When going into the PaperUI, and try to edit the parameters of the Fibaro FGD212 Dimmer 2, the blue button to save the settings is not working (darkish colour) and thus I’m unable to save the settings. It does work for other brands of Z-Wave devices.
I use an AeonLabs Z-stick Gen 5 and the latest snapshot of OpenHAB (openHAB 2.3.0 Build #1206).
No it’s a fresh install and it’s like this from the start. Really strange that the Fibaro has the problem, whereas the Qubino ZMNHDD Flush Dimmer I also have does not…
Very strange… now suddenly I don’t have any configuration parameters for any of the Z-Wave devices. It just shows the Device Configuration with the Polling Period and the Switch All Mode options. But now in HABMin they are also unavailable (under “Device Configuration”)!
What happened to my parameters???
I am using the latest snapshot (just upgraded again through apt-get upgrade). I needed to install the Z-Wave binding again for that. Could that have been the cause?
Indeed, that’s exactly the same problem. I’ll cross-link it.
I hope we can find out the cause. Any ideas for what I can try? I’m using openHAB 2.3.0 Build #1214 (latest snapshot) with the Aeon Labs Z-Stick Gen5 and a mix of Z-wave devices.
