Hi I’m having trouble with one of my three universalsensors. I recently added on new to my network and connected 3 temperature sesnors DS18B20 of the same kkind that I have running on one other universalsensor. As I figured out the sensor only listens for sensors during the first period of time or if it’s when it gets included. Hence i but all my sensor inplace befor powering up and include device to Zwave network (aeonlab usb stick gen5). But I did just get one temeprature reading from one sensor and that’s it. I read somewhere about putting a pull upp resistor to feed 5volt also on the VCC and TP line. Since this pullup thing is well known I was thinking that Fibaro built their sensor like that allready. Wire lenght is approximatley 1m on each temp sensor. Does anyone here knows how to solwe this problem.
I Paste in the .xml file from zwave folder of this device.
I’m hoping it might be possible to see if univeral sensor have recognized any temperature sensors.
Ther’s on strange messeage in the debug log which make me think that somethings wrong but measseage is still a debug not warning or error
15:16:49.914 [DEBUG] [essage.ApplicationCommandMessageClass] - NODE 28: Transact ion not completed: node address inconsistent. lastSent=28, incoming=255
ROUTING_SLAVE BINARY_SENSOR ROUTING_SENSOR_BINARY 0xe6c4274b 28 4 0x10f 0x1002 0x501 true false true false true 40000 SENSOR_BINARY MULTI_INSTANCE ASSOCIATION MULTI_INSTANCE_ASSOCIATION MANUFACTURER_SPECIFIC CONFIGURATION VERSION FIRMWARE_UPDATE_MD ASSOCIATION 2 1 2 3 MULTI_INSTANCE_ASSOCIATION 2 1 2 2 MULTI_INSTANCE 2 1 2 1 ROUTING_SLAVE BINARY_SENSOR ROUTING_SENSOR_BINARY 1 BASIC 0 0 0 true SENSOR_BINARY 1 1 1 true SENSOR_ALARM 0 1 0 true false 2 ROUTING_SLAVE BINARY_SENSOR ROUTING_SENSOR_BINARY 2 BASIC 0 0 0 true SENSOR_BINARY 1 1 1 true SENSOR_ALARM 0 1 0 true false false true CONFIGURATION 1 1 1 1 1 2 0 false false 2 2 2 0 false false 3 3 1 1 false false 4 4 1 1 false false 5 5 1 -1 false false 6 6 1 -1 false false 7 7 1 -1 false false 8 8 1 -1 false false 9 9 1 0 false false 10 10 1 20 false false 11 11 1 -56 false false 12 12 1 8 false false 13 13 1 0 false false 14 14 1 0 false false FIRMWARE_UPDATE_MD 1 1 1 VERSION 1 1 1 LIB_SLAVE_ENHANCED 3.52 2.1 BASIC 1 1 1 true SENSOR_BINARY 1 1 1 true NO_OPERATION 1 1 1 MANUFACTURER_SPECIFIC 1 1 1 false 271 1281 4098 1 1 2 2 3 3 1 25 2019-01-05 09:37:12.196 UTC 2019-01-05 09:37:12.393 UTC‘’
