Make sure you don’t have any associations set to other devices than the controller.
In this case the motion event will trigger those associated devices without intervention of openHAB.
The reboot sorted it out. There were no associations and the rule was deleted. The restart of OH2 didnt work, the restart of the server did.
Ive created my rule. Lets see if this works, intention is to turn the lights on if someone gets up in the middle of the night and goes to the bathroom and then switch them off, after 2 minutes of no motion.
var Timer Eye1_Timer = null
val Integer Eye1_TimeOut = 2
rule "FibaroEye1 motion detection turns ON Living Room Lights when Dark"
Item FibaroEye1Motion changed to ON
if (FibaroEye1Lux.state < 20 ) {
if (Eye1_Timer !== null) {
LivingRoomSw1.sendCommand("ON")
logInfo("FibaroEye1Motion","Eye1 Timer rescheduled for " + Eye1_TimeOut + " minutes")
Eye1_Timer.reschedule(now.plusMinutes(Eye1_TimeOut))
} else {
logInfo("FibaroEye1Motion", "Eye1 Motion Detected! Turn ON Living Lights")
logInfo("FibaroEye1Motion","Eye1 Timer created with " + Eye1_TimeOut + " minutes")
Eye1_Timer = createTimer(now.plusMinutes(Eye1_TimeOut))
if (FibaroEye1Motion.state == OFF) {
logInfo("FibaroEye1Motion","Eye1 Timer triggered, but rescheduled again for " + Eye1_TimeOut + " minutes")
} else {
logInfo("FibaroEye1Motion", "Eye1 No Motion Detected! Turn OFF Living Lights")
LivingRoomSw1.sendCommand("OFF")
Eye1_Timer = null
The Fibaro detects motion but it doesnt turn the lights on alas
I’m having the same issue as several others in this thread. I’m on OH2 running on RPi3. I’m not getting any results on movement. The temperature and lux appear to work correctly.
This thread is well over a year old, so an awful lot has changed. If you are not using the latest snapshot, then please update.
I ran all of the updates using the config tool on my pi and I’m still having the same issue as other people in this thread. The temp and lux work fine, but I don’t get any response on motion.
Please provide debug logs showing what is received when there is motion. If nothing is received, then it is likely a device configuration or association issue on the device, but in this case, the binding can’t do anything if there is no message from the device.
Hi, I bought three of these devices. They worked as expected for 24 hrs or so, then motion alarms are not being reported. @chris, i understand you are maintaining the binding database. What logs if any would you like?
tnx
We don’t know anything about your setup, openHAB version, os version, … to give you an appropriate answer.
As you can read in many, many zwave threads a DEBUG log is needed. Please search the forum on how to do that.
Also please read How to ask a good question / Help Us Help You
The binding debug logs, although my guess is that it won’t help if the device has stopped sending data, but let’s check.
@chris , I´m currently running version OHv: 2.4.0~S1461-1. with binding-zwave - 2.4.0.SNAPSHOT.
I been reading through the fibaro “eye” posts here and it looks like i experience similar issues.
In my script im checking for when Item change.
Item H_KitchenSensor_Motion changed from OFF to ON
I have several motion detectors of another brand and they are working as expected.
As i mentioned in the OP, the fibaro device “FGMS001 Motion Sensor, zw5 v3.3 EU” report the status change when its added to the system and for some time, until its silence.
As for visual observation.
The eye initially flash green when motion and report event ON/OFF as expected.
Then the eye flashes amber when motion, and no report.
Today it flashed green again, how ever with nothing in the logs as of status change.
Debug logs from when i triggered motion this morning.
N/A no events
trying to force logs by resetting device.
[10:06:29] openhabian@openHABianPi:/var/log/openhab2$ tail -f /var/log/openhab2/openhab.log | grep "NODE 14"
2018-12-16 10:07:52.424 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 14: Application Command Request (ALIVE:DONE)
2018-12-16 10:07:52.426 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 14: resetResendCount initComplete=true isDead=false
2018-12-16 10:07:52.430 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 14: Is awake with 0 messages in the queue
2018-12-16 10:07:52.432 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 14: Start sleep timer at 1000ms
2018-12-16 10:07:52.435 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Got an event from Z-Wave network: ZWaveNodeStatusEvent
2018-12-16 10:07:52.460 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 14: Node Status event - Node is AWAKE
2018-12-16 10:07:52.463 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 14: Commands processed 1.
2018-12-16 10:07:52.466 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 14: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@161d86d.
