Today I got two new Fibaro Smoke detector and I have some issue to configure those guys.
Only signal I get back at the moment is the temperature, all the rest is showing “null”.
I know that all this alarms will not return or change until something happend, but I expect a signal when I take the Sensor from his mounting device , but nothing happend.
If I change something in the association groups,I find the following messages in the Debug Log (Thanks to Bruce again showing me the way to this !):
The log atarts with this:
''2021-05-22 17:15:42.018 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Controller status changed to ONLINE.
2021-05-22 17:15:42.021 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Controller is ONLINE. Starting device initialisation.
2021-05-22 17:15:42.027 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Updating node properties.
2021-05-22 17:15:42.028 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Updating node properties. MAN=271
2021-05-22 17:15:42.028 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Updating node properties. MAN=271. SET. Was 271
2021-05-22 17:15:42.029 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Properties synchronised
2021-05-22 17:15:42.032 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Update ASSOCIATION group_ZWaveAssociationGroup [index=1, name=null, profile1=null, profile2=null, associations=[node_1]]: Adding Controller (node_1)
2021-05-22 17:15:42.033 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration synchronised
2021-05-22 17:15:42.040 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Initialising Thing Node…
2021-05-22 17:15:42.041 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Initialising cmd channel zwave:device:fead79cbfa:node24:sensor_temperature for QuantityType
2021-05-22 17:15:42.042 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Initialising state channel zwave:device:fead79cbfa:node24:sensor_temperature for QuantityType
2021-05-22 17:15:42.044 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Initialising cmd channel zwave:device:fead79cbfa:node24:alarm_heat for OnOffType
2021-05-22 17:15:42.045 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Initialising state channel zwave:device:fead79cbfa:node24:alarm_heat for OnOffType
2021-05-22 17:15:42.046 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Initialising cmd channel zwave:device:fead79cbfa:node24:alarm_smoke for OnOffType
2021-05-22 17:15:42.047 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Initialising state channel zwave:device:fead79cbfa:node24:alarm_smoke for OnOffType
2021-05-22 17:15:42.048 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Initialising cmd channel zwave:device:fead79cbfa:node24:alarm_system for OnOffType
2021-05-22 17:15:42.049 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Initialising state channel zwave:device:fead79cbfa:node24:alarm_system for OnOffType
2021-05-22 17:15:42.050 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Initialising cmd channel zwave:device:fead79cbfa:node24:alarm_tamper for OnOffType
2021-05-22 17:15:42.050 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Initialising state channel zwave:device:fead79cbfa:node24:alarm_tamper for OnOffType
2021-05-22 17:15:42.051 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Initialising cmd channel zwave:device:fead79cbfa:node24:alarm_battery for OnOffType
2021-05-22 17:15:42.052 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Initialising state channel zwave:device:fead79cbfa:node24:alarm_battery for OnOffType
2021-05-22 17:15:42.053 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Initialising cmd channel zwave:device:fead79cbfa:node24:battery-level for PercentType
2021-05-22 17:15:42.053 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Initialising state channel zwave:device:fead79cbfa:node24:battery-level for PercentType
2021-05-22 17:15:42.055 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Polling initialised at 1800 seconds - start in 1081800 milliseconds.
2021-05-22 17:15:42.056 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Device initialisation complete.’’
Looks Good to me. As soon as I change something in the configuration I get this:
‘‘2021-05-22 17:17:16.082 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update received
2021-05-22 17:17:16.141 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update ignored group_2 to [] (EmptyList)
2021-05-22 17:17:16.142 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update ignored action_heal to false (Boolean)
2021-05-22 17:17:16.142 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update ignored config_1_1 to 2 (BigDecimal)
2021-05-22 17:17:16.143 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update ignored config_2_1 to 3 (BigDecimal)
2021-05-22 17:17:16.143 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update ignored wakeup_node to 1 (BigDecimal)
2021-05-22 17:17:16.144 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update ignored config_12_2 to 0 (BigDecimal)
2021-05-22 17:17:16.145 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update ignored config_11_2 to 255 (BigDecimal)
2021-05-22 17:17:16.145 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update ignored config_3_1 to 7 (BigDecimal)
2021-05-22 17:17:16.146 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update ignored config_4_1 to 7 (BigDecimal)
2021-05-22 17:17:16.147 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update ignored config_13_1 to 0 (BigDecimal)
2021-05-22 17:17:16.147 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update ignored config_14_1 to 15 (BigDecimal)
2021-05-22 17:17:16.148 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update ignored node_id to 24 (BigDecimal)’’
I even switch my system back to “Stable” and back to “Milestone” and change the Z Wave Binding, but no success so far, Failure messages stay the same. I have a feeling that somehow the way the Numbers are sent to the device are not in the right format, but have no idea how to change that.
I searched the Forum, but couldn’t find something related to this messages. If there is somethign I missed, I’m sorry and appreciate the guide to the post.
My configuration:
Raspberry 3 Modell B+
Raspian GNU/Linux 10 (buster) / Linux 5.10.17 -v7+
openHAB 3.1.0.M4 Milestone Build
ZWAVE Binding 3.1.0.M4
