- Platform information:
- Hardware: raspberry pi 3
- OS: openhabian 32
- openHAB version: 3.2.0
- Issue of the topic: not able to set Param 28 send scene ID for both 1 time and 2 time pressed keys
In the PaperUI, when I go to the “Thing” and select a Fibaro switch 2 for configuration I can set the Parameter 28/29/30 by choosing between “No scene sent, key pressed 1 time, key pressed 2 times,…” etc. rather than entereing the raw value like for Parameter 27.
According to the datasheet of Fibaro switch 2 there’s a possibility to combine and configure the switch for sending scene ID for both key pressed 1 time and key pressed 2 times by adding the values, e.g. 1+2=3. But using the PaperUI I am not able to set the parameter to 3, only 1,2,4 or 8.
Any way for me to achieve such setting?
Would it make sense to change the interface to just enter the raw value for maximum flexibility, like it is done for parameter 27 for example?
Regards, Stefan
