Hi Chris,
Chris Jackson himself
I really appreciate your effort for the community - your answers in many other threads really solved most of my problems when installing the Razberry board (Update Binding, make board reachable with AMA0, etc…)
Thanks for the info. Just tried to figure out how to do that (I am new to openhab). I guess this is what you are looking for and it seems like the device is not awake. Wondering how that is possible if it is sending data, manually waking up the device does not help unfortunately, although it works during initial configuration and initialising. (reseted both the controller and the door sensor like 10 times already to make it work
Note: 197 | Active | 80 | 2.1.0.201705281057 | ZWave Binding
The log contains two actions: removing the magnet from the sensor and attach it again.
12:35:22.536 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_4fdd66f2_serial_sof changed from 406 to 407
12:35:22.541 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 13 00 04 00 02 0D 56 01 71 05 00 00 00 FF 06 16 00 FF C5 11
12:35:22.584 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Response SENT 6
12:35:22.593 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage inputMessage: class=ApplicationCommandHandler[0x04], type=Request[0x00], dest=2, callback=0, payload=00 02 0D 56 01 71 05 00 00 00 FF 06 16 00 FF C5
12:35:22.600 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lockMessage: class=ApplicationCommandHandler[0x04], type=Request[0x00], dest=2, callback=0, payload=00 02 0D 56 01 71 05 00 00 00 FF 06 16 00 FF C5
12:35:22.609 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], dest=2, callback=0, payload=00 02 0D 56 01 71 05 00 00 00 FF 06 16 00 FF C5
12:35:22.620 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
12:35:22.621 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Application Command Request (ALIVE:DONE)
12:35:22.622 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: resetResendCount initComplete=true isDead=false
12:35:22.629 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Decapsulating COMMAND_CLASS_CRC_16_ENCAP
12:35:22.635 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
12:35:22.640 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: SECURITY NOT required on COMMAND_CLASS_ALARM
12:35:22.645 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Received COMMAND_CLASS_ALARM V5 NOTIFICATION_REPORT
12:35:22.653 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Commands processed 1.
12:35:22.656 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@aa1314.
12:35:22.659 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
12:35:22.662 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
12:35:22.665 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
12:35:22.668 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start
12:35:22.672 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: listening == false, frequentlyListening == false, awake == false
12:35:22.675 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Node not awake!
12:35:22.679 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: listening == false, frequentlyListening == false, awake == false
12:35:22.682 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Node not awake!
12:35:22.685 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: listening == false, frequentlyListening == false, awake == false
12:35:22.690 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Node not awake!
12:35:22.695 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction from controllerQueue
12:35:22.698 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage nothing
12:35:27.114 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 13 00 04 00 02 0D 56 01 71 05 00 00 00 FF 06 17 00 CC F4 12
12:35:27.117 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_4fdd66f2_serial_sof changed from 407 to 408
12:35:27.144 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Response SENT 6
12:35:27.149 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage inputMessage: class=ApplicationCommandHandler[0x04], type=Request[0x00], dest=2, callback=0, payload=00 02 0D 56 01 71 05 00 00 00 FF 06 17 00 CC F4
12:35:27.157 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lockMessage: class=ApplicationCommandHandler[0x04], type=Request[0x00], dest=2, callback=0, payload=00 02 0D 56 01 71 05 00 00 00 FF 06 17 00 CC F4
12:35:27.165 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], dest=2, callback=0, payload=00 02 0D 56 01 71 05 00 00 00 FF 06 17 00 CC F4
12:35:27.175 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
12:35:27.178 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Application Command Request (ALIVE:DONE)
12:35:27.184 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: resetResendCount initComplete=true isDead=false
12:35:27.188 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Decapsulating COMMAND_CLASS_CRC_16_ENCAP
12:35:27.192 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
12:35:27.195 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: SECURITY NOT required on COMMAND_CLASS_ALARM
12:35:27.201 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Received COMMAND_CLASS_ALARM V5 NOTIFICATION_REPORT
12:35:27.226 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Commands processed 1.
12:35:27.230 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@e104f6.
12:35:27.233 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
12:35:27.236 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
12:35:27.239 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
12:35:27.242 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start
12:35:27.246 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: listening == false, frequentlyListening == false, awake == false
12:35:27.250 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Node not awake!
12:35:27.254 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: listening == false, frequentlyListening == false, awake == false
12:35:27.258 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Node not awake!
12:35:27.261 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: listening == false, frequentlyListening == false, awake == false
12:35:27.264 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Node not awake!
12:35:27.267 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction from controllerQueue
12:35:27.270 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage nothing
