- Platform information:
- Hardware: Synology
- OS: DSM 6.2.2
- Java Runtime Environment: 8
- openHAB version: 2.5.2
- Zwave binding: 2.5.2
I’m using a Roller shutter 3 (FGR223 FW 5.1) to control an awning (Markise) mounted on top of a glass roof. When the awning goes down and stops, then the awning cloth touches the glass. This can be avoided by changing direction and going up for a short moment (e.g. 1s).
I would like openhab to do this automatically, but I fail to create a useful trigger point that triggers when the awning made a stop after a DOWN command.
In general I can trigger on the command DOWN …
Item zwave_device_c6dd6a91_node6_blinds_control1 received command DOWN
and I could do the same for the command STOP.
Another problem:
It seems as if the device does not receive a STOP command when the blinds stop. A STOP command is only sent when I press the STOP button in the UI.
e.g. when it arrives at the lower endpoint or
e.g. when the device is ordered to get to 75% via SendCommand…
zwave_device_c6dd6a91_node6_blinds_control1.sendCommand(75)
Is there a way to trigger when the awning made a stop after a DOWN command?
As a workaround I could always press the STOP button in the UI and trigger the rule. But that’s not what I’m aiming at.
Thanks!