2018-12-16 10:07:52.934 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 14: WakeupTimerTask 0 Messages waiting, state DONE
2018-12-16 10:07:53.435 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 14: WakeupTimerTask 0 Messages waiting, state DONE
2018-12-16 10:07:53.438 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 14: No more messages, go back to sleep
2018-12-16 10:07:53.440 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 14: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
2018-12-16 10:07:53.443 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 14: SECURITY NOT required on COMMAND_CLASS_WAKE_UP
2018-12-16 10:07:53.447 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 14: Command Class COMMAND_CLASS_WAKE_UP is NOT required to be secured
2018-12-16 10:07:53.450 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 14: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@103801c
2018-12-16 10:07:53.454 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 14: Bump transaction 668 priority from Immediate to Immediate
2018-12-16 10:07:53.458 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 14: Adding to device queue
2018-12-16 10:07:53.461 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 14: Added 668 to queue - size 2
2018-12-16 10:07:53.472 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 14: Sending REQUEST Message = 01 09 00 13 0E 02 84 08 25 76 36
2018-12-16 10:07:53.550 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 14: sentData successfully placed on stack.
2018-12-16 10:07:53.556 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 14: TID 668: Transaction not completed
2018-12-16 10:07:53.662 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 14: SendData Request. CallBack ID = 118, Status = Transmission complete and ACK received(0)
2018-12-16 10:07:53.665 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 14: resetResendCount initComplete=true isDead=false
2018-12-16 10:07:53.671 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 14: Response processed after 166ms
2018-12-16 10:07:53.674 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 14: TID 668: Transaction completed
2018-12-16 10:07:53.677 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 14: notifyTransactionResponse TID:668 DONE
2018-12-16 10:07:53.681 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2018-12-16 10:07:53.687 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 14: Went to sleep COMPLETE
2018-12-16 10:08:00.759 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 14: Application Command Request (ALIVE:DONE)
2018-12-16 10:08:00.763 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 14: resetResendCount initComplete=true isDead=false
2018-12-16 10:08:00.766 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 14: Incoming command class COMMAND_CLASS_DEVICE_RESET_LOCALLY, endpoint 0
2018-12-16 10:08:00.769 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 14: SECURITY NOT required on COMMAND_CLASS_DEVICE_RESET_LOCALLY
2018-12-16 10:08:00.771 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 14: Received COMMAND_CLASS_DEVICE_RESET_LOCALLY V1 unknown command 1
2018-12-16 10:08:00.774 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 14: Commands processed 1.
2018-12-16 10:08:00.777 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 14: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1b6846.
So the very interesting thing here is that the device is saying it has been locally reset to factory defaults, so in this case, it will likely have lost its configuration (eg the association configuration) and this would explain the problem.
(please also use code fences when pasting logs - or format with the </>
button - I’ve edited your post to do this so that it’s readable).
@chris Yes as it was absolute silent i manually resat the device this morning. So if i understand you properly, your suggestion is to recreate the device motion item binding or to re add the device to the controller?
The thing i find most interesting is that it did work, and then “died” without any layer8 interaction.
As i mentioned I have several EYE´s so I suggest I add another one, leave debugging on and update the thread with findings.
Thank you for beautifying my post. Its been a while since I was active on forums.
What do you mean by “layer8”?
Yes, if the device is loosing its configuration, or at least, it’s stopped sending the alerts, then we need to find out why. Either the device is doing something by itself (ie there’s a device problem) or the binding is doing something. If it’s the binding, then we need to get the logs to find out where it’s going wrong. If it is working, then capture the logs until it stops working, then we need to find if there are any commands sent by the binding that might reconfigure the device (eg association changes).
Human interaction. OSI model Phun.
Ok. I will add one of the other eyes for testing and dump the logfiles. This may take a few days.
I will keep you posted with any findings.
Ok, not come across that before - I like it
@chris
f001dbg.log (421.7 KB)
Added Node 19. Its behaving now and i am tailing the logfile in the backgroud for updates.
I get alarm notifications.
As agreed I will let this run for testing purposes. Its currently in a room where events are frequently triggered.
This is not the same device, but it had the same symptoms as the other two.
Please investigate the logfile attached for any abnormal behavior.
And when you find that , jump on it’s back and fly it over the ! I’ve been chasing it for a couple years now!
Please don’t filter the logs - you remove all the useful stuff and I can’t process them properly without the data that is received from the device as it’s a one sided story with only the TX data.
This has an initialisation of the device, and it looks fine as the associations seems to have been set correctly -:
Since the log doesn’t have the information from the device, I don’t see the final configuration, but at least from what I see here it looks ok.
