I am testing Fibaro Smart Implant connected with a magnetic contact (ABUS MK1010). Currently the whole installation is on my desktop. Finally the magnetic contact should monitor open/close of a door.
The wire connection follows the recommendation of Fibaro:
openHAB item:
Switch Tuer_IN1_EG_Gartenhaus "Gartenhaustür Input 1 Alarm" (EG_Gartenhaus) {channel="zwave:device:7cd6bd6b:node37:alarm_burglar1"}
openHAB rule:
rule "Door "
Time cron "* 30 10 * * ?"
logDebug("Ausgabe", "Gartentür IN1 = " + Tuer_IN1_EG_Gartenhaus)
When I start the rule, the debug output is as follows:
2021-12-28 10:30:00.407 [DEBUG] [lipse.smarthome.model.script.Ausgabe] - Gartentür IN1 = Tuer_IN1_EG_Gartenhaus (Type=SwitchItem, State=NULL, Label=Gartenhaustür Input 1 Alarm, Category=null, Groups=[EG_Gartenhaus])
The rule does not recognize the status of the magnetic contact open/close. Why not? The debug ouput above is repeated 60 times. What is the reason?
The thing parameters are as follows:
No. 20 Input 1 operating mode: “Normally closed alarm input”. All other parameters are default values.
