Fibaro Wall Parameter 47
I have tried to modify parameter 47 to any value different of default 3600 but not able
Any idea?
Using 1.7 zwave binding
You have to do it via Habmin. You cannot change parameters in a normal item configuration - if that is what you tried…
Regards
Ollie
Hi Oliver.
Sure i did with habmin. Thats where i found issue. I changed but always returns to 3600 secs
Please provide a debug log covering the period around the time you try to make the change and I’ll take a look…
Chris
