I have already an FIbaro Roller Shutter FGR-222 activ with openhab 1.8.
At the including process everything went fine.
Habmin found FGR-222 in the zwave database - the configuration is possible.
Now I bought five more Roller Shutter from Fibaro.
At the including process the Roller Shutter wasn’t found in the zwave database - Configuration isn’t possible
In Habmin there is the following entry: Fibaro System [ID:1000,Type:302]
In the Logfile there are the following entries:
18:22:19.607 [DEBUG] [.z.internal.ZWaveActiveBinding:433 ] - ZwaveIncomingEvent
18:22:19.607 [DEBUG] [.z.internal.ZWaveActiveBinding:450 ] - NODE 7: Got a value event from Z-Wave network, endpoint = 0, command class = SWITCH_BINARY, value = 0
18:22:19.608 [WARN ] [.z.internal.ZWaveActiveBinding:467 ] - NODE 7: No item bound for event, endpoint = 0, command class = SWITCH_BINARY, value = 0, ignoring.
18:22:19.608 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:63 ] - Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 07 02 25 02
18:22:19.608 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:64 ] - Recv message Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 07 03 25 03 00
18:22:19.609 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:65 ] - Checking transaction complete: class=ApplicationCommandHandler, expected=ApplicationCommandHandler, cancelled=false
18:22:19.609 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:68 ] - transaction complete!
18:22:19.609 [DEBUG] [b.z.i.protocol.ZWaveController:635 ] - Notifying event listeners: ZWaveTransactionCompletedEvent
18:22:19.609 [DEBUG] [.z.internal.ZWaveActiveBinding:433 ] - ZwaveIncomingEvent
18:22:19.610 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1013 ] - NODE 7: Node advancer - DYNAMIC_VALUES: Transaction complete (SendData:Request) success(true)
18:22:19.610 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:203 ] - NODE 7: Node advancer - checking initialisation queue. Queue size 1.
18:22:19.610 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:209 ] - NODE 7: Node advancer - message removed from queue. Queue size 0.
18:22:19.611 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:269 ] - NODE 7: Node advancer - DYNAMIC_VALUES: queue length(0), free to send(true)
18:22:19.611 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:1131 ] - NODE 7: Initialisation retry timer started 5000
18:22:19.611 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:335 ] - NODE 7: Node advancer: loop - DYNAMIC_VALUES try 1: stageAdvanced(false)
18:22:19.611 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:781 ] - NODE 7: Node advancer: DYNAMIC_VALUES - checking SWITCH_MULTILEVEL
18:22:19.612 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:784 ] - NODE 7: Node advancer: DYNAMIC_VALUES - found SWITCH_MULTILEVEL
18:22:19.612 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:788 ] - NODE 7: Found 1 instances of SWITCH_MULTILEVEL
18:22:19.612 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:781 ] - NODE 7: Node advancer: DYNAMIC_VALUES - checking CONFIGURATION
18:22:19.613 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:781 ] - NODE 7: Node advancer: DYNAMIC_VALUES - checking BASIC
18:22:19.613 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:781 ] - NODE 7: Node advancer: DYNAMIC_VALUES - checking ASSOCIATION
18:22:19.613 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:781 ] - NODE 7: Node advancer: DYNAMIC_VALUES - checking SENSOR_MULTILEVEL
18:22:19.613 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:784 ] - NODE 7: Node advancer: DYNAMIC_VALUES - found SENSOR_MULTILEVEL
18:22:19.614 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:788 ] - NODE 7: Found 1 instances of SENSOR_MULTILEVEL
18:22:19.614 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:781 ] - NODE 7: Node advancer: DYNAMIC_VALUES - checking METER
18:22:19.614 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:784 ] - NODE 7: Node advancer: DYNAMIC_VALUES - found METER
18:22:19.614 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:788 ] - NODE 7: Found 1 instances of METER
18:22:19.615 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:781 ] - NODE 7: Node advancer: DYNAMIC_VALUES - checking NO_OPERATION
18:22:19.615 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:781 ] - NODE 7: Node advancer: DYNAMIC_VALUES - checking VERSION
18:22:19.615 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:781 ] - NODE 7: Node advancer: DYNAMIC_VALUES - checking SWITCH_BINARY
18:22:19.615 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:784 ] - NODE 7: Node advancer: DYNAMIC_VALUES - found SWITCH_BINARY
18:22:19.616 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:788 ] - NODE 7: Found 1 instances of SWITCH_BINARY
18:22:19.616 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:781 ] - NODE 7: Node advancer: DYNAMIC_VALUES - checking MANUFACTURER_SPECIFIC
18:22:19.616 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:816 ] - NODE 7: Node advancer: DYNAMIC_VALUES - queued 0 frames
18:22:19.617 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:868 ] - NODE 7: Node advancer - advancing to DONE
18:22:19.617 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:335 ] - NODE 7: Node advancer: loop - DONE try 0: stageAdvanced(true)
18:22:19.618 [DEBUG] [.b.z.i.p.i.ZWaveNodeSerializer:107 ] - NODE 7: Serializing to file /var/lib/openhab/zwave/node7.xml
18:22:19.627 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:827 ] - NODE 7: Node advancer: Initialisation complete!
18:22:19.627 [DEBUG] [b.z.i.protocol.ZWaveController:635 ] - Notifying event listeners: ZWaveInitializationCompletedEvent
18:22:19.628 [DEBUG] [.z.internal.ZWaveActiveBinding:425 ] - NODE 7: ZWaveIncomingEvent Called, Network Event, Init Done. Setting device ready.
18:22:19.631 [DEBUG] [z.internal.ZWaveNetworkMonitor:730 ] - Network initialised - starting network monitor.
18:22:19.632 [DEBUG] [WaveController$ZWaveSendThread:1327 ] - NODE 7: Response processed after 64ms/4259ms.
18:22:32.621 [DEBUG] [.z.i.config.ZWaveConfiguration:276 ] - NODE 7: No database entry: Fibaro System [ID:1000,Type:302]
18:22:43.319 [DEBUG] [.z.i.config.ZWaveConfiguration:276 ] - NODE 7: No database entry: Fibaro System [ID:1000,Type:302]
18:22:48.335 [DEBUG] [.z.i.config.ZWaveConfiguration:276 ] - NODE 7: No database entry: Fibaro System [ID:1000,Type:302]
18:22:53.355 [DEBUG] [.z.i.config.ZWaveConfiguration:276 ] - NODE 7: No database entry: Fibaro System [ID:1000,Type:302]
18:22:58.345 [DEBUG] [.z.i.config.ZWaveConfiguration:276 ] - NODE 7: No database entry: Fibaro System [ID:1000,Type:302]
18:23:03.337 [DEBUG] [.z.i.config.ZWaveConfiguration:276 ] - NODE 7: No database entry: Fibaro System [ID:1000,Type:302]
18:23:08.340 [DEBUG] [.z.i.config.ZWaveConfiguration:276 ] - NODE 7: No database entry: Fibaro System [ID:1000,Type:302]
18:23:13.348 [DEBUG] [.z.i.config.ZWaveConfiguration:276 ] - NODE 7: No database entry: Fibaro System [ID:1000,Type:302]
18:23:18.356 [DEBUG] [.z.i.config.ZWaveConfiguration:276 ] - NODE 7: No database entry: Fibaro System [ID:1000,Type:302]
