I am running Openhab 2.5 on a linux machine.
I wanted to connect some door/window sensors. I got me a fibaro systems door/window sensor 2 (FGDW-002).
As most of the functionality works (temperature, battery levels, tampering), the door sensor itself does not work. I have created a “contact” item that is connected with the nodes door sensor channel:
Contact entry_door "Door Entry [%s]" <door> { channel="zwave:device:controller:node4:sensor_door" }
While my ZWave PIR sensors work and trigger updates to their items, the door contact does not trigger any update whatsoever.
if I am checking the ZWave logs (in this case from opening the door) I see the command being sent from the sensor:
17:54:25.470 [DEBUG] [ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0B 00 04 08 04 03 20 01 63 CA 00 77
17:54:25.473 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=4, callback=8, payload=08 04 03 20 01 63 CA 00
17:54:25.477 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=4, callback=8, payload=08 04 03 20 01 63 CA 00
17:54:25.479 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - lastTransaction null
17:54:25.480 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 4: Application Command Request (ALIVE:REQUEST_NIF)
17:54:25.481 [DEBUG] [ing.zwave.internal.protocol.ZWaveNode] - NODE 4: Incoming command class COMMAND_CLASS_BASIC, endpoint 0
17:54:25.483 [DEBUG] [ing.zwave.internal.protocol.ZWaveNode] - NODE 4: SECURITY not supported
17:54:25.485 [DEBUG] [otocol.commandclass.ZWaveCommandClass] - NODE 4: Received COMMAND_CLASS_BASIC V0 BASIC_SET
17:54:25.486 [DEBUG] [l.commandclass.ZWaveBasicCommandClass] - NODE 4: Basic report, value = 99
17:54:25.487 [DEBUG] [ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0B 00 04 00 04 03 20 01 63 DB 00 6E
17:54:25.487 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
17:54:25.489 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 4: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_BASIC, value = 99
17:54:25.489 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=4, callback=0, payload=00 04 03 20 01 63 DB 00
17:54:25.491 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 4: Commands processed 1.
17:54:25.492 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 4: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@35c4bed6.
17:54:25.493 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
17:54:25.494 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
17:54:25.494 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=4, callback=0, payload=00 04 03 20 01 63 DB 00
17:54:25.495 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - lastTransaction null
17:54:25.496 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 4: Application Command Request (ALIVE:REQUEST_NIF)
17:54:25.497 [DEBUG] [ing.zwave.internal.protocol.ZWaveNode] - NODE 4: Incoming command class COMMAND_CLASS_BASIC, endpoint 0
17:54:25.497 [DEBUG] [ing.zwave.internal.protocol.ZWaveNode] - NODE 4: SECURITY not supported
17:54:25.498 [DEBUG] [otocol.commandclass.ZWaveCommandClass] - NODE 4: Received COMMAND_CLASS_BASIC V0 BASIC_SET
17:54:25.499 [DEBUG] [l.commandclass.ZWaveBasicCommandClass] - NODE 4: Basic report, value = 99
17:54:25.499 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
17:54:25.500 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 4: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_BASIC, value = 99
17:54:25.501 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 4: Commands processed 1.
17:54:25.502 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 4: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@7fcb0a65.
17:54:25.502 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
17:54:25.503 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
17:54:25.504 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
17:54:25.504 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
my sensor is configured in the following way:
- 1: closed when near
- 2: open/close indication on
- 2: wakeup indication off
- 2: tamper indication off
- 3: tried any of these values. currently at “none as secure”
- 11: switch after open and close
- 12: 99
- 13: 0
- 14: 0
- 15: 0
Associations:
- 1: Lifeline: Controller
- 2: on/off: Controller
- 3: tamper: none
properties:
I tried reboots of the system, removing the sensor, repowering the sensor… nothing worked.
