I must be doing something wrong but I cannot figure it out.
I have purchased 4 new Fibaro Flood Sensors FGFS-101 v3.4 (US) and I have been trying to discover them and looking in the device list it should be in the database. Looking through old posts it seemed it was added about 2 years ago?
I am currently running 2.5.10 release (I have not made the jump to 3.0 yet). When the device is discovered I allow it to be full discovered by waking it up constantly and it has a device id (010F:0B01:2003:3.4).
I have the discovery debug logs but they are too large to post… when the binding goes through the database it is not found. I have tried 2 of these with the same result with multiple discoveries. Can you point me in the right direction or does something need to be added to the database? Is there anything else in the logs that I can post that will help set some direction?
020-12-29 10:41:16.788 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 28: Unable to find thing type (010F:0B01:2003:3.4)
2020-12-29 10:41:16.789 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 28: Controller status changed to ONLINE.
2020-12-29 10:41:16.790 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 28: Controller is ONLINE. Starting device initialisation.
2020-12-29 10:41:16.798 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 28: Updating node properties.
2020-12-29 10:41:16.803 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 28: Updating node properties. MAN=271
2020-12-29 10:41:16.803 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 28: Updating node properties. MAN=271. SET. Was 271
2020-12-29 10:41:16.805 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 28: Properties synchronised
2020-12-29 10:41:16.811 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 28: Update ASSOCIATION group_ZWaveAssociationGroup [index=1, name=Lifeline, profile1=0, profile2=1, associations=[node_1]]: Adding Controller (node_1)
2020-12-29 10:41:16.812 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 28: Configuration synchronised
2020-12-29 10:41:16.818 [DEBUG] [ve.internal.protocol.ZWaveController] - Event listener added.
2020-12-29 10:41:16.819 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 28: Initialising Thing Node…
2020-12-29 10:41:16.820 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 28: Polling initialised at 1800 seconds - start in 1605600 milliseconds.
2020-12-29 10:41:16.821 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 28: Device initialisation complete.
