- Platform information:
- Hardware: Rasp Pi 3 B+ and Aeon Zwave Stick Gen 5
- OS: openHABian
- Java Runtime Environment: which java platform is used and what version
- openHAB version: 2.2
- Issue of the topic: Error 500 when saving new thing configuration: Fibaro Wall Plug FGWP102
- Please post configurations (if applicable): Fresh install.
Hi, newbie here with OpenHab.
Config as above. When I added the power plug it was properly recognized by the Zwave Binding (paperUI). When I went into configuration and tried to give a name and location, upon save, I get Error: 500 - Internal Server Error. Plug doesn’t sho up in control.
Tried configuring in HABMIN as this was recommended in some threads. No error message there, but the plug still doesn’t show up in Control.
Based on what I read there might be a wrong variable in the default Thing Configuration, resulting in a failed save.
Properties of the plug:
zwave_class_basic | ROUTING_SLAVE |
zwave_class_generic | BINARY_SWITCH |
zwave_frequent | false |
zwave_neighbours | 1 |
zwave_version | 3.2 |
zwave_listening | false |
zwave_plus_devicetype | ON_OFF_POWER_SWITCH |
zwave_deviceid | 4097 |
zwave_nodeid | 2 |
zwave_routing | false |
zwave_beaming | false |
zwave_class_specific | POWER_SWITCH_BINARY |
zwave_manufacturer | 271 |
zwave_devicetype | 1538 |
Log files from Log Viewer seem to support the wrong default variable theory.
Any ideas?
Thank you!
Arnold
2018-05-07 20:15:30.237 [ERROR] [st.core.internal.thing.ThingResource] - Exception during HTTP PUT request for update config at 'things/zwave:device:91ca99c1:node2/config’
java.lang.ClassCastException: java.math.BigDecimal cannot be cast to java.lang.Integer
at org.openhab.binding.zwave.handler.ZWaveThingHandler.handleConfigurationUpdate(ZWaveThingHandler.java:749) [228:org.openhab.binding.zwave:2.2.0]
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.updateConfiguration(ThingRegistryImpl.java:94) [116:org.eclipse.smarthome.core.thing:0.10.0.b1]
at org.eclipse.smarthome.io.rest.core.internal.thing.ThingResource.updateConfiguration(ThingResource.java:413) [126:org.eclipse.smarthome.io.rest.core:0.10.0.b1]
at sun.reflect.GeneratedMethodAccessor38.invoke(Unknown Source) ~[?:?]
at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:160) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [15:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:848) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [85:org.eclipse.jetty.security:9.3.22.v20171030]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.Server.handle(Server.java:534) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:333) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:251) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:283) [79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:108) [79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93) [79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589) [90:org.eclipse.jetty.util:9.3.22.v20171030]
2018-05-07 20:15:50.392 [me.event.ThingUpdatedEvent] - Thing ‘zwave:device:91ca99c1:node2’ has been updated.
2018-05-07 20:15:50.399 [vent.ConfigStatusInfoEvent] - ConfigStatusInfo [configStatusMessages=[ConfigStatusMessage [parameterName=config_30_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_42_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_31_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_20_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_40_2, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_41_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_32_2, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_21_2, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_43_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_11_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_10_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_50_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=powerlevel_level, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=group_3, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=group_2, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_1_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_2_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_12_2, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_13_2, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_14_2, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_15_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null]]]
2018-05-07 20:15:50.447 [me.event.ThingUpdatedEvent] - Thing ‘zwave:device:91ca99c1:node2’ has been updated.
2018-05-07 20:15:50.451 [vent.ConfigStatusInfoEvent] - ConfigStatusInfo [configStatusMessages=[ConfigStatusMessage [parameterName=config_30_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_42_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_31_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_20_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_40_2, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_41_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_32_2, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_21_2, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_43_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_11_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_10_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_50_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=powerlevel_level, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=group_2, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_1_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_2_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_12_2, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_13_2, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_14_2, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_15_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null]]]
2018-05-07 20:15:50.500 [me.event.ThingUpdatedEvent] - Thing ‘zwave:device:91ca99c1:node2’ has been updated.
2018-05-07 20:15:50.503 [vent.ConfigStatusInfoEvent] - ConfigStatusInfo [configStatusMessages=[ConfigStatusMessage [parameterName=config_30_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_42_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_31_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_20_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_40_2, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_41_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_32_2, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_21_2, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_43_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_11_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_10_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_50_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=powerlevel_level, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_1_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_2_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_12_2, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_13_2, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_14_2, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_15_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null]]]
2018-05-07 20:15:50.552 [me.event.ThingUpdatedEvent] - Thing ‘zwave:device:91ca99c1:node2’ has been updated.
2018-05-07 20:15:50.555 [vent.ConfigStatusInfoEvent] - ConfigStatusInfo [configStatusMessages=[ConfigStatusMessage [parameterName=config_30_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_42_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_31_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_20_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_40_2, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_41_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_32_2, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_21_2, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_43_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_11_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_10_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_50_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_1_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_2_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_12_2, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_13_2, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_14_2, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_15_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null]]]
