No problem. Also the firmware version should be on the back of your device.
But even if it is firmware version 5.0, you should get an xml file after successful inclusion.
Until we (you) get an xml, we can’t do anything.
Okay, almost, there is still something to do if it is not working: switch do DEBUG and post the log file after an inclusion attempt.
I checked the firmware number - it is actually 5.1.
but I found something interesting - nothing happens at the range test:
The device has a built in Z-Wave network main controller’s
range tester.
Follow the below instructions to test the main controller’s range:
- Switch off the mains voltage (disable the fuse).
- Remove the device from the wall switch box.
- Switch on the mains voltage.
- Press and hold the B-button to enter the menu.
- Wait for the visual LED indicator to glow violet.
- Quickly release and click the B-button again.
- Visual indicator will indicate the Z-Wave network’s range (range
signalling modes described below).- To exit Z-Wave range test, click the B-button.
Z-Wave range tester signalling modes:
- Visual indicator pulsing green - the device attempts to establish a
direct communication with the main controller. If a direct communication
attempt fails, the device will try to establish a routed communication,
through other modules, which will be signalled by visual
indicator pulsing yellow.- Visual indicator glowing green - the device communicates with the
main controller directly.- Visual indicator pulsing yellow - the device tries to establish a routed
communication with the main controller through other modules
(repeaters).- Visual indicator glowing yellow - the device communicates with
the main controller through the other modules. After 2 seconds the
device will retry to establish a direct communication with the main
controller, which will be signalled with visual indicator pulsing green.- Visual indicator pulsing violet - the device does communicate at the
maximum distance of the Z-Wave network. If connection proves successful
it will be confirmed with a yellow glow. It’s not recommended
to use the device at the range limit.- Visual indicator glowing red - the device is not able to connect to
the main controller directly or through another Z-Wave network device
(repeater).
in my case the “visual indicator” simply stays black …
Then you have to look for your problems on the hardware side, not the openHAB software side.
Actually you can’t do a range test as long as the device is not connected to a controller
Then you need to:
