2015-10-01 18:06:17.999 [INFO ] [rialApiGetInitDataMessageClass] - ZWave Controller is Primary Controller
2015-10-01 18:06:18.000 [INFO ] [rialApiGetInitDataMessageClass] - ------------Number of Nodes Found Registered to ZWave Controller------------
2015-10-01 18:06:18.002 [INFO ] [rialApiGetInitDataMessageClass] - # Nodes = 5
2015-10-01 18:06:18.003 [INFO ] [rialApiGetInitDataMessageClass] - ----------------------------------------------------------------------------
2015-10-01 18:06:21.954 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 2: Unsupported command class SWITCH_ALL
2015-10-01 18:06:22.073 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 6: Unsupported command class SWITCH_ALL
2015-10-01 18:07:16.275 [ERROR] [b.x.internal.XbmcActiveBinding] - Connection failed for ‘#bedroom’ on 192.168.1.105
2015-10-01 18:08:16.312 [ERROR] [b.x.internal.XbmcActiveBinding] - Connection failed for ‘#living’ on 192.168.1.123
2015-10-01 18:31:23.879 [INFO ] [c.internal.ModelRepositoryImpl] - Refreshing model ‘default.sitemap’
2015-10-01 18:35:51.520 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 5: Unsupported command class MULTI_INSTANCE_ASSOCIATION
2015-10-01 18:35:54.884 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@8f7eb8, ignoring.
2015-10-01 18:35:55.052 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@d9003a, ignoring.
2015-10-01 18:35:55.202 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@17c96de, ignoring.
2015-10-01 18:35:55.352 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@14fff48, ignoring.
2015-10-01 18:35:55.503 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@e32742, ignoring.
2015-10-01 18:35:55.652 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@53987d, ignoring.
2015-10-01 18:35:55.802 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@1e6525, ignoring.
2015-10-01 18:35:55.952 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@2cbb7b, ignoring.
2015-10-01 18:35:56.102 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@b0613b, ignoring.
2015-10-01 18:35:56.252 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@18b51d4, ignoring.
2015-10-01 18:35:56.402 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@103c720, ignoring.
2015-10-01 18:35:56.553 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@b28aae, ignoring.
2015-10-01 18:35:56.702 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@11d2f2a, ignoring.
2015-10-01 18:35:56.852 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@15f9103, ignoring.
2015-10-01 18:35:57.020 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@1afdc1a, ignoring.
2015-10-01 18:35:57.154 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@1c11724, ignoring.
2015-10-01 18:35:57.312 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@12a3c98, ignoring.
2015-10-01 18:35:57.447 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@a12d91, ignoring.
2015-10-01 18:35:57.612 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@18020b7, ignoring.
2015-10-01 18:35:57.763 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@558922, ignoring.
2015-10-01 18:35:57.912 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@1f6e749, ignoring.
2015-10-01 18:35:58.063 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@164ce8a, ignoring.
2015-10-01 18:35:58.212 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@173f773, ignoring.
2015-10-01 18:35:58.362 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@1673aa6, ignoring.
2015-10-01 18:35:58.512 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@fa10e5, ignoring.
2015-10-01 18:35:58.662 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@1ecf3f2, ignoring.
2015-10-01 18:35:58.812 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = CONFIGURATION, value = org.openhab.binding.zwave.internal.protocol.ConfigurationParameter@158a65, ignoring.
2015-10-01 18:35:59.153 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = BATTERY, value = 100, ignoring.
2015-10-01 18:35:59.313 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SENSOR_ALARM, value = 0, ignoring.
2015-10-01 18:35:59.453 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SENSOR_BINARY, value = 0, ignoring.
2015-10-01 18:36:01.243 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 3, ignoring.
2015-10-01 18:36:12.833 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 2: No item bound for event, endpoint = 1, command class = SWITCH_MULTILEVEL, value = 3, ignoring.
2015-10-01 18:36:17.923 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 2: No item bound for event, endpoint = 1, command class = SWITCH_MULTILEVEL, value = 99, ignoring.
2015-10-01 18:36:26.273 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 2: No item bound for event, endpoint = 1, command class = SWITCH_MULTILEVEL, value = 0, ignoring.
2015-10-01 18:39:54.116 [INFO ] [c.internal.ModelRepositoryImpl] - Refreshing model ‘default.items’
2015-10-01 18:39:54.226 [WARN ] [.b.z.i.c.ZWaveConverterHandler] - NODE 2: Generating message failed for command class = SWITCH_MULTILEVEL
2015-10-01 18:39:54.228 [WARN ] [.b.z.i.c.ZWaveConverterHandler] - NODE 2: Generating message failed for command class = SWITCH_MULTILEVEL
2015-10-01 18:39:54.230 [WARN ] [.b.z.i.c.ZWaveConverterHandler] - NODE 2: Generating message failed for command class = SWITCH_MULTILEVEL
2015-10-01 18:39:54.231 [WARN ] [.b.z.i.c.ZWaveConverterHandler] - NODE 2: Generating message failed for command class = SWITCH_MULTILEVEL
2015-10-01 18:39:54.237 [WARN ] [.b.z.i.c.ZWaveConverterHandler] - NODE 5: Generating message failed for command class = SENSOR_MULTILEVEL
2015-10-01 18:39:54.243 [WARN ] [.b.z.i.c.ZWaveConverterHandler] - NODE 5: Generating message failed for command class = SENSOR_MULTILEVEL
2015-10-01 18:40:04.271 [INFO ] [c.internal.ModelRepositoryImpl] - Refreshing model ‘default.sitemap’
