34:45.807 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2025-02-06 20:34:45.808 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2025-02-06 20:34:45.808 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2025-02-06 20:34:45.809 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2025-02-06 20:34:45.810 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0D 00 13 03 06 60 0D 01 01 26 02 25 17 9F
2025-02-06 20:34:45.811 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 3: Sending REQUEST Message = 01 0D 00 13 03 06 60 0D 01 01 26 02 25 17 9F
2025-02-06 20:34:45.813 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2025-02-06 20:34:45.814 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2025-02-06 20:34:45.817 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2025-02-06 20:34:45.823 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2025-02-06 20:34:45.824 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 33574: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 23
2025-02-06 20:34:45.825 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2025-02-06 20:34:45.825 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 33574: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 23
2025-02-06 20:34:45.825 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2025-02-06 20:34:45.826 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2025-02-06 20:34:45.826 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2025-02-06 20:34:45.835 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2025-02-06 20:34:45.836 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2025-02-06 20:34:45.837 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 33574: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 23
2025-02-06 20:34:45.837 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2025-02-06 20:34:45.837 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 33574: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 23
2025-02-06 20:34:45.838 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2025-02-06 20:34:45.838 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 3: sentData successfully placed on stack.
2025-02-06 20:34:45.839 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 33574: Advanced to WAIT_REQUEST
2025-02-06 20:34:45.839 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: TID 33574: Transaction not completed
2025-02-06 20:34:45.839 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2025-02-06 20:34:45.840 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2025-02-06 20:34:45.903 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 18 00 13 17 00 00 09 01 C1 7F 7F 7F 7F 00 00 03 11 00 00 00 03 01 00 00 3A
2025-02-06 20:34:45.915 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=23, payload=17 00 00 09 01 C1 7F 7F 7F 7F 00 00 03 11 00 00 00 03 01 00 00
2025-02-06 20:34:45.916 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=23, payload=17 00 00 09 01 C1 7F 7F 7F 7F 00 00 03 11 00 00 00 03 01 00 00
2025-02-06 20:34:45.917 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 33574: [WAIT_REQUEST] priority=Get, requiresResponse=true, callback: 23
2025-02-06 20:34:45.917 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2025-02-06 20:34:45.917 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 33574: [WAIT_REQUEST] priority=Get, requiresResponse=true, callback: 23
2025-02-06 20:34:45.918 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 33574: (Callback 23)
2025-02-06 20:34:45.918 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2025-02-06 20:34:45.918 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 33574: callback 23
2025-02-06 20:34:45.919 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=23, payload=17 00 00 09 01 C1 7F 7F 7F 7F 00 00 03 11 00 00 00 03 01 00 00
2025-02-06 20:34:45.919 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 3: SendData Request. CallBack ID = 23, Status = Transmission complete and ACK received(0)
2025-02-06 20:34:45.920 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: resetResendCount initComplete=true isDead=false
2025-02-06 20:34:45.920 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 33574: Advanced to WAIT_DATA
2025-02-06 20:34:45.920 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: TID 33574: Transaction not completed
2025-02-06 20:34:45.921 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2025-02-06 20:34:45.921 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2025-02-06 20:34:45.975 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0F 00 04 00 03 07 60 0D 01 01 26 03 63 C1 00 1A
2025-02-06 20:34:45.426 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Licht_Bad_Dimmer' changed from 0 to 100
2025-02-06 20:34:45.804 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Licht_Bad_Electric_meter_watts_Deprecated' changed from 0 to 48.1
2025-02-06 20:34:45.992 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=3, callback=0, payload=00 03 07 60 0D 01 01 26 03 63 C1 00
2025-02-06 20:34:45.993 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=3, callback=0, payload=00 03 07 60 0D 01 01 26 03 63 C1 00
2025-02-06 20:34:45.993 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2025-02-06 20:34:45.994 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Application Command Request (ALIVE:DONE)
2025-02-06 20:34:45.994 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: resetResendCount initComplete=true isDead=false
2025-02-06 20:34:45.995 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2025-02-06 20:34:45.995 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 1
2025-02-06 20:34:45.996 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_SWITCH_MULTILEVEL
2025-02-06 20:34:45.997 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 3: Received COMMAND_CLASS_SWITCH_MULTILEVEL V3 SWITCH_MULTILEVEL_REPORT
2025-02-06 20:34:45.997 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 3: Switch Multi Level report, value = 99
2025-02-06 20:34:45.998 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2025-02-06 20:34:45.999 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got a value event from Z-Wave network, endpoint=1, command class=COMMAND_CLASS_SWITCH_MULTILEVEL, value=99
2025-02-06 20:34:45.999 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Updating channel state zwave:device:49c171dfd7:node3:switch_dimmer1 to 100 [PercentType]
2025-02-06 20:34:46.000 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Commands processed 1.
2025-02-06 20:34:46.001 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@4a0d9d74.
2025-02-06 20:34:46.003 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@4a0d9d74.
