I got the impression (from Fibaros commercial material) that I should be able to get the smoke level (assumeably as a numerical value) from this unit…
However when configuring I can’t see any channel that corresponds to that…
Has anyone got any information ?
There is no channel available in the database:
https://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/129
The only parameter you can change is the smoke level detected…so I guess device internally the smoke level must be available.
This data uses a proprietary command class from Fibaro and is not available publicly. If someone knows the information to decode it, then I’m happy to look at adding it.
ah okay … that explains it… thanks!
