I’m trying to accomplish a special setup where S1 switch is able to turn on both Q1 and Q2 depending on the scene (1 click for turning on Q1 and press and hold in order to turn on Q2). the intention is to be able to do other things with S2 scenes. The problem is that I’m afraid it is not possible to detach it from Q2, i.e. not to turn on it when pressed. I tried to set param 16 to “no reaction”, without success.
Does anybody tried something similar? is it even possible to detach switches from outputs?