2025-02-06 20:34:46.004 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: notifyTransactionResponse TID:33574 DONE
2025-02-06 20:34:46.006 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2025-02-06 20:34:46.007 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2025-02-06 20:34:46.008 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2025-02-06 20:34:46.008 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2025-02-06 20:34:46.009 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2025-02-06 20:34:46.010 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0D 00 13 03 06 60 0D 01 02 26 02 25 18 93
2025-02-06 20:34:46.012 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 3: Sending REQUEST Message = 01 0D 00 13 03 06 60 0D 01 02 26 02 25 18 93
2025-02-06 20:34:46.015 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2025-02-06 20:34:46.016 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2025-02-06 20:34:46.019 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2025-02-06 20:34:46.027 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2025-02-06 20:34:46.028 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 33575: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 24
2025-02-06 20:34:46.029 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2025-02-06 20:34:46.030 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 33575: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 24
2025-02-06 20:34:46.031 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2025-02-06 20:34:46.031 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2025-02-06 20:34:46.032 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2025-02-06 20:34:46.039 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2025-02-06 20:34:46.041 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2025-02-06 20:34:46.041 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 33575: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 24
2025-02-06 20:34:46.042 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2025-02-06 20:34:46.043 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 33575: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 24
2025-02-06 20:34:46.043 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2025-02-06 20:34:46.044 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 3: sentData successfully placed on stack.
2025-02-06 20:34:46.045 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 33575: Advanced to WAIT_REQUEST
2025-02-06 20:34:46.045 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: TID 33575: Transaction not completed
2025-02-06 20:34:46.046 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2025-02-06 20:34:46.046 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2025-02-06 20:34:46.093 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 18 00 13 18 00 00 08 01 C1 7F 7F 7F 7F 00 00 03 11 00 00 00 03 01 00 00 34
2025-02-06 20:34:46.104 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=24, payload=18 00 00 08 01 C1 7F 7F 7F 7F 00 00 03 11 00 00 00 03 01 00 00
2025-02-06 20:34:46.105 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=24, payload=18 00 00 08 01 C1 7F 7F 7F 7F 00 00 03 11 00 00 00 03 01 00 00
2025-02-06 20:34:46.105 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 33575: [WAIT_REQUEST] priority=Get, requiresResponse=true, callback: 24
2025-02-06 20:34:46.105 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2025-02-06 20:34:46.106 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 33575: [WAIT_REQUEST] priority=Get, requiresResponse=true, callback: 24
2025-02-06 20:34:46.106 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 33575: (Callback 24)
2025-02-06 20:34:46.106 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2025-02-06 20:34:46.106 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 33575: callback 24
2025-02-06 20:34:46.107 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=24, payload=18 00 00 08 01 C1 7F 7F 7F 7F 00 00 03 11 00 00 00 03 01 00 00
2025-02-06 20:34:46.107 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 3: SendData Request. CallBack ID = 24, Status = Transmission complete and ACK received(0)
2025-02-06 20:34:46.107 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: resetResendCount initComplete=true isDead=false
2025-02-06 20:34:46.107 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 33575: Advanced to WAIT_DATA
2025-02-06 20:34:46.108 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: TID 33575: Transaction not completed
2025-02-06 20:34:46.108 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2025-02-06 20:34:46.108 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2025-02-06 20:34:46.165 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0F 00 04 00 03 07 60 0D 02 01 26 03 00 C1 00 7A
2025-02-06 20:34:46.175 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=3, callback=0, payload=00 03 07 60 0D 02 01 26 03 00 C1 00
2025-02-06 20:34:46.176 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=3, callback=0, payload=00 03 07 60 0D 02 01 26 03 00 C1 00
2025-02-06 20:34:46.176 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2025-02-06 20:34:46.177 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Application Command Request (ALIVE:DONE)
2025-02-06 20:34:46.177 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: resetResendCount initComplete=true isDead=false
2025-02-06 20:34:46.177 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2025-02-06 20:34:46.177 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 2
2025-02-06 20:34:46.177 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 3: SECURITY NOT required on COMMAND_CLASS_SWITCH_MULTILEVEL
2025-02-06 20:34:46.178 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 3: Received COMMAND_CLASS_SWITCH_MULTILEVEL V3 SWITCH_MULTILEVEL_REPORT
2025-02-06 20:34:46.178 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 3: Switch Multi Level report, value = 0
2025-02-06 20:34:46.178 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2025-02-06 20:34:46.178 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got a value event from Z-Wave network, endpoint=2, command class=COMMAND_CLASS_SWITCH_MULTILEVEL, value=0
2025-02-06 20:34:46.179 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Updating channel state zwave:device:49c171dfd7:node3:switch_dimmer2 to 0 [PercentType]
2025-02-06 20:34:46.179 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Commands processed 1.
2025-02-06 20:34:46.180 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@64822093.
2025-02-06 20:34:46.180 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@64822093.
2025-02-06 20:34:46.181 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 3: notifyTransactionResponse TID:33575 DONE
2025-02-06 20:34:46.182 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2025-02-06 20:34:46.182 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2025-02-06 20:34:46.183 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2025-02-06 20:34:46.183 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2025-02-06 20:34:46.183 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
