I have a Fibaro FGK-101-ZW5 door/window sensor, with a temperature sensor.
My problem is that I don’t receive temperature updates in OpenHAB. Door binary sensor and batter level are reported correcty, but not the temperature. The sensor is properly installed (I have measured voltage with a multimeter), I included the device AFTER the installation of the temperature sensir and I am pretty sure that the parameters of the device are correctly set so I think it should send temperature readings.
I have other devices of this kind working perfectly, and the configuration is the same for all of them:
Contact ctPuerta {zwave=“25:0:command=sensor_binary,respond_to_basic=true,refresh_interval=0”}
Number nbTempPuerta {zwave=“25:2:command=sensor_multilevel,sensor_type=1,refresh_interval=0”}
Dimmer dmBateriaSensorPuerta {zwave=“25:0:command=battery,refresh_interval=3600”}
This configutarion works for the other devices, but not the temperature readings for this new device.
My controller is an Aeon Labs Z-Stick (the old one, not Gen5) assigned to the FGK-101-ZW5 association group named “Sensor ZW-3”.
The thing is that the other devices that I have and work are the old version (Fibaro FGK-101, not the new Gen5 version), so I guess the problem may be in the command class.
Does any one how to configure this for OpenHAB 1.8???
Please help.
